Old Oct 02, 2014, 06:32 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
F104 for 40mm
As I now have a 40mm mad thrust fan I can have this build in the micro edf section .Its been sitting around for some time. But Pdawg made me buy a new 40mm fan so I deside to slap this together. The kit is a old Steve jets F-104. I own the molds for it so I can make more when needed
Old Oct 02, 2014, 06:49 PM
ksqm is online now
Find More Posts by ksqm
Hampton, VA
Joined Mar 2009
That's a really sweet F-104 you have there. Good luck with the build.
Ksqm
ksqm is online now Find More Posts by ksqm
Old Oct 02, 2014, 07:43 PM
danj31 is offline
Find More Posts by danj31
Greenwood Indiana
Joined Jun 2004
Good luck, you might give me the motivation to get mine in the air. How do you plan on doing the tail linkage?
danj31 is offline Find More Posts by danj31
Old Oct 02, 2014, 10:01 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
You should Dan..you have way too much work into yours...Tail is pretty easy ...servo is in the tail pipe just below the vert. with a direct shot up to the stab.Pivot is forward of the control link.I will post some pics later
Old Oct 03, 2014, 02:53 AM
meerkat13 is offline
Find More Posts by meerkat13
meerkat13's Avatar
United Kingdom, Birmingham
Joined Jan 2013
Wow, some exciting builds happening on the forum. First nitro and now turbonut -awesome.
meerkat13 is offline Find More Posts by meerkat13
Old Oct 03, 2014, 09:55 AM
ksqm is online now
Hampton, VA
Joined Mar 2009
Turbonut,
Can you post specs on the Mad Thrust 40mm EDF benched and installed?
Old Oct 03, 2014, 12:12 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
I will post the fan numbers as soon as I can...I have to get the esc still..maybe this weekend for bench numbers..The intake ducts are now in the jet .I just need to make the adapter from the rear of the ducts to the fan. Then I can get installed numbers. I am curious as the ducts are very long.But they are over size as they were designed for a 50mm fan in the orig set up
Old Oct 03, 2014, 04:26 PM
nighthawk0077 is offline
Find More Posts by nighthawk0077
Joined Oct 2009
Nice bird, good luck on the project, would probably go pretty well on something like a great planes 55mm hyperflow fan and 500watts, not sure about a 40mm though? Maybe scale performance, anyway will be interesting to see a mini composite F104
nighthawk0077 is offline Find More Posts by nighthawk0077
Old Oct 03, 2014, 05:11 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Considering its close to the size of Pdawgs electrolite I think it will go pretty good. the 50mm fan is a tight fit so I dont know if 55 would fit
Old Oct 05, 2014, 06:25 PM
NX-687 is offline
Find More Posts by NX-687
Joined Aug 2007
Yo
Beautiful work there, will follow
NX-687 is offline Find More Posts by NX-687
Old Oct 09, 2014, 09:09 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
Looks like the fuselage was laid up w/Safety Poxy...Am I right???---Winner winner chicken dinner?!?!???......
Man---Does it look good or what!!!...Any chance of some of use mere mortals obtaining a fuselage from you?!?!???......
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Oct 09, 2014, 10:47 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Hi Kevin,
No just real old west system hardener..Turns brown with age. After I get the first one set up I will lay up a few for sale. Intakes are done and the fan is mounted. next the wings and aileron servos.
Old Oct 12, 2014, 04:43 PM
Joined Mar 2007
Hi Kevin,
Safety Poxy also turns brown with age, hence the question...Looks REAL good!!!...Please PM me when you have the parts available as I seem to miss out on the first and sometimes only run of parts...
Old Oct 23, 2014, 10:55 AM
rvincent is offline
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
VERY Nice Scott!! I will talk to you at Big Jolt Got to see about one of these Fuses Please also share how you built your wings. How is the elevator done? full flying? Not like I like Starfighters or anything
rvincent is offline Find More Posts by rvincent
Old Oct 23, 2014, 12:35 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
I will bring V1 with me to the Jolt..Current wings are foam core with balsa skin then Mono coat. V2 may be some thing other than that. the stab is full flying on mine. When Steve did them he just split the stab and elevator
Discussion het f104 starfighter retract install esb-help Electric Ducted Fan Jet Talk 43 Oct 12, 2014 06:43 PM
Discussion Looking for a GAD 50mm EDF F104 Star fighter kit ? redtail Foamy EDFs 0 Aug 30, 2014 06:22 AM
For Sale rxr HET F104 w/tip tanks istandalone Aircraft - Electric - Jets (FS/W) 3 Oct 23, 2013 07:21 AM
For Sale F104 v2 and a f104 mp4-24 3dcrasher Cars - Cars and Parts (FS/W) 0 Apr 24, 2013 04:09 PM
New Product Yeah Racing (#F104-014SS) Spring Steel Main Drive Shaft Black for Tamiya F104 Pro edwardchan80 Product Announcements 0 Jul 19, 2012 09:31 PM
