Old Jun 24, 2015, 09:07 AM
ignacioprodentis is offline
Find More Posts by ignacioprodentis
Spain, AL, Málaga
Joined Oct 2011
Estrenando un motovelero (2 min 18 sec)
Hi again and thanks a lot to Thomas, Peter and Ask21 !
I flew the bird twice. First the CG was 65 from leading edge . Second flight at 70.
On landing aproach , flaps deflection is about 15 degrees. At about 1 meter altitud I deployed to 80 degrees.
During take off I use no flaps.
If so kind of you watch the video and give your opinion.
Thanks, thanks and thanks a lot.
ignacioprodentis is offline Find More Posts by ignacioprodentis
Old Jun 24, 2015, 11:52 AM
Ricardo RW is offline
Find More Posts by Ricardo RW
.: Looking for Thermals :.
Ricardo RW's Avatar
Chile, Quinta Región de Valparaíso, Los Andes
Joined Jun 2002
Originally Posted by ignacioprodentis View Post
https://youtu.be/iunv2S9F0zc
Did you program flap to elevator comp.? Seems on landing that when deploying flaps she drops the nose.
Get her high and deploy flaps, watch her attitude and compensate with elevator trying to maintain level flight.
I would suggest you to try full trailing edge camber and reflex settings for better performance at different speeds.
Good luck!
Ricardo RW is offline Find More Posts by Ricardo RW
Old Jun 24, 2015, 11:56 AM
Martin Y is offline
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Nice flight. IMO you need a little expo in the elevator. What is the full battery installed weight?
Martin Y is offline Find More Posts by Martin Y
Old Jun 24, 2015, 03:31 PM
Spain, AL, Málaga
Joined Oct 2011
Good luck!
What is " full trailing edge camber and reflex settings". Please, could you explain it for me ? Thanks
Old Jun 24, 2015, 05:44 PM
TomTerrific is online now
Find More Posts by TomTerrific
United States, CT, Waterford
Joined Jul 2012
This is the new (11/2014) 4m Duo Discuss... Not the DG808s. So, CG will not be the same as on the DG808s. Ask FyFly for the instruction manual with the correct cg.
Plenty of power with your setup. I usually use about 1/3 to 1/2 flaps on final landing approach... And increase or decrease to better control and slow glide path.
TomTerrific is online now Find More Posts by TomTerrific
4 meter Duo Discus install and fly Jeff Meyers Scale Sailplanes 51 Dec 26, 2009 09:45 PM
Discussion 4 good places to fly going to waste.... 1987tc USA - District VI 3 May 21, 2007 10:33 AM
New P-82 Twin Ready To Fly Twin 4 Strokes comtech001 Aircraft - Fuel - Airplanes (FS/W) 7 Jan 14, 2005 10:37 PM
should you fly inverted 4' off the deck and hit your photographer ? Goleith Parkflyers 0 Nov 04, 2003 08:09 PM
Pics from Grand Haven MI fun fly going on now rojoyinc Electric Heli Talk 1 Apr 14, 2002 04:43 PM
