Old Feb 18, 2015, 08:27 PM
pankajbhaban is offline
Find More Posts by pankajbhaban
Joined Feb 2015
my 2nd scratch built
Hi i am new to scratch building i did 1st airplane did take off vertically but never running takeoff.
Anyways now i built new one please see pictures of it and let me know if the dynamics or the way i built is ok with aero-dynamics?
1. Wing Span 1500 mm
2. Fuselage 900 mm
3. 1500 KV motor with 7'4 prop
4. 25A ESC
Battery 2200 mAH 11.1V (i use same all over as having one only lol)
pankajbhaban is offline Find More Posts by pankajbhaban
Old Feb 18, 2015, 09:01 PM
balsa or carbon is offline
Find More Posts by balsa or carbon
Hot glue held together by foam
United States, WA, Vancouver
Joined Aug 2010
Does it fly well ?
balsa or carbon is offline Find More Posts by balsa or carbon
Old Feb 18, 2015, 10:20 PM
Joined Feb 2015
haven't yet tried
Old Feb 18, 2015, 11:40 PM
Joined Aug 2010
That will be the real test of the aerodynamics being in order .
Old Feb 19, 2015, 05:03 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Assuming the model is using just rudder, not aileron, (I could not see any ailerons), the wing will need some dihedral, or you may find it either doesn't turn or is extreemly difficult to turn.
It's great that people are willing to have a go at designing and building their own models, but it is a good idea to base them on know working designs. That includes things like any incidence angles, any dihedral angle, and any motor thrust angle, balance point, (CG), - all can be important fora successful first flight.
eflightray is offline Find More Posts by eflightray
Old Feb 19, 2015, 08:14 AM
nuteman is offline
Find More Posts by nuteman
Joined Apr 2013
The primary problem on your first build was too high wing loading (several of us agreed on that).
So what's the wing loading on this one?
What's the chord? (you gave span but not chord).
What are the dimensions of the tail surfaces?
Do you have ailerons?
Do you have a spar in the wing?
Finally, as others have mentioned, starting with a "known good" design and then tweaking it is a lot better for a new builder. Fly it before tweaking so that you can know what effect your changes had.
nuteman is offline Find More Posts by nuteman
Discussion Planing my first Scratch built Tricopter intermision Scratchbuilt Multirotors 13 Mar 04, 2015 08:46 PM
Discussion Making junk fly - my scratch built cam gimbal TheNiceGuy Aerial Photography 0 Jan 24, 2015 02:39 PM
Build Log 2nd Scratch built plane ever! nickwasp Foamies (Scratchbuilt) 0 Feb 27, 2012 03:14 AM
Video Cozy MK IV Foam scratch-built 2nd Video Steven Wong Electric Plane Talk 9 Mar 06, 2006 10:50 AM
