Old Yesterday, 09:25 AM
Spain, GA, Ourense
Joined Apr 2014
More Help
Originally Posted by FireHawx View Post
This is definitely a builders jet. Loved both mine to the end(ccrash). But enjoyed the build. It can be made a very nice jet with a little work. I wouldn't use those tail feathers even if they came pristine. Use balsa. I used an old set of SkyAngel F86 wings and it was a perfect fit with only a little work and some CF. Good luck.
Thanks FireHawk. I was planning to use some CF on the horizontal stabs, I have seen some models that come with it from stock, mine don't.
Another question. As I said before this is my first edf. Made a ground test, it's clear that fan needs to be balanced. I see that I can reach fan screw easily (about1 inch from foam edge), without the need of taking out all the edf, but I don't know what to wait, it seems that the motor is somehow attached to the duct, so it won't get loose if I unscrew fan, and the fan looks like if it goes screwed to a shaft adaptor or something like that, my question is: if I unscrew fan, it will be easy to reassemble, I mean, there are no going to appear a bunch of little pieces that force me to take out all the edf unit to put it all together again, am I right and motor won't get loose?. Thanks in advance
New Merlin is offline Find More Posts by New Merlin
Old Yesterday, 10:29 AM
FireHawx
FireHawx's Avatar
United States, FL, Jacksonville
Joined Oct 2011
Nope, your good. Go ahead take that screw off and pull the fan off of the hub its mounted onto. No little pieces or thing will fly off. I totally get your new and your concerns. Do you know how to balance the fan? I use tape to initially balance it then use CA/super glue (loctite professional) for the permanent setup after tape it removed.
FireHawx is offline Find More Posts by FireHawx
Old Yesterday, 01:37 PM
Spain, GA, Ourense
Joined Apr 2014
Thanks again FireHawk, I've seen some YT videos on how to balance an edf fan, I'll follow your advises.
Old Yesterday, 02:04 PM
Spain, GA, Ourense
Joined Apr 2014
Sorry... FireHawx, my foul.
Old Yesterday, 02:33 PM
FireHawx
FireHawx's Avatar
Joined Oct 2011
No worries
New Product F4D Skyray 64mm EDF by FMS Model Joe 1320 Foamy EDFs 993 Oct 16, 2014 01:21 PM
Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review Spackles94 Foamy EDFs 69 May 19, 2012 02:46 AM
Discussion Hobby King A4 Blue Angels EDF Jet airbagit13 Electric Ducted Fan Jet Talk 8 Nov 04, 2010 11:37 PM
For Sale Replacement 64mm EDF fan units for EDO and Hobby Lobby jets (REDUCED) The Don Aircraft - Electric - Jets (FS/W) 10 Dec 07, 2008 10:24 PM
Discussion broken fan on 64mm sapac t45 edf newguy2005 Foamy EDFs 0 Jul 19, 2008 04:44 PM
