Old Jan 04, 2016, 08:18 PM
tcbp285 is offline
Find More Posts by tcbp285
Joined Oct 2006
Futaba 8FG Screen Default
Happy New Year to all.
I have a small but annoying problem with my 8FG.
I start a flight on the home screen.
The screen then defaults to another screen ( either system , linkage or menu - I have not taken any notice of which ) maybe 45 ? seconds after.
Pushing S1 gets me back to the home screen.
This happens several times during a 2 minute.
This has been the case since day 1, firstly without the use of timers and now using both timers.
I am sure there is a simple fix ?
tcbp285 is offline Find More Posts by tcbp285
Old Jan 04, 2016, 08:28 PM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
You are probably pushing the MDL button by accident which takes you to the Model menu. It is not difficult to do as the MDL button is close enough to the edge where your right palm is. Lock the screen before flight by holding down S1 until you see the little key sign. Keep in mind that once locked you can not change the screen from the one at the time you locked it - you need to unlock it by holding down S1, switch to another screen if necessary then lock again.
I normally go to the timers screen before taking off and lock the screen there. Locking and unlocking is now something I do without thinking, I'm so used to it.
Ivan
ivanc is offline Find More Posts by ivanc
Old Jan 05, 2016, 02:25 AM
tcbp285 is offline
Joined Oct 2006
Hi Ivan,
Thanks for that. You were 100% correct!
I guess that explains those random beeping sounds as well :-)
Old Jan 05, 2016, 08:54 AM
ivanc is offline
S.A.D. member
ivanc's Avatar
Joined Dec 2004
Originally Posted by tcbp285 View Post
Hi Ivan,
Yeap, it beeps every time you touch that sensor.
Ivan
Old Jan 05, 2016, 02:19 PM
pilotpete2 is online now
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
+1 on locking the touch wheel.
If you update to the latest firmware, there is the option to auto-lock the control input thingy. This works particularly well with the option to have the radio power on to the model select screen (both options are under the MDL menu). With both options on, when you power up the radio, the model select screen will have the last model selected highlighted, now you just have to tap the enter button to fly the same model, or scroll to another model that you plan on flying. When the model loads, then the input lock will be active.
Lots of good stuff in the 8FG and 14SG
Pete
pilotpete2 is online now Find More Posts by pilotpete2
For Sale 3M TX Screen Protectors 14SG 8FG 18MZ 18SZ DX6 DX9 DX7 DX8 DX18 - 3M Vikuiti ADQC27 rlclemmons Aircraft - General - Radio Equipment (FS/W) 100 Yesterday 04:08 PM
Sold 1 x Futaba 8FG (V5) Super + R6208SB HV Receiver FASST Radio System (Futaba-Acc-8FG-R6 jmremash FPV Equipment (FS/W) 1 Mar 21, 2015 06:53 PM
Sold Futaba 8FG (Upgraded to 8FG SUPER) 14ch Dylwad Aircraft - General - Radio Equipment (FS/W) 7 Feb 18, 2015 12:59 PM
Help! 8fg super FUNCTION Screen Question porsche.911 Radios 1 Feb 26, 2013 10:44 AM
Wanted FUTABA 8FG or 8FG SUPER Snyper68 Aircraft - General - Radio Equipment (FS/W) 0 Feb 13, 2012 08:49 PM
