Old Oct 20, 2014, 08:04 PM
RobertTHaas
RobertTHaas's Avatar
Joined Dec 2004
Build Log
50 inch dlg concept. Cnc pink foam cores.
Here is a DLG I have been working on.
Robert
RobertTHaas is online now Find More Posts by RobertTHaas
Old Oct 20, 2014, 08:45 PM
RobertTHaas
Joined Dec 2004
The next set of wings I bag will be done in 1k carbon. I'll wet-sand them to a nice flat hand sanded finish. The elevator and rudder will also be bagged. I think I will use 1k on them as well. They will all be sanded in 45 degree strokes until the weight is where it needs to be. The plug I machined in the picture will be used for these first prototypes. I have to redo a new mold using tooling board. MDF just isnt my thing. But sure is cheaper then 300-500 dollars for a block of tooling board. Anyone know a more affordable place to buy tooling board. Something where I can machine it directly to mold?
Old Oct 20, 2014, 10:05 PM
G_T
Joined Apr 2009
Sanding carbon in that fashion will result in parts that are much weaker than you might hope. Carbon filaments are very thin. They are either continuous, or they are not... You might be better off just using a lighter fabric of some sort - particularly on the tails.
Gerald
G_T is offline Find More Posts by G_T
Old Oct 20, 2014, 10:19 PM
RobertTHaas
Joined Dec 2004
Yeah, I may have to do that. The carbon will have to be carefully sanded.. I mean, I count the number of passes.. enough to get rid of the shine from the mylars.. a fine sanded surface keeps flow attached better then a slick surface. There is a suggested grit for that effect.. ill have to look it up..
Old Oct 20, 2014, 10:21 PM
RobertTHaas
Joined Dec 2004
Can anyone suggest a source for Corian? I imagine it machines very nice..
Old Oct 20, 2014, 10:29 PM
Thermaln2's Avatar
Reno Nevada
Joined Oct 2007
Tom Siler once mentioned he visited a local countertop making shop for Corian. They had pieces of size that could not be used for other requirements. I imagine larger pieces may require an order at the local Home Depot type place.
Thermaln2 is offline Find More Posts by Thermaln2
Old Oct 20, 2014, 11:44 PM
let's FLY!
JimZinVT's Avatar
United States, VT, Castleton
Joined Dec 2007
Could you wet sand the mylars in the area you want non-glossy? (aft 75% of top surface?)
How did your flying wing DLG project turn out?
JimZinVT is offline Find More Posts by JimZinVT
Old Oct 22, 2014, 12:30 AM
RobertTHaas
Joined Dec 2004
NEW POD update
Pod has been updated to fit the alegro tail-boom from goodwinds.com or https://goodwinds.com/22202.html The mold is currently being machined.
Old Oct 22, 2014, 12:52 AM
RobertTHaas
Joined Dec 2004
possible winglets
I will be experimenting with winglets of this nature..
Old Oct 22, 2014, 02:34 AM
No slope for richardo
Endless Sloper's Avatar
Seattle, WA
Joined Jun 2005
I like the tips, look like the old FW planes (will double as launch pegs?). Looking forward to following the build Robert.
Endless Sloper is offline Find More Posts by Endless Sloper
Old Oct 22, 2014, 01:26 PM
RobertTHaas
Joined Dec 2004
Yes the wing tips are completely inspired by the fireworks DLG's. I have used my 3d printer to print up some. Im going to try printing up a few different ones till I get the feel just right and see if I can turn them into plugs to make molds with. If they don't work as plugs Ill machine a mold based on the print I like the best. Id like to make the wing tips, so that they will slip onto the wing after it has been bagged and cleaned up, then epoxied in place. That will also give more strength to the thin wing tips..
Old Oct 22, 2014, 01:41 PM
RobertTHaas
Joined Dec 2004
I redesigned the pod to use the alegro tail-boom for now because the creation of a custom tail-boom will need some more time and experimentation for me. I plan to create a clean end cap that will streamline the alegro tail-boom where it meets the rudder. The alegro tail-boom will be cut down from its original quite a bit.
Old Oct 22, 2014, 03:06 PM
RobertTHaas
Joined Dec 2004
Updated Pics
Designed the elevator mount, and the tail-boom to rudder transition mount.
Old Oct 22, 2014, 04:34 PM
jbarnhardt's Avatar
United States, WA, Seattle
Joined May 2011
Great lines, Robert - I quite like the look of this plane. The HT mount seems like it's quite "tall" though - do you need the HT to be that far away from the boom? Nice CAD work.
-John
jbarnhardt is offline Find More Posts by jbarnhardt
Latest blog entry: Latest creation...
Old Oct 22, 2014, 05:54 PM
RobertTHaas
Joined Dec 2004
Yes I agree. I will shorten that to the minimal distance necessary..
Build Log ~50 inch foam board wing. Asulenver Flying Wings 7 Oct 22, 2014 12:17 AM
For Sale Speedo cores pink foam steeg Aircraft - Sailplanes (FS/W) 4 Jun 15, 2014 10:44 PM
Idea CNC Foam Core Tailless Flying Wing DLG SAL Design.. RobertTHaas Hand Launch 41 Dec 22, 2012 09:30 AM
For Sale CNC DLG foam cut wing cores for sale, with Drela Airfoils RobertTHaas Aircraft - Sailplanes (FS/W) 9 Dec 30, 2008 12:48 PM
Discussion CNC Foam Cores for My DLG yanivlevi Hand Launch 2 Mar 28, 2008 08:19 AM
