Old Jun 19, 2016, 08:02 AM
Rogue_Pilot is offline
Find More Posts by Rogue_Pilot
Fly-Crash-Rebuild-Repeat
Rogue_Pilot's Avatar
Joined Jan 2011
Build Log
Micro 'SS Nomadic' (1:325 Scale) 8" RC Model
Hello all,
Thank you for viewing my build log!
I will be building a 1:325 scale radio controlled model of the SS Nomadic from scratch.
Here are the dimensions of the model:
Length ~ 8.12"
Beam ~ 1.36"
Approximate total displacement weight ~ 39 grams.
A bit of history:
The SS Nomadic was a tender for the White Star Line, built in Harland and Wolff shipyards from 1910 to 1911 along side the RMS Olympic and Titanic. The tender was built to service these two famous (or infamous) ships at Cherbourg, where the port was too shallow to allow an Olympic class liner to dock. Nomadic was used to ferry the 1st and 2nd class passengers to the ship; the 3rd class passengers boarded a different tender named SS Traffic. The SS Nomadic is the only surviving White Star vessel today, and is currently on display in Belfast, Northern Ireland.
I have been commissioned to build this model by a customer who owns a 1:325 scale R/C Titanic model and wanted to add this same scale SS Nomadic to their fleet to sail along side it.
Model Construction Method:
The hull will be made from vacuum molded plastic, with added internal reinforcements for strength. It will be powered with two micro-size motors driving the two propellers. Steering is done by shutting down one motor so the opposite motor turns the model.
I am also building a larger model of the SS Nomadic in 1:87 scale, which is around 30 inches long. You can find that build at the following link:
http://www.rcgroups.com/forums/showthread.php?t=2675726
Here's a picture of the real SS Nomadic as it looked in 1911, and as it looks today. Image source 'Wikipedia'.
Also a painting by Ken Marschall depicting the Titanic and Nomadic together as they would have appeared while passengers boarded Titanic in Cherbourg.
Rogue_Pilot is offline Find More Posts by Rogue_Pilot
Old Jun 19, 2016, 08:22 AM
Joined Jan 2011
Making the Plastic Hull Mold - June, 2016
Here is the hull mold that will be used in creating the vacuum formed hull. The mold is made from carved basswood, with 1.5mm styrene tips. I've included pictures of the carving process to show how I made it the correct shape.
The mold does not look too pretty with those random wood-filler spots, but it does not need to look nice. As long as the shape is true it will do its job in molding the actual plastic hull.
The next step is to vacuum mold the plastic hull around this block on a vacuum molding machine (which I also need to build).
Old Jun 19, 2016, 11:36 AM
kparquette is offline
Find More Posts by kparquette
Joined Jun 2016
Can't Wait!
Looking nice so far...can't wait till she's done and sailing alongside my Titanic
kparquette is offline Find More Posts by kparquette
Old Jun 19, 2016, 09:20 PM
flynelson is offline
Find More Posts by flynelson
China, Shanghai Shi, Shanghai
Joined Jan 2014
Awsome!
wish this can be a useful reference, as this one has similar weight and volume limit.
flynelson is offline Find More Posts by flynelson
Old Jun 25, 2016, 02:12 PM
Joined Jan 2011
Completed Funnel - June 25, 2016
Here are some pictures of the completed funnel. I made if from 1/4" aluminium tubing and .020" styrene rods. The tubing was compressed slightly to give it an ellipse shape.
Old Jul 01, 2016, 05:48 PM
Joined Jan 2011
I finished my vacuum forming table which will be used to mold the hull.
Old Jul 02, 2016, 06:18 PM
Joined Jan 2011
First Molding Attempt
Well, the vacuum machine worked BUT the mold did not. The sharp ends are impossible to mold without becoming a wrinkled mess.
I'll have to round out the ends so it can be molded properly, then crease the plastic into a point after the mold is set.
This was my first time ever doing a vacuum formed mold, so I'm learning as I go.
Old Jul 04, 2016, 09:04 PM
Joined Jan 2011
Vacuum-Formed Hull (July 4, 2016)
The vacuum-formed hull is now complete! It took several failed vacuum-forming attempts, but I've finally gained success! This was my first time vacuum forming, so I learned along the way. The hull had to be molded in two bilateral halves, then glued together.
Old Jul 05, 2016, 10:23 AM
Joined Jan 2014
awesome! is it tricky heating the sheet?
Old Jul 05, 2016, 06:04 PM
Joined Jan 2011
Thanks!
Heating the sheet isn't too tricky, I used a baking oven heated to 335 F (168.3 C) and placed the plastic sheet in for about a minute until the center sagged down ~1" (the height of the mold). I was using polystyrene, other plastic types will require different temperatures to mold properly.
Old Jul 06, 2016, 08:20 PM
Joined Jan 2014
Thanks!
I appreciate the information, which is valuable to me for a try in the future.
Old Jul 08, 2016, 09:58 PM
Joined Jan 2011
Propellers & Shafts
I made the propellers and shafts today. It will start coming together pretty fast once I get the electronics installed!
Old Jul 10, 2016, 09:06 PM
Joined Jan 2011
Painted The Hull - July 10, 2016
I painted the hull today! The next step is to paint the windows, then do some detailing work.
Old Jul 11, 2016, 06:18 PM
fastmax is offline
Find More Posts by fastmax
RCP Me!
fastmax's Avatar
United States, MI, Goodrich
Joined Nov 2007
This is awesome! Can't wait to see more! Nice work!
fastmax is offline Find More Posts by fastmax
Old Jul 11, 2016, 10:45 PM
Joined Jan 2011
Detailing the Hull - WIP Update 1 (July 11, 2016)
Thanks fastmax!
Tonight I added windows and the hawseholes in the forward & aft railings.
There are still a few more hull details to add, then I will work on the internal electronics.
I made the hawseholes by heating a bent paperclip in a candle flame, then pushing the hot metal through the plastic. It makes a perfect little hole.
Build Log SS Nomadic (1:87 Scale) 'White Star Line' Tender Rogue_Pilot Scale Boats 23 Jul 10, 2016 09:48 PM
Sold 3 pilots for sale: DGA 1/8 Scale, Ram Models Pilot 1/6 & Williams brother 1/4 scale unclegeorge Aircraft - Fuel - Airplanes (FS/W) 0 May 08, 2016 02:26 PM
Discussion Exceed RC 1/8 Scale Mad Torque 8x8 Crawler 2.4ghz Ready to Run RC Crawler RaidenCharlie NitroRCX 0 Apr 08, 2016 04:57 PM
Sold AMT "Showroom Replicas" 1/25 scale 2011 Chevy Camaro SS/RS Convertible plastic model W0WG Non R/C Items (FS/W) 2 Apr 06, 2016 03:45 PM
Whoops! Project Scrapped - Thread Deleted. Rogue_Pilot Scale Boats 13 Jul 29, 2015 11:47 PM
