Old Jul 31, 2012, 09:58 AM
Torch8 is offline
Find More Posts by Torch8
Torch8's Avatar
NYC
Joined Aug 2010
Question
Charging Lipo using Balance board vs Direct
Been charging my 2s and 3s lipo connecting balance cable to the balance board on my CellPro4s. Seem this is safer method of charging Lipo.
Charging lipo through balance board vs charging it directory to discharge cable, what is the difference? Is it any faster?
Torch8 is offline Find More Posts by Torch8
Old Jul 31, 2012, 11:57 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Not sure sure what "charging it to directory" means but basically the clue is in the name. If you aren't using the balance connector then you aren't balancing the pack. It's a good idea to balance lipo packs though it's not 100% essential that you do it every charge .
Steve
slipstick is offline Find More Posts by slipstick
Old Jul 31, 2012, 07:25 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
CellPro 4 charges and balances thru the balancing leads only.
Many other balancing chargers charge thru the main leads and balance thru the balancing leads .
An old article on Balancers and how they work
http://www.rcgroups.com/forums/showthread.php?t=599287
Charles
Discussion LiPo Fast Charge Vs Balance. Sam1148 Beginner Training Area (Aircraft-Electric) 42 Feb 05, 2015 03:54 AM
Discussion Using a IMAX B6 lipro balanced charger to charge a nimh pack Tripsta Electric Power Cars 11 Jul 11, 2012 05:28 AM
Discussion Pre-balancing batteries using a charging board? overmyhead Batteries and Chargers 7 May 29, 2012 09:06 AM
Balancing vs. discharging/charging Lipos ned49 Batteries and Chargers 4 Aug 27, 2005 09:14 PM
Does using a lipo charge balancer slow down the rate of charge significantly Gordon Batteries and Chargers 37 Jan 23, 2005 10:53 AM
