Old Jun 27, 2015, 09:01 AM
Jon h2 is online now
Find More Posts by Jon h2
United States, MI, Royal Oak
Joined Dec 2003
Intermodulation Distortion (IMD) in FPV
Hi all,
With our FPV racing group, we have often noticed poor FPV performance when flying in groups. This often occurs even when we spread out channels across the 5.8 range. My father, a retired RF engineer, did some experiments and came to the conclusion that inter-modulation distortion (IMD) is at least part of the problem. As far as I am aware, this is an often ignored issue in the FPV community.
A group of pilots operating at 5.8 GHz are especially prone to IMD. The close proximity, high power transmitters, even spacing of the channel frequency, and poor receivers contribute to the problem. Per the video, there are some simple steps that can be taken to mitigate the issue. IMD is when two other transmitters combine and produce interference in your receiver at your desired FPV frequency.
I know the video is not the most exciting (the demo is at 3:45 in for those with short attention spans). I do think that if the FPV community adopted some of these strategies we could have better racing and group flying.
FPV Interference from IMD - Demo (10 min 45 sec)
Best,
Jon
Jon h2 is online now Find More Posts by Jon h2
Old Jun 27, 2015, 01:16 PM
waltr is offline
Find More Posts by waltr
Team WarpSquad
United States, PA, Doylestown
Joined Jan 2014
Good video covering IMD.
I have run into this issue working on Ham Radio repeater systems on multiple bands and during Club multi-station Ham radio contests.
It can be a difficult issue to work out what combination is causing the trouble.
Is the spread sheet show in the video available?
Better Receivers would go a long way to reduce IMD and also reduce adjacent channel interference.
Do any better vRX's exist?
I have been an advocate of low power vTXs. I have been running 200-250mW vTXs and use a goggle mounted 3-turn helix when I need a little more range. Tracking the copter by moving my head works very well and not that hard to learn to do.
waltr is offline Find More Posts by waltr
Old Jun 27, 2015, 04:46 PM
Joined Dec 2003
I will try and post the spreadsheet later. It is very difficult to choose frequency combinations that produce no IMD problems with one another when you are flying with 4 or more people. It is especially hard when you try to make sure the IMD products are spaced so many MHz away from any of the desired frequencies.
It was our hope that this would lead into a discussion about receiver performance. Do the more expensive ImmersionRC receivers reject IMD better? We do not know.
It is worth noting that none of the 5.8 bands available to us do anything to prevent IMD combinations. This includes immersionRC's new 'race band'
Old Jun 27, 2015, 04:48 PM
Joined Dec 2003
Also, members of our club are working to introduce a strategy into their website pidfoo.com that will sort the racers and assign frequencies that produce no IMD products on the desired frequencies.
Old Jun 27, 2015, 06:55 PM
Rob Hair is online now
Find More Posts by Rob Hair
Michigan
Joined Apr 2001
I am attaching two versions of the spreadsheet. One shows all of the two tone products and the other has those frequencies that are outside of the band removed for clarity.
The spreadsheet can be used to see the two tone third order IMD products produced by frequencies of the 32 standard FPV channels in the 5.8 GHz band. Note that any given pair of frequencies has to be fit "both ways" so to speak in the spreadsheet. That is, locate the intersection of f2 in the first column and f3 in the first row, then do the same with f3 in the first column and f2 in the first row, After a little time with these you will see how difficult it is to keep track of these frequencies! Better would be a program in which you could enter the frequency assignments that you want to try in a race and the program would calculate whether there were any IMD products on or near frequencies that had been assigned to any racer. I think one of our club members is working on something like this.
I'm looking into doing some testing of FPV receivers to evaluate their IMD performance and maybe I'll be able to make available third order intercept measurements. There are other receiver performance parameters related to interference immunity that would be helpful to know as well.
Rob Hair is online now Find More Posts by Rob Hair
Old Jun 27, 2015, 07:03 PM
Michigan
Joined Apr 2001
To clarify, I don't at present know if any of the commercially available receivers on the FPV market offer any better IMD performance compared to the ones that I have used for this demonstration.
Waltr, you are right on target with your comments.
Old Jun 28, 2015, 02:27 PM
waltr is offline
Team WarpSquad
Joined Jan 2014
Thanks.
I remember the First HF Ham radio receiver I built. It was single conversion for 80meters and had down converters for the other ham bands. First time trying the 40 meter converted there were squeals and stuff all over when tuning. I wrote down each frequency there was a tone then learned about IMD. I did write a GW Basic program to work out all the products.
Never did get the converters working well but the 80 meter part worked great.
Old Jun 28, 2015, 10:03 PM
Martin Y is online now
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
That is a great demo but can you do that same test some distance away from the rx? Dont think anybody flys that close to each others rx's. For example have all tx's about 10 feet apart and 20 feet from the rx.
IMO for racing everybody should have the same power vtx.
Martin Y is online now Find More Posts by Martin Y
Old Jun 28, 2015, 11:28 PM
Michigan
Joined Apr 2001
Perhaps you missed it but we did address that in the presentation. I had the same concerns, namely that in the demo, the distance between the potential interferers and the receiver was less than would be encountered in an FPV race. So I repeated the test at greater distances. I found very significant interference when the distance between the interfering transmitters and the ground station (receiver) was up to 100 ft. Its my judgement that this could be readily encountered in an FPV race. At distances over 100 ft, interference could still be seen, but was less dramatic.
Note also that in the demo we used transmitters of lower power than are often used in FPV racing. One of the interferers was 200 mw and the other was only 25 mw.
Our intention is to show that IMD can be a source of interference in FPV racing. Our experience was that despite taking adequate measures to avoid adjacent channel interference at our races, some pilots (including me) still saw significant interference in some circumstances. If otherwise unexplained interference is seen at an FPV race, IMD problems could be the cause.
Unfortunately, there are other potential deficiencies in the RF systems for FPV besides IMD that can cause problems. We would benefit from better specifications for these devices. And, of course, these devices were designed with low cost being a major consideration.
Old Yesterday, 02:39 PM
Havoc256 is offline
Find More Posts by Havoc256
Havoc256's Avatar
United States, MI, Detroit
Joined May 2014
The problem comes in play because a lot of us use the 600mw transmitters and they stop all over the 200mw transmitters. Also when we have our race events, the pilots tend to sit right next to each other. So this does become a real life issue.
Havoc256 is offline Find More Posts by Havoc256
Discussion Distortion upon distortion upon distortion: Welfare Pays well MtnGoat Life, The Universe, and Politics 74 Aug 23, 2013 08:48 PM
Question FPV color distortion issue Bobby_C USA - District V 4 Jan 27, 2013 07:20 PM
Help! GoPro FPV not working! Black & White and distorted. Help! Mon0bLE FPV Talk 9 Dec 29, 2012 06:00 AM
Question FPV cameras and distorted views tugboat rod FPV Talk 9 Aug 17, 2007 05:31 AM
Intermodulation Neil McGrath Power Systems 4 Feb 09, 2002 03:25 PM
