Old Apr 13, 2015, 12:37 AM
MaikelHoeky is offline
Find More Posts by MaikelHoeky
Foamies rules
Netherlands, NH, Heemskerk
Joined Feb 2014
Best easy battle foamies for club battle
Hello everyone,
Were looking for a nice coupple of plane's to have a club battle.
We'll problably start with streamer battle and end in full carnige.
We would like some different but similar sized planes. Pusher or mid mounted to protect the prop.
Just wanted to get some expertise from you guy's.
I like the F-22 and already a saw some nice design's.
Most likely ill cut the FunBat or bloody wonder as well but dont know if these are asked for with the prop in front.
Il be cutting these for the club at cost price with my PlahtPrinter CNC.
Already selling alot of kits to my club members from SEMFF and others i did send a PM to these guy's stating that i wanted to sell them with only very low profit but no one responds, i never change the name or pretend its my design all links to the plans are given when asked for.
Thanx in advance,
Maikel
Netherlands
MaikelHoeky is offline Find More Posts by MaikelHoeky
Old Apr 13, 2015, 02:07 AM
balsa or carbon is offline
Find More Posts by balsa or carbon
Hot glue held together by foam
United States, WA, Vancouver
Joined Aug 2010
Probably the easiest plane to make that will work well for combat is the Simplest Simple Delta , a VERY agile flyer !
http://www.rcgroups.com/forums/showthread.php?t=2145562
Here is the original
Simplest simple delta (1 min 20 sec)
Here is one made recently by Marblekit
Red Dragon "On Steroids" (2 min 19 sec)
balsa or carbon is offline Find More Posts by balsa or carbon
Old Apr 13, 2015, 09:46 AM
springer is offline
Find More Posts by springer
treefinder
springer's Avatar
SE MI
Maikel: Send a PM to Ken (dz1sfb) Most of the SEMFF planes we have used for our streamer combat are his designs. He shares the plans freely, and will give guidance on your recutting them to "sell".
We use the F&F, Ken's Stingray, and various other planes, about the only criteria is we try for same 24 gram 1700kv Blue Wonder motor (or close to gram weight and Kv), similar wing area, mostly 2s 850-950mah packs( although a few 3s packs slip in from time to time). Tough to be too structured when there are no rules!
Since it's all in fun, we fly all planes til they hit LVC, for max fun, so even after one's streamer is cut they keep flying. We just try to keep track of our cuts. Keeping more planes in the air makes for more fun, (and usually more carnage).
springer is offline Find More Posts by springer
Latest blog entry: even more indoor stuff!
Old Apr 13, 2015, 12:17 PM
Foamies rules
Joined Feb 2014
Originally Posted by springer View Post
Maikel: Send a PM to Ken (dz1sfb) Most of the SEMFF planes we have used for our streamer combat are his designs. He shares the plans freely, and will give guidance on your recutting them to "sell".).
I already did a while ago without any answer. Hopefully he will respond sometime.
Like stated i am only selling them for the hobby not to make profit.
His planes fly awsome. built the Mig-3, Vampire, Mustang, Spitfire and they all fly awesome.
Thanks for the suggestions so far i will look into them.
Old Apr 13, 2015, 01:30 PM
boaterguy is online now
Find More Posts by boaterguy
Thermite + ice = Big boom.
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
I've built two of these deltas, they have a 20" span, 15" root 4" tip chord. Motor about 7" from the tail, elevons 1.5 to 2".
The KF section (top and bottom) is exactly 50% chord all the way across.
Leave the paper on the main wing and remove it from the kf sections or remove it all and use a spar. Vertical stabilizer is TLAR, about a 5" by 5" triangle.
This one is running a hobbyking donkey 2204 with a gemfan 8*4 cut down to 6", 1000mAh 3S.
The roll rates are pretty crazy and could use some expo, but it's a blast to fly and quite stable in pitch. Glide ratio leaves much to be desired, likely because of the high reflex on the elevons (maybe a bigger tail). Slam them into the dirt all the time and a little hot glue gets them back up and flying again.
I can draw up some plans if you want but with those dimensions it shouldn't be too hard.
boaterguy is online now Find More Posts by boaterguy
Old Apr 13, 2015, 01:47 PM
Joined Aug 2010
Looks exactly like the SSD in post #2
Old Apr 13, 2015, 01:58 PM
Azarr is offline
Find More Posts by Azarr
Old age is not for sissies
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Leadfeather's Firefly is hard to beat for combat. Free plans, EPP bounces well, mid motored for prop protection and built around the blue (silver) wonder. Fancyfoam.com offers inexpensive kits if you get tired of cutting them.
