Old Jan 28, 2016, 06:59 AM
Dakrat is offline
Find More Posts by Dakrat
Sky good, Earth bad!
Dakrat's Avatar
Anchorage
Joined Dec 2005
Help!
Esc's will not arm!
Ok guys,
I putting together the VTOL Mini-SkyWalker, during this build the Escs were not working (arming) correctly.
The Esc's - King Kong 12a http://www.banggood.com/KINGKONG-BLH...p-1002347.html
KK mini
Lemon 6ch ppm receiver. I have tried both in WPM and CPPM
I have read the manual Calibrated the ESC's, radio, gyros etc several times. Esc will arm by themselves sometimes while handling plane, have check connections they are solid. I thought that I FC in wrong orientation but I have confirmed it is Right - down.
I see that I can change the wpm rate but I thought that had to deal with aircraft stability and not arming, Also I have turn the safety arming on and off to see if that would work. My buddy and I worked on it last night but nothing! We fixed several thing I want fixed but we could not arm the esc's. They beep that they have power but not the beeps that they have counted cell count then arm, this is very frustrating. I have plug them directly into the receiver but they boot up just fine and work! The only thing I can think of is that they are High speed Blelhi?
Guys up a fellow out, I know this is going to be a simple fix that I am over looking....
Dakrat is offline Find More Posts by Dakrat
Old Jan 28, 2016, 09:52 AM
Ran D. St. Clair is offline
Find More Posts by Ran D. St. Clair
Ran D. St. Clair's Avatar
United States, CA, Sunnyvale
Joined Dec 2006
If the ESCs won't arm it is almost certainly because you are not providing them with a low enough low throttle input.
You say you are using a KK-mini, but you don't say what firmware you are using. If it is the stock HobbyKing KK-mini firmware then I can't help you, except to tell you what the problem is.
You are aparrently right on the ragged edge of providing a low enough throttle input as you say it arms sometimes.
I would go look at the basic flight controller setup in terms of giving the flight controller the proper range of signals that it needs, especially throttle. This will likely go back to your TX programming.
If you want to know for certain what I going on, I suggest you buy a servo tester with a digital Pulse Width readout. You can also do this with a scope if you have one. Servo testers of this sort are extremely useful in general, and worth having in your tool box for life.
I have not used this one myself, but it appears to have the necessary functionality:
http://www.hobbyking.com/hobbyking/s...o_Tester_.html
Ran D. St. Clair is offline Find More Posts by Ran D. St. Clair
Old Jan 28, 2016, 11:11 AM
Dakrat is offline
Dakrat's Avatar
Anchorage
Joined Dec 2005
Sorry, I am using version OpenAero-VTOL Firmware (V1.3), Thought that's what everyone was using here.
Now that I think off it here are some other details: DX9 radio, motors are blue wonder 1500kv and my template file
Old Jan 28, 2016, 11:49 AM
Joined Dec 2006
In that case, you need to go to the Receiver Inputs Menu and check all the values when you move the sticks. Throttle should go from 0 to 2000. Elevator, aileron, and rudder, should go from -1000 to +1000. The transition control input, usually a 3 position switch, should go from -1024 to 0 to +1024.
When OAV is disarmed, or the throttle stick is below 2.5%, motor outputs should go to 1ms pulse width. This is way below (more than adequate) to arm any reasonable ESC. If your throttle stick input does not go below 50 per the Receiver Inputs Menu, or you have the FC set to Armed mode, then this feature will not activate. Even so, for motor outputs the pulse width should go to 1.1ms at full low throttle stick, which is also plenty low to arm any reasonable ESC.
I note that you are in Armable mode.
You might temporarily set OUT1 and 2 to A Servo and connect a servo to make sure they are at least responding as you would intend.
Old Feb 13, 2016, 11:03 AM
Manny BUSTOS is offline
Find More Posts by Manny BUSTOS
Joined Nov 2012
Dakrat,
I had the same issue you were having. I switched from blheli to SimonK . That fixed the problem. If you already figured it out I just wanted to respond to let others know.
Manny BUSTOS is offline Find More Posts by Manny BUSTOS
Old Apr 13, 2016, 01:47 AM
JetJockE is offline
Find More Posts by JetJockE
Joined Sep 2006
Some ground station software defaults the throttle to "never arm" to make sure you don't spin the props on your desk or into your hands, monitor... whatever... when you're setting up your motors and ESCs.
Make sure after you set up your system, you go back in and program the speed controllers to arm with the throttle down (at a minimum), and you can opt for another function, like full right yaw (left stick in lower right corner of the gimbal aperture).
I set mine up the first time and forgot to reset the arming command and the ESCs wouldn't arm. Once I went back into the Groundstation program on my computer with my quadcopter connected and set my ESCs to arm at min throttle stick it worked perfectly.
JetJockE is offline Find More Posts by JetJockE
Help! Quanum Nova will Not arm/motors will not unlock alexrok Multirotor Talk 1 Jul 19, 2015 05:39 AM
Discussion E-Flite Pro 25 ESC - will not arm with Futaba 9C - Fixed Henna_Ojisan Power Systems 29 May 05, 2011 01:04 AM
Help! Eflite 40 ESC will not arm benja Beginner Training Area (Aircraft-Electric) 12 Mar 04, 2007 01:50 PM
tail esc will not arm with CSM gyro.. helifrek Micro Helis 1 Jan 03, 2005 11:32 PM
TMM-80 ESC will not arm... soholingo Power Systems 4 Nov 17, 2003 09:23 PM
