Old Jan 01, 2013, 02:56 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Question
50 % speed of a ESC, The losses are highest.
Why do people say they are the highest over the entire speed range ? What becomes so dominant that they state it is the roughest temperature point ?
cyclops2 is offline Find More Posts by cyclops2
Old Jan 01, 2013, 06:58 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Switching losses in the FETs.
When a FET is either ON or OFF, it's very nearly ideal. When it's switching though, it passes through all resistances between 0 and infinite. As it does so, it wastes some energy through I2R losses.
At high duty cycles (near 100%) it carries high currents when ON, but doesn't switch very often. Losses when ON are very low compared to when switching though.
Odysis is offline Find More Posts by Odysis
Old Jan 01, 2013, 07:07 PM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Obviously it won't be 'highest over the entire speed range'.
At zero throttle the losses will be minimal.
At full throttle the dominant loss is FET on-resistance.
At part throttle, a number of factors come into play.
1. The higher PWM switching frequency increases transitional conduction losses because the FETs are being turned on and off more often. It also increases the power required to drive the gates.
2. In most ESCs the high-side FET body diodes are used to recirculate motor current during the 'off' part of each PWM cycle. These diodes typically drop ~0.7V when conducting, compared to <0.1V drop when the FETs are turned on.
3. Peak motor current is higher because the back-emf is lower, and winding inductance is not high enough to completely smooth out current variations.
It's not easy to calculate the exact point at which ESC losses will be highest, as it varies depending on characteristics of the motor and load. However in most cases it will be somewhere above 50% throttle, because prop loading (and therefore current draw) drops rapidly as rpm reduces.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Jan 01, 2013, 07:09 PM
Odysis is offline
Joined May 2007
True, body diodes are evil things.
Having a bit more of a think, I have a strange feeling body diode conduction probably contributes to total losses more than resistance through the miller plateu...
Old Jan 01, 2013, 08:12 PM
cyclops2 is offline
Joined Mar 2003
You have found my free wheeling diode ?
Old Jan 01, 2013, 09:01 PM
Odysis is offline
Joined May 2007
Didn't know it was missing! Mine are generally in my sock drawer, or down the back of the couch...
Old Jan 02, 2013, 04:08 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
What about N-FET only ESCs ?
Mine are cold even if packed two ESC sharing a single heatsink, wrapped, and between two carbon plates, with no airflow, like in this picture.
renatoa is online now Find More Posts by renatoa
Old Jan 02, 2013, 05:25 AM
Odysis is offline
Joined May 2007
n-fets have a lower RDSon than an equivelant p-fet, but that only affects heat when ON. During the switching or body diode conduction, there's no difference.
Old Jan 02, 2013, 05:29 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
This is why the YGE or YEP ESCs have freewheeling.
And presto, I saw 5-10% more efficiency when I used YEP instead of Turnigy plush.
Julez is offline Find More Posts by Julez
Old Jan 02, 2013, 06:16 AM
Odysis is offline
Joined May 2007
I was wondering how much effect that has.
I run two of them on my helis and one in an EDF, and am amazed at how much cooler they come down. I wasn't sure how much of an effect it'd have on the motor...
Old Jan 02, 2013, 06:36 AM
jakestew is offline
Find More Posts by jakestew
United States, ID
Joined Sep 2011
Clue me in... what is freewheeling?
Is it a ZVS or ZCS strategy?
jakestew is offline Find More Posts by jakestew
Old Jan 02, 2013, 06:46 AM
Odysis is offline
Joined May 2007
My understanding is neither. Before the FET is turned on, the body diode will be conducting. It's just there to move the current flow from the diode to the FET channel.
Say phase C was just switched to floating. The field in the inductor begins to collapse, sending current through the body diode. Freewheeling is the action of the current running from phase C to phases A and B. Using the FET to do the freewheeling keeps them cooler, and puts that energy back into the motor.
Old Jan 02, 2013, 06:47 PM
Joined Jan 2001
Perhaps this will help. Synchronous Rectification.
Old Jan 08, 2013, 01:30 PM
jjantti is offline
Find More Posts by jjantti
jjantti's Avatar
Finland
Joined Sep 2004
Hi all
Big ESC's are pricy and I just had to do some data mining. I found this thread very interesting. I bought YEP after reading this. What I've heard it's copy of YGE with old software. Electrical engineering background helps but is not mandatory
http://www.helifreak.com/showthread.php?t=443322
Jyri
jjantti is offline Find More Posts by jjantti
Discussion mini Skyfun highest speed is 144kM/h (fly video) weilung Flying Wings 5 Jan 31, 2013 06:40 AM
Help! Loss of head speed during banked turn? FyreSG Mini Helis 19 Dec 16, 2012 04:38 AM
Discussion why does my motor or ESC stall at 50% max speed pudbawl Electric Motor Design and Construction 12 Oct 14, 2012 01:08 PM
Question loss of control authority at high speed stallion explosi Flying Wings 10 Apr 01, 2012 01:23 AM
Discussion Fans with highest efflux potential for speed airframe? pdawg Electric Ducted Fan Jet Talk 99 Mar 16, 2012 11:37 PM
