Old Aug 13, 2014, 12:58 AM
Altitude is my friend...
Depronicus's Avatar
Southern California
Joined May 2009
Originally Posted by johnnyrocco123 View Post
...BTW, I went with chinahobbyline 4s 3000mah 40C...
I have many of their 3000 and 3300 batteries, 40C and 50C. I'd say they're equivalent to Sky Lipo. They're fine, and Jason's service is excellent. He ships from his U.S. warehouse right away.
Depronicus is online now Find More Posts by Depronicus
Old Aug 13, 2014, 08:57 AM
Well, now that you know ...
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
All the guys that fly tail heavy, must be all over the sticks in knife edge.
Knife edge will tell you about your cg as well
Nope. Flew with very little mix. Go figure.
Bigster is online now Find More Posts by Bigster
Old Aug 13, 2014, 09:10 AM
3d NOOBular
3DNater's Avatar
USA, UT, St George
Joined Aug 2010
Guys I just want to mention... you can move the elevator servo forward if you want for lighter packs or just better pack placement. I did that on my last slick and it worked out pretty well. Just thought I'd throw it out there as an option. My first preference though would just be to use a motrofly and 4s 3000's with the servo in the normal spot.
3DNater is offline Find More Posts by 3DNater
Old Aug 13, 2014, 01:34 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
I use Thunder Power 4S 45C 3300's in mine, but they are as light as most other 3000's... Flies great IMO...
SteveT.
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Aug 14, 2014, 10:42 PM
wrecklessly misspeling stuff..
tuck's Avatar
United States, CA, Citrus Heights
Joined Feb 2009
Hmmmmm.. I wonder if that is what I did. I've not any issues with aft CG. And have been puzzled by all the talk of burying the packs under the cowl. My 2150mah strap centered over the landing gear.
tuck is offline Find More Posts by tuck
Old Aug 14, 2014, 10:51 PM
Registered Crasher
United States, TX, Coppell
Joined Feb 2011
Originally Posted by SteveT. View Post
Found here... and I have three kits in stock...
SteveT.
Cut me a deal on one for the 51 & bype and I may be into it.
jtaylor996 is offline Find More Posts by jtaylor996
Old Aug 14, 2014, 10:54 PM
SteveT.'s Avatar
San Jose, CA
I can do that.....
SteveT.
Old Aug 15, 2014, 07:07 AM
3d NOOBular
3DNater's Avatar
USA, UT, St George
Joined Aug 2010
You would know... the slot is just a lightening hole and is too long. You have to mod it a little. Also, the supplied push rod would be too short.
At least that is how I remember it.
Old Aug 15, 2014, 12:19 PM
United States, IL, Highland Park
Joined Apr 2011
3DN, can you post of pic of where you placed your servo further forward? I'm about to start my build (w/ Motrolfly & 4S, and likely 2800-3000 packs but haven't decided yet) and would be curious to consider this mod if it allows more flexibility in pack size, esp if only downside is longer pushrod on one servo (depending on how much longer)
brick1 is online now Find More Posts by brick1
Old Aug 15, 2014, 12:59 PM
3d NOOBular
3DNater's Avatar
USA, UT, St George
Joined Aug 2010
I think I posted some pics waaaay back in the thread when I did it. I had to add a little backing for the servo screws as well. Not a big deal, but could be a turn-off for some ppl.
Basically thete is a lightening hole in-line horizontally with the regular servo cutout. The slot is longer and narrower. It did take a little dremel work to get the servo case in.
I would recommend using a cf pushrod if you can work it out. That way the longer pushrod doesnt negate the effect of having the servo about 2 inches further forward. That being said, I used all-thread with dubro ball links.
Old Aug 16, 2014, 02:27 PM
tuck's Avatar
Joined Feb 2009
Yup the rod is too short, and I didn't measure the length of the slot. But I used the recommended servo slot.
Still wondering what is different about my V2 Slick. It balances perfect with plenty room to slide the pack fore or aft without any hassle.
Old Aug 18, 2014, 09:30 PM
Kerbob's Avatar
Knoxville, TN
Joined Apr 2008
so many pages.. so few videos.
C'mon guys.. post some videos so I can snicker at your flying skills.
Zach Galifianakis Laugh (0 min 23 sec)
Kerbob is offline Find More Posts by Kerbob
Discussion Need New 3d Plane from Previes gear. NoMercy 3D Flying 2 Jun 06, 2006 04:07 AM
New 3D planes from GWS? assib GWS (Grand Wing Servo) 4 Feb 24, 2005 12:34 AM
Sneak Peak At NEW 3D Plane from Dick Rankin thechosen1one Foamies (Kits) 5 Oct 11, 2004 01:27 PM
New 3D Planes from Fliton LTChip Parkflyers 1 Jun 19, 2003 02:17 PM
New "3D Aircraft" Discussion Group Proposal Tim H. Foamies (Kits) 1 May 02, 2003 09:57 PM
