Old Jan 01, 2014, 01:10 PM
1000MPH is offline
Find More Posts by 1000MPH
Objects in mirror are losing
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
The OEMs were AA sized? I replaced the batteries on my older Stalker Pro with a relatively cheap NiMh, Sub C, RC car pack. Still works great. The guts looked very similar to yours with the temp sensor and 3 wire setup. Can you field charge those guns? Might want to hook up a pigtail while you're at it.
1000MPH is offline Find More Posts by 1000MPH
Old Jan 02, 2014, 02:18 AM
ALEX HEWSON is offline
Find More Posts by ALEX HEWSON
PB of 733kph
ALEX HEWSON's Avatar
Christchurch, New Zealand
Joined Jul 2005
Stock capacity was 2400mah. Now has 2000mah eneloop.
The 2400mah cells were same length as AAs but slightly fatter.
I have never charged it above 1A at the field
ALEX HEWSON is offline Find More Posts by ALEX HEWSON
Old Jan 02, 2014, 03:57 AM
josh18 is offline
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
Good to see youre getting some time back for DS Alex. I remember that day at dilmah ridge with frustration at our guns, as I reckon that's by far the fastest Ive flown! Oh well, have to come back there again!
josh18 is offline Find More Posts by josh18
Old Jan 02, 2014, 10:56 AM
PB of 733kph
Joined Jul 2005
Yes you will! Come back soon mate
Old Jan 02, 2014, 05:05 PM
josh18 is offline
608 km/h!
josh18's Avatar
Joined Jan 2010
cant wait!
Old Jan 03, 2014, 01:04 AM
PB of 733kph
Joined Jul 2005
Did some more testing today. Different range settings etc. This is the best the gun has ever gone! Got 156mph with a Reaper on a front side dive (dived from almost out of sight) Followed with solid readings for about the last 300ft of the dive on 20-220 range setting. Beforehand, it would only read if directly, I mean directly at the gun and only if lucky the last 100ft
If anyone is having problems with their Falcon, I HIGHLY suggest making sure your power system to it is solid and giving a good voltage
Old Jan 03, 2014, 12:16 PM
wdeighton is offline
Find More Posts by wdeighton
Where is the inspiration
wdeighton's Avatar
Moira
Joined Feb 2006
Alex
Would you please do a build log with pictures and your final configuration of electronics.
I am interested in giving this a go.
William
wdeighton is offline Find More Posts by wdeighton
Old Jan 03, 2014, 01:01 PM
PB of 733kph
Joined Jul 2005
It is just a direct copy of the original battery configuration (I even re-used the solder tabs between the cells), but I used Eneloop 2000mah cells instead
Just make sue you keep the length as I had to dremel out a bit of the handle to get it to fit again
Old Jan 04, 2014, 05:35 PM
AvB is offline
AvB
Find More Posts by AvB
AvB
Wind, hill, ... I'm keen ...
AvB's Avatar
Australia, QLD, Woody Point
Joined Nov 2006
Stu, I field charge mine ... I took the original wall pack charge lead, cut it and soldered a servo plug onto the end. So all my Falcon gun charging is done with the peak charger - I can't use the wall plug now. Ah, I remember ... that's because I got sent one with the US wall plug! Anyway it works and I like the fact that I can charge it on the hill too.
Gee Alex you've got me wondering now if I should replace my batteries with Eneloops too! It's so frustrating when you're gunning a fast Kinetic and getting no-reads ...
AvB is offline Find More Posts by AvB
Old Jan 04, 2014, 05:40 PM
josh18 is offline
608 km/h!
josh18's Avatar
Joined Jan 2010
My TX battery was wrecked by a wall charger so I have done exactly like you have done Andrew. I expect my new battery to last a lot longer because the proper charger will look after it much better.
Cheers
Old Jan 04, 2014, 09:51 PM
PB of 733kph
Joined Jul 2005
Wait till I get something fast back in the circuit again and get the radar on it before you change it. Missed a good 50mph good direction day at Tekapo today:
Old Jan 05, 2014, 09:32 PM
1000MPH is offline
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
So there's no issues peak charging with those electronic components in series?
Old Jan 05, 2014, 09:58 PM
PB of 733kph
Joined Jul 2005
Not that I have experienced. I generally charge at less than 1amp
Old Jan 05, 2014, 11:37 PM
1000MPH is offline
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
Sounds good. Thanks.
Discussion Comparing Stalker Pro 2 and Falcon DS Radar Guns AvB Dynamic Soaring 21 Feb 04, 2015 10:20 PM
For Sale Align ds 420 tail servo and a Hyperion ds-11 NIP benysjets Aircraft - Electric - Helis (FS/W) 0 Dec 16, 2013 08:43 AM
Sold NIP Align Servos (DS-610 x3) & (DS-650 x1) helinut4ever Aircraft - General - Radio Equipment (FS/W) 0 Dec 08, 2013 01:02 PM
Discussion New K100 and falcon ds adam_lambretta Dynamic Soaring 1 Apr 21, 2012 03:35 AM
Discussion Falcon DS Radar Gun Jantar2A Dynamic Soaring 4 Sep 09, 2010 10:16 PM
