Old Feb 21, 2012, 08:19 PM
Transplant in 1996
United States, NE, Scribner
Joined Aug 2011
Help!
OS Max .40 rc
I have boiled (anti-freeze/crockpot method) for 1 1/2 days. Have everything apart, EXCEPT the wrist pin/piston.
Please someone out there with lots more experience (than me), tell me how to get it out. I have tried a SMALL easy-out, but no luck so far.
I want to take piston out and replave the ring, But I'm not smart enough, engine has done me in!
Transplant92 is offline Find More Posts by Transplant92
Old Feb 21, 2012, 10:55 PM
Rocky Mountain High and Higher
PROACE's Avatar
Joined Jan 2002
Try heating the piston with a small torch but dont melt it! and the pin should press out easy with a drift punch of the correct diameter. remove the teflon buttons first if the engine has them.
PROACE is offline Find More Posts by PROACE
Old Feb 22, 2012, 02:55 AM
Joined Jun 2011
You can't just press it out. It has to be removed from the hole in the case. The plastic buffer needs to be removed and the pin pulled out, I use a pin or a piece of hardened music wire with a small hook on the and slowly work it back and force until it slides out. Heat will help. A small ez out should work too.
datsunguy is offline Find More Posts by datsunguy
Old Feb 22, 2012, 10:17 AM
Transplant in 1996
Joined Aug 2011
Thank you!
I will try with the little hook, then maybe I can get it out of the crancase.
Then I should be able to push it out.
Old Feb 22, 2012, 02:57 PM
Sverige, Jönköpings Län, Aneby
Joined Aug 2005
Isen´t there a G-clip at the end of the wristpin? Depends on the model, but it could be...
Guzzten is offline Find More Posts by Guzzten
Old Feb 22, 2012, 04:16 PM
Transplant in 1996
Joined Aug 2011
Sorry, Iv'e never heard of a G-clip, all you can see of the wrist pin is through the little hole on back side of crankcase.
10 minutes later: went looking for G-clip, still did not find it. But I giess this was not there, tried with easyout again. The wrist pin came out.
Thank you all for all the info, I guess I need to boil again, it's nasty looking now that I can see the piston and both rings.
Old Feb 22, 2012, 04:31 PM
Joined Jun 2011
There is no "G-clip"_ or c-clip on the OS 40R/C..The little nylon buffer things keep the wrist pin from rubbing on the cylinder.
Old Feb 22, 2012, 04:47 PM
Transplant in 1996
Joined Aug 2011
The little nylon buffer things may have boiled away, if I can't find any? is this engine worth rebuilding???
Old Feb 22, 2012, 06:53 PM
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
the little teflon thingies won't melt away with boiling water.If they'll stand upper cylinder heat,they'll thrive in hot water.
We can't see the engine to say if it's rebuildable...look for scratches in the cylinder wall near the exhaust,and scores in the piston sidewalls.Is the ring stuck in the piston?
If you need to replace all those parts,it's prolly just as cheap to get a new one.
epoxyearl is offline Find More Posts by epoxyearl
Latest blog entry: Wheeling and dealing..
Old Feb 22, 2012, 09:32 PM
DL8698's Avatar
Singapore
Joined Mar 2008
They are probably made of teflon. You can use small brass tacks with the heads trimmed down to replace lost or broken pads.
DL8698 is offline Find More Posts by DL8698
Old Feb 22, 2012, 09:38 PM
Transplant in 1996
Joined Aug 2011
Rings are not stuck (antifreeze boilng helps that). There are NO scuffs on sleeve or anywhere else inside cylinder. I guess I got lucky.
Old Feb 23, 2012, 11:16 AM
Reginald's Avatar
Belgium
Joined Aug 2004
Using an appropriately sized small round file can sometimes do the trick, you insert it until it grips and you then try to pull out the wristpin, carefully not moving sideways or it will break off, this has worked for me quite often
Reginald is offline Find More Posts by Reginald
Old Feb 23, 2012, 10:37 PM
semperfi1970's Avatar
Joined Feb 2012
I am new to this forum or forums in general but have been in the rc hobby for 30 plus years and have never seen the boiling in antifreez thing. I just soak my engines in old glow fuel for a few days and they come out all unstuck and freed up. I have bought many a engine that folks thought were junk because they were seezed up from sitting for years.
semperfi1970 is offline Find More Posts by semperfi1970
Old Feb 25, 2012, 01:40 AM
Joined Jun 2011
It may not have the nylon buffers. The wrist pin may have bronze ends that serve the same purpose
Old Feb 25, 2012, 05:09 PM
Transplant in 1996
Joined Aug 2011
They were bronze, I got it apart and now have it flying, The antifreeze method is what I was told to do. I tried the glow fuel soaking, it worked but the antifreeze cleans it like brand new aluminum. And it's a little faster.
For Sale Rc os max 40 nitro engine master airscrew prop fuel tank & glow plug igniter t.korb Aircraft - Fuel - Engines and Accessories (FS/W) 2 Feb 22, 2012 01:46 PM
For Sale OS Max .40 LA RC & CL venturi w/muffler HD Hucker Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 22, 2012 01:38 PM
Wanted WANTED: OS Max-H 40 rc motor mount northern pointer Aircraft - Fuel - Engines and Accessories (FS/W) 6 Apr 21, 2011 07:44 PM
Discussion motor mount for OS Max-H 40 rc northern pointer Hot Online Deals 1 Apr 19, 2011 11:10 PM
For Sale OS MAX 40 SF and OS MAX 40 FP Local only Jessdog Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jul 16, 2009 02:13 AM
