Old Feb 14, 2014, 06:20 AM
TheKingPhisher is offline
Find More Posts by TheKingPhisher
Joined Dec 2012
New Product
New Hobbywing ESCs?
http://www.hobbywing.com/cn/news_show.asp?id=213
TheKingPhisher is offline Find More Posts by TheKingPhisher
Reply With Quote  (Disabled)
Old Feb 14, 2014, 08:24 AM
P.I.Engineer is online now
Find More Posts by P.I.Engineer
P.I.Engineer's Avatar
United States, CA, Redondo Beach
Joined Mar 2005
those look great
P.I.Engineer is online now Find More Posts by P.I.Engineer
Old Feb 14, 2014, 11:16 AM
Dejavu*Xion is offline
Find More Posts by Dejavu*Xion
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
K.P:: Freaking Awsome. . You know im a huge fan of Hobby"Wing" love the new upgraded v2.
Thanks for the post K.P
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old Feb 18, 2014, 06:38 PM
teamdavey is offline
Find More Posts by teamdavey
Sunnyvale, CA, USA
Joined Apr 2000
When, HV? is the soft start better and how much?
teamdavey is offline Find More Posts by teamdavey
Old Feb 18, 2014, 11:02 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
The throttle lead has 4 wires, built in RPM sensor maybe?
EDIT: No there are actually two leads.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Feb 23, 2014, 01:33 PM
IntegrityHndywrk is offline
Find More Posts by IntegrityHndywrk
IHW Heli Division
IntegrityHndywrk's Avatar
United States, FL, Palm Coast
Joined Mar 2012
Nice find, Looks interesting. I have translated the page so others may read about it easier.
Originally Posted by http://www.hobbywing.com/cn/news_show.asp?id=213
Platinum V3 series of high-end air mode Brushless ESC upcoming
Only let opponents fear, the Warriors; make opponents fear, is king.
▲ High-performance 50MHz microprocessor, fast response speed.
▲ multiple flight mode, a wide range of applicability:
● Aircraft - Airplane mode
● Helicopters - fixed speed off mode
● Helicopter - Wizard constant speed mode
● Helicopter - stored constant speed mode
▲ new fixed speed algorithms, excellent constant speed effect .
▲ excellent slow startup performance, completely eliminating drift phenomenon helicopter startup.
▲ flameout landing restart time is adjustable, can be manually interrupted flameout landing process and quickly restart the motor, avoid handling errors and crash.
▲ PWM frequency up to 32KHz, the drive motor is running smoother, quieter.
▲ industry's most powerful built-in high-power switch-mode BEC:
● Platinum-100A-V3: BEC output voltage 6.0V/7.4V/8.4V adjustable output current continues 10A, 25A moments;
● Platinum-50A-V3: BEC 5.2V/6.0V/7.4V adjustable output voltage, output current continues 7A, instant 15A;
▲ independent of speed (RPM) signal output interface, simplifying without aileron system peripherals.
▲ independent parameters set Interface (Program Port), for connecting LCD programmable box.
▲ independent parameters set the interface can run real-time output power transfer state data, with data transfer module can be real-time data monitoring and recording.
▲ professional electronic engineers can use ESC to run real-time output data to develop more applications.
▲ ESC firmware can be updated online.
▲ compact and rugged construction.
Pasted from <http://www.hobbywing.com/cn/news_show.asp?id=213>
IntegrityHndywrk is offline Find More Posts by IntegrityHndywrk
Old Feb 27, 2014, 02:45 PM
galaxy1 is offline
Find More Posts by galaxy1
galaxy1's Avatar
Italy
Joined Oct 2005
I've tried. everything is written here http://www.rcgroups.com/forums/showthread.php?t=2112916
galaxy1 is offline Find More Posts by galaxy1
Old Feb 27, 2014, 03:34 PM
Joined Dec 2012
Thank you galaxy1! Looks to be a winner!
Any word on new versions of OPTO HV or firmware updates with new governor?
Old Feb 27, 2014, 03:54 PM
galaxy1 is offline
galaxy1's Avatar
Italy
Joined Oct 2005
Are currently provided only version 50A and the 100, both with BEC.
the firmware is already perfect as it is.
expect an answer by hobbywing to update the firmware of the program box.
it currently does not connect with the V3
Old Feb 27, 2014, 04:23 PM
Joined Dec 2012
I was hoping users could update the platinum pro 120A HV OPTO with the updated governor algorithm.
Old Feb 27, 2014, 04:45 PM
galaxy1 is offline
galaxy1's Avatar
Italy
Joined Oct 2005
this is not possible. I also had already asked hobbywing, but they told me that the processor is to limit its potential. In fact, the PL-V3 processor have changed (50mhz). inside, the hardware is completely different.
Old Feb 27, 2014, 05:33 PM
Joined Dec 2012
Ok that makes sense. Do you know when these new V3s will be available for purchase? I want to try the 100A model in my 600 class heli.
Old Feb 28, 2014, 08:59 AM
galaxy1 is offline
galaxy1's Avatar
Italy
Joined Oct 2005
I'm sorry I do not know
Old Mar 04, 2014, 03:20 AM
galaxy1 is offline
galaxy1's Avatar
Italy
Joined Oct 2005
was added to the site (English) Hobbywing PL-V3.
you can download the manual.
http://www.hobbywing.com/product.asp...&subclassid=29
Old Mar 04, 2014, 10:03 AM
IHW Heli Division
Joined Mar 2012
Geez man, here is something i thought they might have "fixed" and didn't. A lot of the motors people are using these days want 5 advanced timing... For instance, every single Scorpion motor in existence. Even the tiny little 3S Lynx motor has 5 timing as their recommendation. What is with Hobbywng only ever providing 3.75, and now 4 on the new ones. Otherwise you have to select something higher than 5. Why can't they just put a square 5 in there somewhere if so many motors recommend it...
Not for nothing, but Hobbywing has a deal with Gaui and their controllers are provided on the Gaui kits using Gaui branding. Also, every Gaui kit comes with a Scorpion motor with Gaui branding as well... Would make sense to release the new line with a 5 option, i would have thought. It probably only requires a firmware update, right?
Sold Hobbywing 100A HV ESC, 30A esc's couple motors planebldr Aircraft - Electric - Power Systems (FS/W) 0 Oct 21, 2013 07:31 AM
For Sale Brand New x4 650KV Motors and Hobbywing 4in1 20A ESC! Sold together ActionDrone Aircraft - Electric - Multirotor (FS/W) 0 Oct 12, 2013 02:48 AM
New Product new hobbywing eZrun 5.5T ESC combo supermanhobby Product Announcements 0 Apr 21, 2009 06:45 AM
Sold 60A Hobbywing Guard ESC - NEW $45 eaterofdog Aircraft - Electric - Power Systems (FS/W) 6 Apr 19, 2009 09:22 AM
Sold Brand new in packet Hobbywing pentium 30A esc Happy|Harry Aircraft - Electric - Power Systems (FS/W) 2 Aug 17, 2008 07:37 AM
