Old Jan 17, 2013, 05:58 PM
iflircaircraft is offline
Find More Posts by iflircaircraft
United States, NJ, Phillipsburg
Joined Mar 2012
watt meter
I've read posts on using a watt meter. I've assembled my very first electric park flier, rimfire 400 motor,25A Esc, and need to know where to get a watt meter and voltmeter for a 3S Lipo.
I also need to know what does the watt meter's reading tell me?
Tom
iflircaircraft is offline Find More Posts by iflircaircraft
Old Jan 17, 2013, 07:51 PM
arnav is offline
Find More Posts by arnav
I live my life 12oz at a time
arnav's Avatar
United States, FL, Miami
Joined Nov 2011
Watt Meter:
In US:
http://www.headsuprc.com/servlet/the...-RC-130/Detail
From HK:
http://www.hobbyking.com/hobbyking/s..._Analyzer.html
Voltmeter:
In US:
http://www.headsuprc.com/servlet/the...Battery/Detail
From HK:
http://www.hobbyking.com/hobbyking/s...System_6S.html others to choose from if out of stock.
A watt meter will tell you Watt, Peak Watt, Amp, Peak Amp, Voltage, etc' you system is drawing. This helps you match ESC to motor, choose correct prop (to ensure you are not drawing more than ESC/motor can handle), Match output to batteries discharge rates, and more... So once you measure, make sure the values you get are within the spec of the batteries/ESC/motor.
These are essential tools....
arnav is offline Find More Posts by arnav
Old Jan 17, 2013, 07:55 PM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Wattmeter's :
Cheapest most likely from Ebay / Hobby King online.
But available via Hobby Shop as well as online.
I paid about $30 for my Wattmeter incl. shipping of ebay.
Most of the wattmeters in that oprice range are pretty well same items but just rebranded.
What does it give ?
Battery pack condition .. ie % charge remaining.
Individual cell voltages
Tells you if pack is unbalanced
Balances a pack without use of charger
Displays Watts / Amps / Volts when motor run
To be honest - a Voltmeter is not so essential if you have the Wattmeter .. but is useful for other checking of leads / contacts etc. A simple Multimeter from local DIY shop is good enough.
The Wattmeter is one of my most used pieces of equipment. I always check my LiPo's prior to charging ... check remaining after flight ...
Nigel
solentlife is offline Find More Posts by solentlife
Old Jan 18, 2013, 12:36 PM
aurorae is offline
Find More Posts by aurorae
aurorae's Avatar
Joined Sep 2008
Tom
One major item is amps. Your ESC is rated at 25 amps, so you need to make sure your motor isn't pulling that much at full throttle. If it is, you need to use a smaller prop or a prop with a lower pitch. Or get a bigger ESC, if your motor is rated at that many watts.
Warning: When you test that, only run the motor at full throttle for a couple of seconds, just long enough to read the display. If you run it for too long, you can burn it up because it is working harder when you are holding the plane still.
aurorae is offline Find More Posts by aurorae
Sold Tenergy TB-6 Balance Charger -- Turnigy Watt Meter Pierat Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 17, 2013 10:42 AM
Discussion Watt Meter or Watts Up Meter Sixter Power Systems 1 Dec 22, 2008 08:37 PM
Wanted Watt Meter, Watt's up Meter...Working or not! kctrading Aircraft - General - Miscellaneous (FS/W) 0 Nov 17, 2007 10:21 PM
Wanted WTB - Watts Up Power Meter / Watt Meter freedomflyer Aircraft - Electric - Power Systems (FS/W) 2 Jul 08, 2006 11:04 AM
Any difference between a "Watt's Up" meter and the Heli "Watts up" meter? xray328 Electric Plane Talk 1 Oct 17, 2005 11:23 PM