Azarr
Azarr is offline Find More Posts by Azarr
Old Apr 14, 2015, 01:06 AM
Foamies rules
Joined Feb 2014
Thnks Azarr,
Does look like a well desinged delta.
EPP is very hard to come by in the netherlands. And whats available is expencive with high shipping cost. Usaly imported from germany.
I will be cutting these on my cnc router so i never get tired of cutting .
Just have to press play and go drink coffy.
I would also like some jets but will discuss this on the club.
Maybe a scaled down version of the FT versa wing.
Old Apr 14, 2015, 01:32 AM
ozmo01 is offline
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
+ 1 on the versa wing. Our club did a pair of group build get togethers and they like the Versa wing quite well. 2 sheets of handi board or about 2 dollars gets the wing made. Cheap fast and flies well.
http://www.stonekap.net/ftplans/FT-V...ILED-PLANS.pdf
ozmo01 is offline Find More Posts by ozmo01
Old Apr 14, 2015, 04:38 AM
Azarr is offline
Azarr's Avatar
Joined Jan 2000
Originally Posted by MaikelHoeky View Post
Thnks Azarr,
You should consider adding your location in your profile, (it will then appear under your name) it makes it much easier to provide answers if we know where people are located.
Azarr
Old Apr 14, 2015, 10:11 AM
Foamies rules
Joined Feb 2014
Updated my location and profile a bit.
If anyone knows cheap EPP around the netherlands i will be happy to hear it.
Thanks do far for your contributions.
Will start desinging a small Versa wing or mini swift clone one of these day's.
Off course i will share the plans once it flies well.
Old Apr 15, 2015, 12:21 AM
Jürgen Be is online now
Find More Posts by Jürgen Be
Jürgen Be's Avatar
near Stuttgart, Germany
Joined Oct 2008
Maikel,
how about a "Skunky"? Offcourse it`s also designed for an EPP build, but it can also be built from Depron with no problems.
Here`s a video:
FMT 10/2014 - Skunky - Kostenloser Downloadplan (3 min 1 sec)
Free downloadplans are available from the German FMT-Magazine:
https://www.vth.de/flugmodell-und-te...wnload-skunky/
And if you can read any German, like many people from the Netherlands do, there`s a buldlog atrcline-Forums:
http://www.rclineforum.de/forum/boar...75-epp-skunky/
Jürgen
Jürgen Be is online now Find More Posts by Jürgen Be
Old Apr 15, 2015, 12:32 AM
Jürgen Be's Avatar
Joined Oct 2008
Another idea are Eddi / Otto , also built from 6mm Depron and designed for fun Combat:
http://www.rcgroups.com/forums/showthread.php?t=2376322
Modell AVIATOR: Downloadplanmodelle Eddie und Otto (2 min 57 sec)
Old Apr 15, 2015, 05:52 AM
Mac50L is online now
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
Dart-XS? The one time we tried it we were both using 19 gram motors, 2C or 3C, not much difference. 3 Ch though even with ailerons (4 Ch) it doesn't make much difference.
Prop? Always use a prop saver. Admittedly doesn't always help in a vertical crash but should help (prop at the front) for streamer cutting.
Mac50L is online now Find More Posts by Mac50L
Old Apr 15, 2015, 10:20 AM
Foamies rules
Joined Feb 2014
Those are some great ones indeed.
Mac50L. Damn your right didn't think of the need to have the prop in front for the steamer cutting.
Kinda handy when we're planning a streamer battle.
Dont think it a good idea to put razor blades on the LE
Everyone needs to wear armour to protect themselfs from the airplanes.
Maybe multiple builds. Mid mounted props for head on battle.
Front prop for the streamer battle. FunBat
Question Best readi-board foamie for a total newbie? Cheezey Foamies (Scratchbuilt) 11 Apr 01, 2015 08:10 PM
Rave 100 + mph Scratchbuilt Foamies Club dz1sfb Foamies (Scratchbuilt) 11 Feb 12, 2015 05:27 AM
Discussion Best Cutting Surface for Scratchbuilding Foamies sstephenson Foamies (Scratchbuilt) 12 Jan 28, 2015 02:01 PM
Help! Best scale for new club TOHrcAUTO Car Talk 8 Jan 07, 2015 11:52 PM
Discussion Clubs for RC Boat Battles Analytica Dock Talk 0 Aug 26, 2013 01:20 PM
