Old Dec 18, 2014, 10:03 PM
buildcrashrepair is offline
Find More Posts by buildcrashrepair
TEAM HILLBILLY
buildcrashrepair's Avatar
United States, KS, Leawood
Joined Jul 2013
Build Log
MXY-7 Ohka
I am starting on the build of my semi-profile MXY-7 Ohka Mod 11 Japanese suicide rocket plane.
I plane on having the wingspan around 21 inches when finished. I will be using a simple KF airfoil with a little bit of a taper toward the tip. The material of choice is just your standard DTFB but for the fuselage I will be removing the paper and laminating 6 pieces of DTFB with epoxy and then fiber-glassing them. The wing position isn't yet decided because they are so far forward that I worry that I will have to put to much weight up front and that would make the wing loading crazy. Total build cost should be around $20 which is very good!
Paint Scheme:
For the paint scheme I will be going for is just a semi-gloss white air-frame with the red circles for the Japanese markings.
Power-plant:
Undecided. I set it up as an edf, a pusher prop or a tractor depending on the the where I end of putting the wings. I may even end up going crazy and using an F size rocket motor.
Electronics:
Receiver:
Going to be using either an FRSky VD5M or a V8FR-II (a little overkill)
Servos:
3 9 gram servos. 2 for the wings and an elevator as there is no need for a
rudder on this small of an airplane
Will update the build process once I get further work done.
Have fun in the clouds,
Rob
buildcrashrepair is offline Find More Posts by buildcrashrepair
Old Dec 19, 2014, 02:56 PM
turbonut is offline
Find More Posts by turbonut
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
Fun!
Old Dec 19, 2014, 04:57 PM
TEAM HILLBILLY
Joined Jul 2013
Build Update
Just got the fuse laid up and I have to say that I am very happy with how the foam/fiberglass went into place. I decided to use a single layer of 3 oz. cloth (I think) in the middle of 6 layers of foam just to add some extra support as I am not sure how the foam will hold up to the speed. I just used the norm for the epoxy: 50/50 on the finishing resin and denatured alcohol. Just used some ammo for my that I had lying around to put some top weight on it. (It's redneck-ville in my shop )
And as I am typing this I just remembered that I will be fiberglassing the fuse once I get the done so I think I may have gone a little bit over kill with the 3 oz. cloth in the middle may have been overkill.
(I think I might have a fiberglass obsession...I have to say that it ain't a bad one, as my R/C addiction is worse )
Old Dec 19, 2014, 07:31 PM
stingray23U is offline
Find More Posts by stingray23U
TEAM HILLBILLY
United States, KS, Overland Park
Joined Dec 2014
How will the wings, tail, and motor be mounted?
stingray23U is offline Find More Posts by stingray23U
Old Dec 19, 2014, 07:42 PM
TEAM HILLBILLY
Joined Jul 2013
For the wings I am planning to laser cut a v-shaped lite ply former as a wing spar and the I will most likely be fiberglassing the wing. The motor will be also mounted with a laser cut former and then fiberglassed over it. The tail surfaces will just be epoxied onto the rear deck of the plane and then fiberglassed on to get a good hold.
(fiberglass 3 times in one paragraph...the addiction is real)
Old Dec 20, 2014, 09:23 AM
Skunkwork is online now
Find More Posts by Skunkwork
Land of confusion
Skunkwork's Avatar
Norway, Oppland, Vestre Toten
Joined Feb 2014
Why not make the piston driven Ohka jet version with an edf engine?? I would make the wings slighty bigger than scale if I were making this one and maybe a little bigger.
Skunkwork is online now Find More Posts by Skunkwork
Old Dec 20, 2014, 02:29 PM
TEAM HILLBILLY
Joined Jul 2013
I think I am now sold on that one! I believe that it was the Mod 22 that had the engine. I tjink that I will have to raise the back a little bit but that shouldn't be to hard. The only problem that I see is getting the intake big enough but since it is going to be a semi-profile I think that I can cover the 64mm edf unit with with the intakes so the airflow would be at a maximum.
Edit:
Skunk, I do think that I made the wings a little but bigger at the cord and also a little bit longer to give a larger surface area as I had the same concern as you.
Old Dec 20, 2014, 02:37 PM
Land of confusion
Skunkwork's Avatar
Joined Feb 2014
How about something like this one with longer wings and more flyable?? You could do something about the intakes, maybe a lttle bigger.
Old Dec 20, 2014, 06:05 PM
Land of confusion
Skunkwork's Avatar
Joined Feb 2014
Check out this one, really like Kato the screaming pilot in it.
Ohka (1 min 57 sec)
Old Dec 21, 2014, 08:45 AM
TEAM HILLBILLY
Joined Jul 2013
I think what I am going to do is build a full fuse Model 22 Ohka and keep the semi-profile Model 11 Ohka as a rocket. The only thing that I do not know how to do is take a 3 view into cross-cut sections.
Old Dec 21, 2014, 09:39 AM
Land of confusion
Skunkwork's Avatar
Joined Feb 2014
Thats where the cad experts could contribute, althoug this planes round fusalage should do the job a lot easier.
Old Dec 21, 2014, 05:25 PM
Land of confusion
Skunkwork's Avatar
Joined Feb 2014
You really got my going now...
Old Dec 21, 2014, 05:28 PM
TEAM HILLBILLY
Joined Jul 2013
Maybe you will have to build one along with me after you finish your F-16XL
Edit: I am really torn between the Mod 22 and Mod 43....I can't decide
Old Dec 21, 2014, 05:49 PM
Land of confusion
Skunkwork's Avatar
Joined Feb 2014
-sure why not. That long span intriqued me. could be made into nice camera platform,
Old Dec 21, 2014, 06:38 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
There is the Steve Bage plan
Small certainly, But easily enlarged .
Reputedly it Flew "fine' Free flight even..
Bare is offline Find More Posts by Bare
Cool NCSA flying cityview 7 7 dvk44039 North Coast Soaring Association 0 Sep 22, 2014 03:54 PM
Build Log SSDC Yokosuka MXY-7 Suicide Rocket RMD72377 Slope 10 Jun 23, 2007 12:55 AM
