Old Dec 08, 2014, 05:01 PM
ranger7 is offline
Find More Posts by ranger7
Joined Jan 2011
I got one of these at an auction. It's been a pleasant surprise.
I had just gotten back into R/C after a long layoff. This was my transition to low tapered wing planes, but still had trike gear to ease takeoffs and landings.
I powered it with a 3536-910KV, a 12x6E cut to 10x6, and a 3S 2200. 285 watts. I get over 10 minutes. It isn't quite enough power to do a loop from level flight.
The best thing is the plane has no bad habits. It's a really good choice for someone's 2nd plane.
ranger7 is offline Find More Posts by ranger7
Old Dec 08, 2014, 06:48 PM
Art Baretta is offline
Find More Posts by Art Baretta
Artp47
Canada, AB, Wabamun
Joined Oct 2014
Got a E flight n15in mine could not see flying it with anything less
Art Baretta is offline Find More Posts by Art Baretta
Old Dec 09, 2014, 03:08 PM
TennFlyer is offline
Find More Posts by TennFlyer
Joined Nov 2012
Yes, you need more power for that Leader! The Eflite 480 was better than that. I fly with an Eflite Power10 with 10x7E prop and get complements every time out. Some favorite moves are a stall turn with a full roll on the upline and large loops with full roll at the top. I usually fly the intermediate sequence with loops w/roll, spins, snap rolls and knife edge pass added.
Had a servo fail after 325 flights on the last one, but have a spare in the box!! (won't be using Eflite servos this time - 3 crashes in two different planes this past summer.....)
TennFlyer is offline Find More Posts by TennFlyer
Old Dec 09, 2014, 06:24 PM
ranger7 is offline
Joined Jan 2011
I need to add that I am using this plane as a "trainer" of sorts. I can do most normal aerobatics, but am aware of power constraints. But it is still my "2nd plane", so I am happy with the power choice I made.
So a question: If and when I want to upgrade, should I switch to 4S or a better motor? Or both? I should note I can easily move the battery back to maintain CG.
Old Dec 10, 2014, 10:49 PM
Bluhammer is offline
Find More Posts by Bluhammer
Bay Area Prop Buster
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
A Rimfire .15 on 4S will push this plane to its reasonable limits. It's a blast every time I fly it. There's a video of it a number of posts back.
Bluhammer is offline Find More Posts by Bluhammer
Old Dec 12, 2014, 10:11 AM
Joined Nov 2012
The Eflite Power 10 uses the same bolt pattern as the stock 480, just use smaller spacers. Mine are 5mm (3/16"). My Eflite 40A esc works fine with the P10, but a Hobbwing flyfun 40A gets quite hot....... 2200mAh 3 cell is located all the way back to the servo tray. A small extra weight on the tail and a rudder extension was required for a decent knife edge.
Enjoy that Leader!!
Old Dec 30, 2014, 01:35 PM
Spitfire Flyer is offline
Find More Posts by Spitfire Flyer
Joined Nov 2013
Odd question maybe, but has anyone tried installing retracts on their Leader?
Spitfire Flyer is offline Find More Posts by Spitfire Flyer
Old Dec 30, 2014, 05:28 PM
Saxguy1000 is offline
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
I bought some last year with the intent of installing them, but haven't done it. I think it was the thought of having to make the cuts into the wings that stopped me.
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Jan 16, 2015, 07:31 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
10% off ends tonight and electric retracts are already marked down. PROMOCODE: ALLPARTS
http://www.horizonhobby.com/airplane...tracts-eflg110
HorizonRC.Com Review - E-flite Electric Retracts Make Installation Simple (10 min 0 sec)
Old Jan 29, 2015, 07:05 AM
mehelicrasher is offline
Find More Posts by mehelicrasher
United States, OH, Milford
Joined Nov 2011
motor question
I'm thinking the leader 480 will be my next plane, is anyone flying it with the emax 480 motor? If so which kv? Thanks
mehelicrasher is offline Find More Posts by mehelicrasher
Old Feb 07, 2015, 09:23 AM
PepeM is offline
Find More Posts by PepeM
Joined May 2011
Took my Leader out after a long time. Still flies beautifully, although it needed a lot of elevator trim to fly straight. I've never been too good at landing this plane, it always end up coming a bit harder than I would like. Not had much issues with it until today, when the motor mount decided to break.
PepeM is offline Find More Posts by PepeM
Old Mar 10, 2015, 06:01 PM
Sophisticat is offline
Find More Posts by Sophisticat
Sophisticat's Avatar
United Kingdom, Northern Ireland, Newtownards
Joined Mar 2012
Had some flights today after replacing the Park 480 motor with a Power 10. Balancing required a 10g weight on the tail. I will not be going back to the 480 as the plane doesn't run out of energy in the climb and large loops are so much easier.
Sophisticat is offline Find More Posts by Sophisticat
Old Mar 11, 2015, 08:24 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
The Power 10 weighs more that the Park 480… The weight of the Power 10 is 122g and the Park 480 is 87g. You must be leaving something out of that description because that can't be.
Old Mar 12, 2015, 03:10 PM
Joined Mar 2012
Indeed, I used motor mounts described by TennFlyer above and moved the esc back by 7cm approximately.
Sold 3DHS 41" Blue Edge NIB + Eflite 480 Cabledawg1 Aircraft - Electric - Airplanes (FS/W) 5 Sep 03, 2010 12:58 AM
Question Thoughts on the Ultrafly P51D w/ Retracts lafuerza Electric Warbirds 3 Sep 01, 2010 02:16 PM
Discussion Should I try high Timing on a Eflite 480? Cabledawg1 Power Systems 4 Jul 19, 2010 01:16 PM
Discussion Can't replace shaft on Eflite 480? Lowezz Electric Motor Design and Construction 6 Apr 07, 2009 10:42 AM
Any thoughts on airfoil for 400/480 stuka with scale wing kit basher Power Systems 3 May 19, 2001 11:21 AM
