Old May 31, 2013, 05:18 PM
Joined Mar 2013
Build Log
Scratchbuilt Aircraft Plywood frame
Hi,
I working on scratchbuilt frame. I will use birch plywood specially made for airplane and lasercutting.
The frame size is 600x600mm and i can't choose between 3mm or 4mm plywood. Any advice welcome....
sixbras is offline Find More Posts by sixbras
Old Jun 01, 2013, 11:03 AM
Joined May 2013
This is probably not what you want to hear, but I learned a valuable lesson today. I let my son have a go of my (wood framed) quad. It went from approximately 100ft altitude to zero before I could wrestle the controls off him. Luckily the hard ground broke its fall
Needless to say it needs a complete rebuild, and that was with a simple (5 parts only) wooden frame. Luckily I can make a new frame in around 10 minutes and for only a couple of $$$
Have you given any consideration to crash resilience ? Your design looks great but one heavy landing and its not going to look like that for long
merly_uk is offline Find More Posts by merly_uk
Old Jun 02, 2013, 06:16 AM
Team JR
Doug Cronkhite's Avatar
San Diego
Joined Feb 2002
Always design to fly, never to crash. If you design something to withstand crashing it'll be very heavy.
Doug Cronkhite is offline Find More Posts by Doug Cronkhite
Old Jun 02, 2013, 03:51 PM
United States, FL, Malabar
Joined Oct 2012
I agree, weight is the enemy of longer flight times. However for stability in wind too light can also be a problem. The arms look good with similar arm design to the Hoverthings HT-FPV frame. Your main body, IMHO looks too heavy unless your were to use large low KV motors on 4s or 6s batteries. I like your integrated brushless gimbal.
What program are you using to lay up the renderings?
Andrew Sommer is offline Find More Posts by Andrew Sommer
Old Jun 03, 2013, 09:15 AM
Joined Mar 2013
I will use 4 Sunnysky 2814-11 KV 700 with 4s Lipo and 12x6 props.
Weight for a full 1200x600mm birch plywood sheet is 1,4kg (3mm)
I use only 60% of the sheet, the frame will be around 800g without glue.
I use adobe-illustrator to draw every items and send files to laser-cutting factory.
My brother help me for design, and export items from illustratior to z-form and cinema4D for pre-assembling and 3D preview.
Old Jun 03, 2013, 11:05 AM
Lead Zeppelin
Germany
Joined Apr 2013
This is a clever design and nice computer work, but I really don't think it will have the strength you need, especially for a quad this size (not a micro quad). Remember the Hoverthings FPV frame is made from G10, which is extremely strong. 3mm plywood will snap like a twig, particularly the area in the arms where there are large cut outs.
I would consider removing more material from the center plates, not from the arms. Nobody who is building their own quad can expect to fly perfectly without some mishaps. Using this design and material I don't think the quad would survive even one less-than-perfect landing. Using G10 or some other high strength material would give you more options in the design.
flugratz is offline Find More Posts by flugratz
Old Jun 03, 2013, 11:20 AM
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
You could always start with some solid stock arms and switch to the girders later once you're confident with the frames' abilities.
Granted is online now Find More Posts by Granted
Old Jun 03, 2013, 05:08 PM
Joined Mar 2013
Originally Posted by flugratz View Post
This is a clever design and nice computer work, but...
Thanks!
The reason why i removed material from the arm is targeting a good airflow, not for saving weight. May be i will let the arm full.
It's not visible on 3D view but i have a landing gear in carbon that will be fix under the center plate. It hope that will prevent broken arms.
Old Jun 08, 2013, 03:53 PM
Tulcea Romania
Joined Mar 2010
Hi there,
That īs a nice idea. I have built a frame similar to that and you can see it here- http://www.rcgroups.com/forums/showt...1785969&page=2
The frame is made from 3mm ply and weighs 340gr empty. It was glued together and it is sturdy . Your arms are weak and they will brake for sure. My arms seem to be strong as I kept them short and glued together. The glue makes a big difference when it comes to ply.
Stil waiting for parts to make it fly...
danielpetrescu is offline Find More Posts by danielpetrescu
Old Jun 14, 2013, 09:30 AM
Joined Mar 2013
Ok, I've got all my parts back from lasercutter.
As flugratz suggest me, i reduce the large cut out in the arms to make it stronger.
@danielpetrescu : Are you using "aircraft" plywood or regular one. Aircraft plywood have more layer (5 layers for my 3mm plywood).
Let's start the puzzle.... I will give you the frame's weight as soon as possible.
Old Jun 14, 2013, 11:04 AM
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
Coolest. Tinkertoys. Ever.
Old Jun 15, 2013, 04:07 PM
Lead Zeppelin
Germany
Joined Apr 2013
That looks very cool. I am very curious about how it turns out.
What kind of glue are you using?
Old Jul 02, 2013, 09:28 AM
Joined Mar 2013
Hi all,
Here is some new pics. Arms are looking strong enought and ready to paint.
The main body need few modifications from the orginal plans (of course )
The blind nuts for the foldable arms
I've try to put stuff on board to see if i have enough room.
And finally it's look like this.... not so bad.
And the gimbal
Any comments, suggestion will be welcome.
@flugratz : I use cyanoacrylate glue from HK
Old Jul 02, 2013, 06:21 PM
Joined Mar 2010
I like Woody.
FlyingMcCoy is online now Find More Posts by FlyingMcCoy
Latest blog entry: Indoor 3d
Old Jul 11, 2013, 06:46 AM
Joined Mar 2013
Some news of my woody ;-)
The main frame with gimbal and landing gear support.
And first balance test for gimbal test.
Painting first layer...
Discussion x wood frame light copter kk2 fpv ready dragonlord Scratchbuilt Multirotors 0 Mar 30, 2013 04:59 PM
Sold **Sold** BNF wood frame quad - $125.00 jkrause528 Aircraft - Electric - Multirotor (FS/W) 3 Jan 17, 2013 09:38 AM
Build Log Aerobatic Cap 232 Full Fuse Scratchbuilt ! (Carbon Stick Frame) Ezekiel Freshmen Foamies (Scratchbuilt) 21 Dec 29, 2011 08:02 PM
Sold scratchbuilt tri frame (foldable w/yaw mount & servo) ROCKY2 Aircraft - Electric - Multirotor (FS/W) 6 Nov 17, 2011 08:40 PM
Balsa wood wing frame PortAh Non R/C Items (FS/W) 3 Sep 28, 2008 12:28 PM
