Old Aug 11, 2012, 12:26 PM
gravityKills is offline
Find More Posts by gravityKills
like a rock!
gravityKills's Avatar
Finland
Joined Oct 2007
Question
Quantum 4530-500 and GAUI X7
Hello,
does anybody know a source for longer motor shafts to fit the 4530-500 into the X7?
By default, it is too short to reach the lower support bearing, and flying with unsupported shaft is out of the question.
Has there maybe a successful "transplantation" for a Scorpion 4035 XXL shaft, or is there any other shaft that fits?
gravityKills is offline Find More Posts by gravityKills
Old Sep 11, 2012, 07:51 AM
Ballsy is offline
Find More Posts by Ballsy
Ballsy's Avatar
South Africa, WC, Cape Town
Joined Jul 2008
I have done that exact "transplantation" on my Quantum and it fitted like a glove. Haven't finished with the heli build so still have to fly it. About 98% complete and should fly this Sat, but on the bench I cant find anything wrong with using that shaft.
Ballsy is offline Find More Posts by Ballsy
Old Dec 31, 2012, 08:26 AM
like a rock!
Finland
Joined Oct 2007
Thanks.
After a couple of months in use, I can confirm that it works
In my opinion it is mandatory to grind some slots for the two set screws, otherwise it won't hold long (think thermal expansion).
It's easily done with a Proxxon / Dremel tool.
Grinding a slot also for the 2nd pinion set screw sounds like a good idea, but note that the 10 tooth pinion and the 11 tooth GAUI pinion have them at 180 degrees and 90 degrees, respectively.
Some test flight video from today's day on the beach:
GAUI X7 with Quantum motor (0 min 0 sec)
The flying isn't that brilliant, but I hope it gives some idea on power and consistency.
This is with a 10t pinion. I've also tried 11t - results in quite a bit more punch, but the 120A ESC overheats too easily. Well, a 160A YGE ESC is in the mail.
Old Jan 03, 2013, 03:07 PM
like a rock!
Finland
Joined Oct 2007
BTW the slots in the picture are a little off. If in doubt, use the original shaft for reference, align at the groove for the clip.
PS those large electric motors make me want to go back to nitro. Changing rear bearings on a .91? That's fun
Old Jan 03, 2013, 03:18 PM
Dejavu*Xion is offline
Find More Posts by Dejavu*Xion
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
Nice flying gravitykills. Was that a polar bear i saw in the background.
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old Jan 03, 2013, 03:40 PM
like a rock!
Finland
Joined Oct 2007
Thanks I think it's an albino tiger, but maybe I'm wrong ...
Old May 25, 2015, 08:43 AM
like a rock!
Finland
Joined Oct 2007
Update: 2 years later and it still works.
The motor was a good choice - got two of them now. One does a pretty good job on 14 s with a 9 t pinion.
If I ever burn one, I'll have it rewound for 14s to 450 Kv, e.g. using the chart on slowflyworld.de
Wanted Gaui X7 photoship beachflyer Aircraft - Electric - Helis (FS/W) 0 Aug 09, 2012 02:47 PM
Sold Gaui X7 Loaded!!! irishmatt18 Aircraft - Electric - Helis (FS/W) 0 May 29, 2012 08:24 AM
For Sale Quantum outrunner brushless heli motor(4530- 500kv ) HeliPro5 Aircraft - Electric - Helis (FS/W) 0 May 28, 2012 10:48 PM
Gallery GAUI X7 low-headspeed setup (video) gravityKills Large Electric Helis 1 Apr 13, 2012 02:37 PM
NEW (never opened) GAUI X7 super combo scirocco2.0 Aircraft - General - Miscellaneous (FS/W) 1 Mar 23, 2012 05:37 AM
