Old Mar 21, 2015, 07:54 AM
Wingin' Wayne is offline
Find More Posts by Wingin' Wayne
I like the violent stuff!
Costa Mesa, CA
Before anyone gets the idea I don't know how to tumble, I do. I learned to tumble from Bone Doc himself. So my repaired 71 does not want to tumble. Balance and thrust angle tests look normal. It will still pop top and all that other good stuff, it just will not tumble. Any ideas about what I should be looking for? THANKS!
Wingin' Wayne is offline Find More Posts by Wingin' Wayne
Old Mar 21, 2015, 08:34 AM
camoy is offline
Find More Posts by camoy
I can't fly
camoy's Avatar
United States, CO, Parker
Joined Dec 2006
Well not knowing what happened exactly and going off the fact that a motor box was replaced. It could be now you have some incidence issues if the wing tub had broken out and needed to be remounted. Could also be the repair added enough weight to change things. How are you testing thrust angle?
camoy is offline Find More Posts by camoy
Old Mar 21, 2015, 09:05 AM
G.P. is offline
Find More Posts by G.P.
iumop ap!sdn w,I
G.P.'s Avatar
Joined May 2005
Are you using the same type and size of prop as before? I've found that a plane can fly drastically different between props. Gyroscopic differences with weight changes and the amount of airflow over the control surfaces are my guess.
Other issues may be a change in C of G after the repairs, or reduced control throws after the repair (radio setup, not on high rates, linkage changes, servos with less torque, etc). I assume there was a crash if you had to do a motor box, so you could also have a damaged servo. Cycle your servos while applying some back pressure to the control surface. Feel for week servos and rough gears.
More info on the crash and the repairs that were done would be helpful.
G.P. is offline Find More Posts by G.P.
Old Mar 22, 2015, 08:45 AM
Costa Mesa, CA
Crash was LVC shutdown. Still had all surfaces. Pancaked in hard on it's belly. Folded the L/G back. No other real damage other than the cowl , wheel pants and holes in bottom of wings. Still using the same prop as a matter of fact. I'm no builder, so I had an experienced builder put in a new motorbox. Moved the battery back to adjust c/g. The c/g is just ahead of neutral where I always run it on all my planes. For thrust line check I go full throttle straight and level downwind and chop throttle to zero, very little effect. Servos still have fast, full deflection and perform well in other violent maneuvers. Today I will manually check backpressure and go over plane again for bad linkages. Thanks for the help guys!
Old Mar 22, 2015, 01:02 PM
G.P. is offline
iumop ap!sdn w,I
G.P.'s Avatar
Joined May 2005
Check your elevator joiner and rudder pull-pull wires too while you are looking things over.
Old Apr 07, 2015, 11:26 AM
Chuck is offline
Find More Posts by Chuck
Balsa to the Wall
Deep in the East Texas Piney Woods
Joined Dec 2001
I need an elevator control horn for my 71. I had to make a repair, now I need to put 2 servos on the elevator. If anyone has a spare you'd like to sell, you'd be my hero forever.
Chuck
Chuck is offline Find More Posts by Chuck
Old Apr 07, 2015, 12:28 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
I have enough for one elevator if that will do...
Send me your "snail mail" address...
SteveT.
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Apr 07, 2015, 12:34 PM
Chuck is offline
Balsa to the Wall
Joined Dec 2001
That would be perfect, Steve. Look for a PM
And muchas gracias, Amigo.
Chuck
Old Apr 07, 2015, 12:38 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
No problema!!!
SteveT.
Old Apr 07, 2015, 12:57 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Packed, and will be on it's way in about 1/2 hour...
SteveT.
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
