Old Feb 24, 2013, 06:20 AM
heliluk is offline
Find More Posts by heliluk
Joined Jun 2011
New Product
3D-printed Microbody
See, and get your own version too!
the new lightweight MICRO 008 is out!
you can get the new improved 1mm MicroBody with two lids included in colors now!
http://www.shapeways.com/shops/Printluk
your comments are appreciated.
You are welcome to also test the 0.7mm updated version!
Video by a satisfied customer
http://www.youtube.com/watch?feature...&v=UgcOCwBURfA
also see some experiments!
heliluk is offline Find More Posts by heliluk
Last edited by heliluk; May 25, 2013 at 09:44 AM. Reason: I try to keep you updated.
Old Feb 24, 2013, 07:13 AM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
very nice design - however, I fear if that gets 3D printed, you will get "weight issues"
Old Feb 24, 2013, 07:35 AM
heliluk is offline
Joined Jun 2011
it has only 9,7 ccm3
wall thickness is 1mm
so if the density of the material is around 0.95g/ccm3 than it should be around 12 gramms for the whole body ..
add board: 2,5g
4motors+props: 17g
battery: 8,5g
all together: 40g ... not too bad i think.
it will take another three weeks, till Iīll have it in my hands though.
by the way: the syma x1 motors are the strongest 7x20 coreless
have: black cap, stiff long wires, the plastic pinion is easy to remove
Old Feb 24, 2013, 05:27 PM
BD Murdock is offline
Find More Posts by BD Murdock
Quad guys are 4x the fun :)
BD Murdock's Avatar
United States, CO, Longmont
Joined Mar 2012
What are the dimensions? I guess size looks similar to the other micros just based on motor holder size. So hollow legs should make wiring easy enough. Stll though 48 grams AUW all said and done is a bit heavy, most 202's that guys have set up for AP are about that or less with the camera and it's own battery attached. Also doesn't look very repair friendly unless it could go back together with CA. Interesting though, I like the idea.
BD Murdock is offline Find More Posts by BD Murdock
Old Feb 25, 2013, 01:03 PM
heliluk is offline
Joined Jun 2011
motor to motor is 87mmx87mm, little bit smaller than the ladybird
density of the material is 0,97g/cm3 so the body with two lids will be about 12g
AUW will be 40g then ...
I am working on a even lighter version now ... think I can save another 4g
Old Feb 28, 2013, 12:13 PM
variantman is offline
Find More Posts by variantman
United States, TN, Knoxville
Joined Jun 2012
I like it. It would look nice as solid white with a clear cover on top.
variantman is offline Find More Posts by variantman
Old Mar 08, 2013, 10:56 PM
heliluk is offline
Joined Jun 2011
it is real!
and it works great!
the second version 0.6mm wallthickness will be even lighter and more rigid...due a better lid-closing- solution!
the lids fall off when hard landings occur. nothing breaks so far, ist is really solid and stiff!
i`ve used standard 7x20 motors, they are sufficient, but get hot after 3 minutes
it all depends on the right motot/ batterx aand Board combination!
it Is up to you to find out the best combination!
Last edited by heliluk; Mar 11, 2013 at 05:22 PM. Reason: it is not brittle but too strong and a little bit too heavy
Old Mar 08, 2013, 11:00 PM
erdnuckel2's Avatar
Joined Mar 2009
do you print the bodies yourself or do you have someone print it for you?
Old Mar 09, 2013, 04:51 AM
heliluk is offline
Joined Jun 2011
you can also have one!
just a click away
http://www.shapeways.com/model/94263...op&material=27
Old Mar 09, 2013, 05:15 AM
Cid156 is offline
Find More Posts by Cid156
Switzerland
Joined Sep 2008
just a click away
28.4g is with or without lipo?
Cid156 is offline Find More Posts by Cid156
Old Mar 09, 2013, 07:07 AM
Oracus is offline
Find More Posts by Oracus
I meant to do that!
Oracus's Avatar
United States, IN, West Terre Haute
Joined Apr 2007
and it works great!
Whats your infill?
Oracus is offline Find More Posts by Oracus
Old Mar 09, 2013, 12:12 PM
heliluk is offline
Joined Jun 2011
the 1mm micro is about 12g for the body with two lids it flies superb with standard (Ladybird/hubsan) motors and a 25C battery.
the 0,6mm newer version will be around 8g only
Old Mar 09, 2013, 12:13 PM
heliluk is offline
Joined Jun 2011
Originally Posted by Oracus View Post
Whats your infill?
infill?
sorry, I donīt understand
Old Mar 09, 2013, 02:01 PM
Joined Jun 2012
Outstanding. This looks like it was designed for Portal by Valve. Or even Apple. Got any flight video? I might have to order one of these.
Old Mar 09, 2013, 04:56 PM
dapple63 is offline
Find More Posts by dapple63
dapple63's Avatar
Joined Jun 2005
I've busted two Hubsan X4 frames now. It is brittle compared to my X1 and V959. So maybe this? Or is it coming out brittle as well?
dapple63 is offline Find More Posts by dapple63
Discussion Do you need something 3D printed. mungral The Builders Workshop 8 Jul 01, 2013 09:19 PM
Discussion Completely 3D printed micro quad frame waterhouse Scratchbuilt Multirotors 4 Mar 12, 2013 02:27 PM
Idea 3D printed Camer Gimbal danielpetrescu Aerial Photography 1 Jan 23, 2013 04:15 PM
Discussion 3D printed quad frame project waterhouse Scratchbuilt Multirotors 3 Jan 22, 2013 05:28 AM
