Old Nov 06, 2015, 02:03 PM
alanbh is offline
Find More Posts by alanbh
Joined Nov 2015
Super Kinetic 815
Newish to rc after many years of building balsa gliders mostly 2 channel
So have been messing about scratch building but the good lady won,t stand for the mess so bought the super kinetic as ready made.
Oops should have spent more time learning to fly again second time out aborted the take off and stuffed it onto a rock snapping body in half.
undeterred fixed body reinforced with carbon rods hardly noticeable thanks to non solvent araldite.
Hobbyking have a strange way to measure CG as I measure from leading edge of wing in this case 40mm seems right added some ballast as wanted to fly a little nose heavy and only using a 3s 460 lipo.
Second attempt much better but OMG does it need a big space to land cut moter and she just kept going and going had to bring it back around again twice. snapped prop blade in long grass no big deal spares on the way as original ones are rubbish brittle plastic. To that end would it be worth trying to use the two airlerons as flaps not sure how to do it have a six channel tx and rx it may not work anyway as could have a bad effect on wing and make the thing stall when dropping the flaps
alanbh is offline Find More Posts by alanbh
Old Nov 22, 2015, 08:39 PM
shonmac is offline
Find More Posts by shonmac
shonmac's Avatar
United States, NJ, Dunellen
Joined Aug 2014
Hi,
I don't know if the this thread will help but maybe you can ask there
http://www.rcgroups.com/forums/showt...976332&page=59
shonmac is offline Find More Posts by shonmac
Latest blog entry: Upgrading
Old Dec 06, 2015, 11:15 AM
620ertom is offline
Find More Posts by 620ertom
Austria, Stmk., Graz
Joined Mar 2012
nice plane
Hi!
Hope that you polished your skills so you are fit for the Super Kinetic.
Here's a short comparison between the overpowered Kit and the PNF-Version so you can see what's possible without big changes...
Don' use the ailerons as flaps. This will cause more speed and some plastik parts may break when landing harsh.
Better to make a wide curve and slow down by slightly pulling the elevator.
Cheers
Tom
620ertom is offline Find More Posts by 620ertom
Sold Super Kinetic BNF outflying3d Aircraft - Electric - Airplanes (FS/W) 3 May 28, 2015 10:51 PM
Discussion FMS Fox/V-Tail or HK Spirit/Super Kinetic?? helicycle Parkflyers 1 May 18, 2015 05:01 PM
New Product HK Super Kinetic 815 clipper Electric Sailplanes 1 Jan 23, 2015 01:46 AM
Help! kinetic 815 and spirit: what's the difference? phil alvirez Electric Plane Talk 2 Sep 15, 2014 05:08 AM
Discussion kinetic 815 and spirit: what's the difference? phil alvirez Foamies (Kits) 0 Sep 14, 2014 09:13 AM
