Old Dec 09, 2009, 05:32 PM
RCPlaye
United States, CT, East Hartford
Joined Aug 2009
Alert
What does acro mean?
I would also like to know what heli-90, heli-120, and
what heli-140 mean.
CoolBudz is offline Find More Posts by CoolBudz
Old Dec 09, 2009, 05:35 PM
ekotil's Avatar
Athens, Texas, United States
Joined Jul 2004
what heli-140 mean.
Acro refers to a plane being aerobatic and 90,120, and 140 are power size references.
ekotil is offline Find More Posts by ekotil
Old Dec 09, 2009, 05:37 PM
RCPlaye
Joined Aug 2009
Does that also mean that it has no mixing.
Old Dec 09, 2009, 05:39 PM
May the Farce be with you...
refugeefromcalif's Avatar
Duncanville, Alabama. USA
Joined Dec 2006
what heli-140 mean.
If your reading this off of a TX, (I have the DX7 Heli version).
Acro is for Airplane.
The others are "Swash plate Degree" setups/configurations on heli's.
George
refugeefromcalif is offline Find More Posts by refugeefromcalif
Old Dec 09, 2009, 05:47 PM
RCPlaye
Joined Aug 2009
George
Oh thanks but I really need to know if a tx is set to
acro mode that it means the mixing will be turned off
Old Dec 09, 2009, 06:04 PM
Scott Stoops
sukhoi26mx's Avatar
United States, CO, Longmont
Joined Mar 2002
Acro in a transmitter generally means airplane. No mixes will be active unless you turn them on.
Scott
sukhoi26mx is offline Find More Posts by sukhoi26mx
Old Dec 09, 2009, 06:21 PM
M Carr's Avatar
Eastern, NC
Joined Dec 2007
what heli-140 mean.
I beleive the heli settings you are asking about refers to the position of the servos around the swash plate. Most helis of today are 3 servos at 120 degrees apart.
M Carr is offline Find More Posts by M Carr
Old Dec 09, 2009, 06:26 PM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
dang, way to pick up that it was Tx settings, I would have just gone straight to pwning that newbie
theKM is offline Find More Posts by theKM
Old Dec 09, 2009, 06:31 PM
M Carr's Avatar
Eastern, NC
Joined Dec 2007
Old Dec 09, 2009, 06:46 PM
WARNING: May contain spam
Xpress..'s Avatar
Joined Oct 2007
Yep, ACRO referts to fixed wing aircraft, or planes. HELI-90/120/140 refers to a helicopter, with the servos orientated at 90 degrees (2 servos, generally beginner helicopters with forward, back, right, and left movement on the cyclic stick), 120 degrees (3 servos- generally for more advanced helicopters that have collective pitch controls on the rotor blades (yes, this means inverted flight too)), and haven;t heard of 140 degrees before, but I'm sure it refers to essentially the same thing as 120 degree orientation
Xpress.. is offline Find More Posts by Xpress..
Old Dec 09, 2009, 06:57 PM
M Carr's Avatar
Eastern, NC
Joined Dec 2007
X9303 manual states:
The Swashplate options are:
1 Servo Non-CCPM, standard mixing type
2 Servo/180 CCPM
3 Servo/120 CCPM (JR style, most popular)
3 Servo/140 CCPM (JR Vigor CS, JR Vibe 90)
3 Servo/90 CCPM
4 Servo/90 CCPM
Just thought I would throw it out there, I had to look up 140 too, never heard of it either until now
Old Dec 09, 2009, 06:59 PM
RCPlaye
Joined Aug 2009
thanks for all.
so that means that if i put this programmable tx in
acro mode then it will turn off its mixing?
http://www.hobbycity.com/hobbycity/s..._&_Rx_(Mode_2)
Old Dec 09, 2009, 07:14 PM
M Carr's Avatar
Eastern, NC
Joined Dec 2007
thanks for all.
Ummm, I dont think that transmitter has much mixing capabilities anyways. I would be afraid to use that thing. Especially if you have an airframe of any value.
Old Dec 09, 2009, 07:45 PM
Scott Stoops
sukhoi26mx's Avatar
Joined Mar 2002
Yup... good work M Carr.
Old Dec 09, 2009, 08:40 PM
Xpress..'s Avatar
Joined Oct 2007
thanks for all.
Yes, you should be using ACRO for aircraft, and HELI for helicopters.
Question What does it mean, 3 sec run, verry hot. pletang Hacker Brushless 9 Oct 03, 2009 05:40 PM
Question ITC Charger - What does flashing charge light mean? demisemiquaver Micro Ready-to-Fly 3 Sep 29, 2009 10:59 PM
Help! What does the beeps mean smurf Power Systems 10 Sep 12, 2009 11:15 AM
Discussion What does "sport plane mean" and a scratchbuilt corsair body v-tail high winger GreenAce92 Foamies (Scratchbuilt) 13 Aug 30, 2009 06:09 PM
