Old Jul 06, 2015, 09:09 AM
elbone65 is offline
Find More Posts by elbone65
Gonads, Son! Big brass ones!
elbone65's Avatar
United States, OK, Oklahoma City
Joined May 2005
Question
Mystique RES - Pure Sailplane
Anybody flying the Mystique RES as a pure sailplane? I decided a while back to leave the motors at home.
I am looking for any tips, etc. Thanks
elbone65 is offline Find More Posts by elbone65
Old Jul 06, 2015, 10:08 AM
jswain is online now
Find More Posts by jswain
Gasbags & Gussets
jswain's Avatar
Riverside, Ca
Joined Feb 2009
suggestion
Consider reinforcing the battery tray hold down structure with some extra material and glue joints when using this model on a winch or high start. If using the 3~4s lipo battery, it weighs a lot more than a typical thermal glider (i.e. 2000mah AA cell type) thus has a lot of momentum to be restrained inside the fuselage on launch. Other than that it flys well and is an enjoyable arf type model.
jswain is online now Find More Posts by jswain
Old Jul 06, 2015, 10:31 AM
elbone65 is offline
elbone65's Avatar
Joined May 2005
jswain- Now that there is no motor weight need to be added in order to balance it. I had to add 11oz to the nose area is that about the amount of weight you added?
I am planning on flying it with a 2000mah NiMh battery.
Old Jul 06, 2015, 03:59 PM
Gasbags & Gussets
jswain's Avatar
Riverside, Ca
Joined Feb 2009
answer
Originally Posted by elbone65 View Post
jswain- Now that there is no motor weight need to be added in order to balance it. I had to add 11oz to the nose area is that about the amount of weight you added? I am planning on flying it with a 2000mah NiMh battery.
I think you will be 100% fine using the nimh and whatever weight is needed to balance at suggested CG, just make sure to secure that 11oz of nose weight in the frame or fuse's fiberglass.
What i saw happen was a clubmates 100% configured electric powered mystique that also had a tow hook on the bottom. Upon reaching the apex (and moving at moderate speed) of the winch tow was the 3s lipo battery's weight break loose the strap and wood supports thus disconnect power to all the electrics. The 3s lipo battery and canopy were ejected.
Nothing is 'wrong' with the planes basic design at all, but with hindsight and using a large lipo and winch tow, it showed an unexpected for need for better battery security. Aerotow or slope soaring or high-starting would NOT cause this drama but a winch could (and did).
Your planned use of small double AA's and secured ballast in place of motors and lipo would be OK.
Sold MYSTIQUE RES 2.9M by EFLITE tcarter Aircraft - Sailplanes (FS/W) 4 Jun 20, 2015 03:04 PM
Discussion PuRES - a 2 mtr RES Sailplane (Germany) seppale Thermal 30 May 21, 2015 10:03 AM
Sold E-flite Mystique RES 2.9meter E-sailplane. botulism Aircraft - Sailplanes (FS/W) 0 Aug 02, 2014 01:01 AM
For Sale E-flite Mystique RES 2.9meter E-sailplane. botulism Aircraft - Sailplanes (FS/W) 4 Jul 17, 2014 10:03 PM
Discussion Mystique full house vs RES bmwbob Electric Competition Soaring-F5J/ALES/e-Soaring 0 Dec 21, 2013 09:36 PM
