Old Jan 19, 2015, 02:37 AM
France, Midi-Pyrénées, Fontenilles
Joined Mar 2014
F5B propulsion 6s vs 10s
Hi Guys,
I'm currently equipping an Avionik for some F5B FAI competition.
It seems that there are globally two families there : those who are running on 6S and those on 10S
I'm still wandering which one, I'll choose, do you have suggestions, ideas, advices ?
Thanks in advance
Regards
Erwitt is offline Find More Posts by Erwitt
Old Jan 19, 2015, 03:09 AM
stwilkie's Avatar
UK
Joined Oct 2003
I am just getting into f5b, my rw2b has just started arriving and I have a b-08 on its way. Both are 6s setups. However the consensus is that 10s is the way to go.
The biggest benefit is that the controller and motor are both working within their designed specs when running on 10s, the stresses are all win the expected norms. Whereas on 6s everything is getting hammered much harder.
That's what I have managed to glean from the mountain of information so far.
stwilkie is online now Find More Posts by stwilkie
Old Jan 19, 2015, 03:31 AM
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
That went fast. B08 on the way?!
When you say Avionik, which one?
You will struggle to fit in a 6S or lower cell count setup with big enough cells in the B12 onwards, it is made for 2 smaller packs (2200mah max) sitting behind each other. The B08 on the other hand was made to accept brick packs like 6S 3300mah. These practical problems will decide for you.
System efficiency wise, there is still no proof that 10S is better then 6S. You will see Patrick Hausler mixing it up with the top at the WC flying 6S. From my measurements even before 10S was legal, the 6S motor of the same size with the same power was running cooler. However it is true that the ESC has to work harder with the higher current of the 6S setups and there are not many ESC's out there that can take these currents (300-350A).
Inside our outside of manufacturers specs, it is no guaranty things won't burn!!!
Personally i am running 9S 1800mah as are a fair few other people. With the same motor you can run 10S and smaller props or save some weight and fly 9S with a bigger prop.
jjmouris is offline Find More Posts by jjmouris
Old Jan 19, 2015, 03:44 AM
Joined Mar 2014
it's a B08, so yes true that it seems easier to fit a 6S than 10S Lipo
Old Jan 19, 2015, 04:21 AM
stwilkie's Avatar
UK
Joined Oct 2003
Mr Burns's B-08 was looking for a new home and has the benefit of just needing a receiver to go fly so it became a no brainer. I have a new A-spec 4s pack sitting here waiting to mate to the airframe. Just need the weather to play ball now.
Old Jan 19, 2015, 08:48 AM
Austria, Stmk., Graz
Joined Sep 2013
Higher cell count is the way to go. Over all system load is reduced and a competitive setup with Neu 1512 (or the corresponding Leomotion) and Castle 120 HV is very affordable. Especially the Castle ESC should be bought second hand to reduce the costs even furhter.
Cheers
JAyThaRevo is offline Find More Posts by JAyThaRevo
Old Jan 21, 2015, 12:27 AM
Joined Mar 2014
thanks all for your help, I'll probably go for 10s with a Leomotion
Old Jan 21, 2015, 11:38 PM
The props of tomorrow
Varna , Bulgaria
Joined Feb 2007
I am selling competition 6S setup : NEU 1412 1,5D + CC180 big mod.Setup is very light.
PM if interested.
GeorgiMirov is offline Find More Posts by GeorgiMirov
Discussion Taft 90mm Viper 8S vs Taft 90mm Viper 6S vs Freewing 90mm Stinger 6S Top Speed racin06 Foamy EDFs 43 Feb 27, 2015 03:28 AM
Help! Alternative to Neu F5B 10s Brick Pack Mark Haigh High Performance 12 Jan 26, 2015 05:58 PM
Sold NEW - F5B / Castle Creations ICE Lite 200 amp 6S Lipo ESC Jaguar22 Aircraft - Electric - Power Systems (FS/W) 0 Jul 13, 2014 05:50 PM
Sold 10S F5B Neumotor setup: 1512 2.5d + ice2 160hv la528it Aircraft - Sailplanes (FS/W) 1 Nov 25, 2013 06:40 PM
For Sale Thunder Power Lipos, 12s(2x 6s) 4400's, 10s(2x 5s) 4400's, 6s 2700's VERY FEW CYCLES paulpeffly Aircraft - Electric - Batteries & Chargers (FS/W) 0 Apr 06, 2012 02:27 PM
