Old Jul 16, 2012, 09:24 AM
phillipb is offline
Find More Posts by phillipb
United States, FL, Fort Myers Beach
Joined May 2012
Help!
Need bearings for Scorpion BL 400 w - KV 1050 3mm shaft GM410 as supplied in the G
I need 4 sets of bearings (or to know size) for Scorpion BL 400 w - KV 1050 3mm shaft GM410 as supplied in the Guai 330xs Quad copter. Or I need the bearing size. I contacted Daniel at gobrushless.com but he needs to know the size of the bearings.
Thank You
Phillip in Fort Myers Beach, FL
phillipb is offline Find More Posts by phillipb
Old Jul 16, 2012, 09:31 AM
TS00 is offline
Find More Posts by TS00
Ape-pilot Extraordinaire
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
I had some of these a while back, and gave up on them - the bearings are a very tight fit, and a bit of a pig to replace.
Swapped them out for these:
http://www.hobbyking.com/hobbyking/s...dProduct=18967
Good results with 2S, but the GAUI 10A ESCs get a little warm on 3S.
TS00 is offline Find More Posts by TS00
Old Jul 16, 2012, 07:31 PM
phillipb is offline
Joined May 2012
Bearing size is 7mm od 2mm id 3mm thick
available gobrushless.com or innov8tivedesigns.com/
Sold Master Drill Dremel Adjustable Speed w/ Flex Shaft Metal 6k-32k Speed Same as DREMEL iPearl Non R/C Items (FS/W) 0 Jul 09, 2012 08:22 PM
Sold BL 15 df & Eflite 3200 kv motor , whill sell as one ore seperate gregka Aircraft - Electric - Jets (FS/W) 6 May 02, 2012 08:12 PM
Sold Eflite BL 15 fan & Eflite 3200 kv motor ,Will sell seperatly or as one gregka Aircraft - Electric - Power Systems (FS/W) 1 May 02, 2012 06:53 PM
Help! Need to build-up a motor shaft from 3mm to 4mm dmccalmon The Builders Workshop 38 Mar 09, 2012 03:05 AM
Sold Gaui Scorpion GM410 1050 Kv motors jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Feb 26, 2012 11:38 PM
