Old Sep 28, 2010, 10:18 AM
gabe_tuft is offline
Find More Posts by gabe_tuft
Joined May 2010
"Micro" Stryker stalling in turns
Hey guys,
I'm a Stryker nut and decided to build a mini/micro Stryker to toss around in areas where landings were tight. Its 3 pieces of 6mm depron CA glued together and then sanded to have somewhat of an airfoil and a nice little nose (its covered in Gorilla tape to strengthen it up on the nose plants during testing). I have finally found the COG, but my biggest problem is stalling in hard banked turns. I can throttle up to avoid that, but I'd like it to respond similar to a true Stryker. Not only that, I would like it to be stable at all times:
As you can see, I made the elevons huge in the testing phase to compensate while I was locating the COG. The roll rate is extremely high right now, even with the aileron travel set very small. I'm assuming its from the over sized elevons.
Power setup is a 1300mah 3S, ICE50 lite, Micro Dan 2990 kv motor. Yeah, on the straight away she's pushing 70 or 80mph for sure. Its ridiculous, but super fun!
Any help would be appreciated.
gabe_tuft is offline Find More Posts by gabe_tuft
Old Sep 28, 2010, 02:51 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Elevon that big on an airfoiled wing will destroy lift even with very small deflection, act more like spoiler than control surface.
coriolan is online now Find More Posts by coriolan
Old Sep 28, 2010, 09:07 PM
Svede is online now
Find More Posts by Svede
United States, CA, Lemoore
Joined Nov 2008
That airfoil looks extremely thick, especially at the wingtips. The air doesn't have a chance to stay attached to the airfoil I'd guess. Which is what a stall is. Build it like a Stryker and I bet you it'll fly like one! 70-80mph is amazing. What power system are you using?
Svede is online now Find More Posts by Svede
Old Sep 28, 2010, 09:19 PM
Alfredo Rubio is offline
Find More Posts by Alfredo Rubio
Moderador.
Alfredo Rubio's Avatar
guadalajara, jalisco, mexico
Joined Sep 2002
Try with less elevon area.
Alfredo Rubio is offline Find More Posts by Alfredo Rubio
Old Sep 29, 2010, 05:09 AM
swami is offline
Find More Posts by swami
swami's Avatar
Ursel, Belgium, Europe
Joined Jul 2001
The whole area in between the rudders, and even a bit outside it due to the servo placement, provides no lift; only turbulence.
Furthermore; less elevon area indeed, better airfoil, less weight, better streamlining, ...
All that aside, it's a cool plane.
Dirk.
swami is offline Find More Posts by swami
Help! Stalling in downwind turns R2R Sailplane Talk 43 May 26, 2010 04:37 AM
Discussion Indoor Fun: Fast forward/Bank Turns/Piros/Nose-In/Tail-Ins with a Sub Micro EQMOD Micro Helis 8 Mar 18, 2009 04:44 PM
Build Log Thrust vectoring Eraider turns into TV stryker VIDEO added garrcass Flying Wings 18 Mar 14, 2009 04:45 AM
Question rudder turns without tip stalling help please? trashmanf Hand Launch 4 Dec 02, 2005 05:39 PM
HELP! Stalling on turns!!! DrummerboyBG Beginner Training Area (Aircraft-Electric) 17 Aug 29, 2005 12:05 PM
