Old Jan 01, 2016, 09:21 PM
Mark Wales is online now
Find More Posts by Mark Wales
Glider Guider
Mark Wales's Avatar
United States, NC, Cape Carteret
Joined Feb 2002
Dodgson Designs
Been out of R/C for about 10 years now and wanting to get back into it. Still have a few of Bobs kits and planes.
Built:
Saber
Windsong
Wee-Giiante
Vee-Gilante
Kits:
Anthem
Pivot Plus
Todi
Anyone still flying Bobs planes?
Mark Wales is online now Find More Posts by Mark Wales
Old Jan 02, 2016, 11:07 AM
scottdivot is offline
Find More Posts by scottdivot
Joined Jul 2006
Had a Todi ! was not an easy kit to build but it flew great I have it somewhere up in the rafters.
scottdivot is offline Find More Posts by scottdivot
Old Jan 02, 2016, 11:10 AM
Glider Guider
Mark Wales's Avatar
Joined Feb 2002
I have thought about building it, but every time I decided to just leave it in the box..
Would you have any pictures of your Todi?
Old Jan 02, 2016, 04:19 PM
Jim Deck is offline
Find More Posts by Jim Deck
Jim Deck's Avatar
Valparaiso, IN
Joined Apr 2005
I have a V-Gilante kit with both 2M and Std Class wings. Are you still flying either of the _-Gilante sailplanes and, if you are, how do you like them? BTW, the Pivot plus gives you a smaller version of the classic (and it is a true classic) look of the most beautiful R/C sailplane ever, a Dodgson Windsong. It would be tempting to convert the Pivot Plus to a full house mini Windsong with today's modern electronics.
Jim Deck is offline Find More Posts by Jim Deck
Old Jan 02, 2016, 04:30 PM
Glider Guider
Mark Wales's Avatar
Joined Feb 2002
That would be a fun project to build the Pivot as a full house bird. The one I have is the 7037 with obichi sheeting thats still NIB.
The Gilante's flew very well and were a lot of fun. I have not flown for over 10 years and they were packed away years before I quit flying.
I sold a few of my kits years ago and wish I had kept them all...
Old Jan 02, 2016, 05:20 PM
xxwolfyxx is offline
Find More Posts by xxwolfyxx
Wolfy
United States, PA, Warminster
Joined Oct 2011
I have an Anthem I'm finishing re-doing with an extra fuse.
I just picked up a Camano a few days ago.
Haven't had either in the air yet as they are both used and needed some work but they are close.
xxwolfyxx is offline Find More Posts by xxwolfyxx
Old Jan 02, 2016, 05:22 PM
Roy_N is offline
Find More Posts by Roy_N
Roy_N's Avatar
United States, WA, Burien
Joined May 2014
I have a Maestro MkIII that needs a little TLC to fly again. Needs a new rudder and radio. Wings may need some work, haven't looked at the Maestro for a long time.
Roy_N is offline Find More Posts by Roy_N
Old Jan 02, 2016, 06:06 PM
Glider Guider
Mark Wales's Avatar
Joined Feb 2002
I built and flew a Camano with a built-up wing, that was one of the sweetest flying planes I have flown.
Have always wanted to build one of the Maestro kits, just like the looks...
Old Jan 02, 2016, 07:26 PM
Wolfy
Joined Oct 2011
Ahh thank you for the Camano pics.
I have the same built up wing. I've been a bit confused, when I did an image search of the Camano I found ones with foam and balsa wings that looked more the the wind/love song line. The built up wing had thrown me for a loop. Plus the stab was higher that the other images I had seen.
The only google image that came up which looked like mine was oddly your blue and white one.
The original builder made a lot of changes. He has a dual main wing rod, added the counter balance to the rudder and extended the wing with a really odd looking tip.
Hard to see from the photo but the tip has a nice taper in the front but the trailing edge sweeps back so you have the wing with a nice forward taper along the TE then a tip that sweeps back.
Old Jan 02, 2016, 07:51 PM
Glider Guider
Mark Wales's Avatar
Joined Feb 2002
Those wing tips do look odd for the Camano..
Other than my Camano having a built up wing it also had a clear canopy. Most of the Camano's I have ever seen have fiberglass canopies...
The rudder on yours also looks a lot bigger..
Old Jan 02, 2016, 08:36 PM
Wolfy
Joined Oct 2011
I'm torn on if to cut the tips off or try to rework the trailing edge to match the rest of the wing. Each panel measures out at 64" with tip. I attached a better pic straight on showing the oddness of it.
Yes the rudder is also huge. Might try trimming that down also looks like the fin was cut to add the extra to the front of the rudder.
Also included photos of the canopy and dual main wing rod. No idea why that was done or where to balance it.
Tried to find a copy of the plan so I would have an idea. balance at first rod or second who knows.....
What was the span of the stock wing of the Camano?
Old Jan 02, 2016, 08:44 PM
Glider Guider
Mark Wales's Avatar
Joined Feb 2002
The original span of the kits we have is 111.5". The Camano 100" was another version of it with foam core wings sheeted with balsa.
Holy wing rods.......
Since yours has a built-up wing it also has the clear canopy.
Here's an image I googledd and copied that has the stats.
Old Jan 04, 2016, 01:05 AM
Mark Lalla is offline
Find More Posts by Mark Lalla
Mark Lalla's Avatar
United States, CA, Montebello
Joined Aug 2011
Greetings,
I currently have a Windsong, Camano, and a Pixie in flying condition. I have them set up with the original mechanical mixers, with modern 2.4 radio gear. I also have a Pivot that is nearly completed. These sailplanes are by far my favorite flying machines. It is great to read that others are keeping these classics alive. Regards, Mark
Mark Lalla is offline Find More Posts by Mark Lalla
Old Jan 04, 2016, 03:42 AM
Glider Guider
Mark Wales's Avatar
Joined Feb 2002
Mark,
Which Camano version are you flying?
If you have any pictures feel free to post them...
Thanks for posting.....
Mark
Old Jan 04, 2016, 07:10 AM
Mr. Kite is online now
Find More Posts by Mr. Kite
May the Wind Always be Good
Webster, Minnesota
Joined Feb 2007
Here is a Yahoo Group on Dodgson stuff...https://groups.yahoo.com/neo/groups/...signgroup/info Hope this maybe a help get more info on Dodgson sailplanes ..
Mr. Kite is online now Find More Posts by Mr. Kite
Sold Dodgson Designs Maestro Mk III jolly01 Aircraft - Sailplanes (FS/W) 1 Dec 27, 2015 03:35 PM
Sold Dodgson Design books Grandstand Aircraft - Sailplanes (FS/W) 1 Jul 04, 2015 11:51 AM
Sold Dodgson Designs Pivot Plus Atindra Aircraft - Sailplanes (FS/W) 2 Jun 28, 2015 10:19 AM
For Sale Anthem from Dodgson Designs Gglide Aircraft - Sailplanes (FS/W) 1 Jun 14, 2015 08:33 PM
Sold For Sale - Dodgson Design Maestro Caliente + 132" Maestro Talisman wing kit Now $450 Wetcoast Aircraft - Sailplanes (FS/W) 3 Nov 01, 2013 12:53 PM
