Old Feb 19, 2015, 08:39 PM
Shawndae is online now
Find More Posts by Shawndae
Building until we fly w\ Jesus
Shawndae's Avatar
United States, CA, Moreno Valley
Joined May 2011
Help!
KK2.1 Stability
Hey Friends. I am looking for some help with my second Quad build.
F450 size, 10 x 4.5 props using KK2.1 controller. All is up and running and I have had it off the ground about 30 inches. Not all that stable on takeoff or hover. If there was no extra weight on this quad I am sure it would be just fine but I have a brushless gimbal on front. I have moved the 2200 mA battery back a little to try and balance the front end weight of GoPro with Gimbal. My first quad is for playing but this one is only going to be used for video shooting.
Looking for someone to give me some advise on setting up the KK2 boards to be more stable to just hover for videos. As a total rookie quad pilot I want to set this quad up to be as dimear and stable as possible. I know how to set the data on the KK2 and I have played with all the different screens but I do not really understand a lot of the settings.
I am looking for someone to advise me on the best setting on the KK2.1 board to make this quad fly as a no frills simple stable video shooting system. Thanks in advance.
Shawndae is online now Find More Posts by Shawndae
Old Feb 19, 2015, 09:23 PM
mmelvis is offline
Find More Posts by mmelvis
United States, FL, Sarasota
Joined Aug 2014
Can you post your current settings?
mmelvis is offline Find More Posts by mmelvis
Old Feb 19, 2015, 11:38 PM
Shawndae's Avatar
Joined May 2011
Here is my current setting:
PI Editor
P Gain 250
P Limit 100
I Gain 250
I Limit 20
Stick Scaling
AIL 6
ELE 6
RUD 6
THROTTLE 90
Self Leveling
P Gain 100
P Limit 20
ACC TRIM ROLL 0
ACC TRIM PITCH 0
Old Feb 20, 2015, 09:50 AM
robca is online now
Find More Posts by robca
United States, WA, Kirkland
Joined Sep 2013
What firmware are you using on your KK2.1? the fact that you do not mention it, makes me think you are using the stock firmware (which is rather poor)
This is one of the best firmware available for the KK2.1 http://www.rcgroups.com/forums/showthread.php?t=2340156
There also is a dedicated thread for the KK2.1, so you might get more help here http://www.rcgroups.com/forums/showthread.php?t=2061620
robca is online now Find More Posts by robca
Old Feb 20, 2015, 11:42 AM
FiftySlicks is online now
Find More Posts by FiftySlicks
United Kingdom, Scotland, Edinburgh
Joined Jun 2014
Definitely upgrade the firmware if you haven't already.
At a glance, it looks like your P gain is far too high and your stick scaling is far too low. Both my gains and my stick scaling are around the 50-70 mark (limits are 20 or so). P and I gain are what fundamentally gives you stability, stick scaling is meant as a way of reducing the control authority so the sticks aren't over sensitive. Also check your transmitter doesn't have any expo/dual rates or the like set up.
Self level gain is independent of the others, 100 seems a little high, I'm around 40 or so as I don't like it to be too strong. Sort out the gains and stick scaling first though.
FiftySlicks is online now Find More Posts by FiftySlicks
Old Feb 20, 2015, 12:00 PM
reelflyt is offline
Find More Posts by reelflyt
reelflyt
Edmonton, Alberta, Canada
Joined Mar 2010
Hi.
To add in here . Make sure that your transmitter is in airplane mode not helicopter mode . Make sure that the battery balances the Gopro 100% .
PI editor
Aileron/Elevator
P Gain 50
P Limit 35
I Gain 20
I limit 20
Yaw Rudder
P Gain 60
P Limit 50
I Gain 25
I Limit 20
Stick Scaling
Roll 35
Pitch 30
Yaw 80
Throttle 100
Self Level
P Gain 55
P limit 45
These work for me .
Now go on YouTube and watch some videos on how to tune the KK 2 boards .
Gordon
reelflyt is offline Find More Posts by reelflyt
Old Feb 20, 2015, 12:45 PM
exnihilo is offline
Find More Posts by exnihilo
Joined Dec 2014
Does the kk have a USB port, or does one have to but a "device" for it?
exnihilo is offline Find More Posts by exnihilo
Old Feb 20, 2015, 01:29 PM
RC Madman68 is offline
Find More Posts by RC Madman68
RC Madman68's Avatar
United States, IL, Manteno
Joined Dec 2014
It has a LCD screen or I should say that most of them do.
No USB.
The benefit is that it is easy to change settings at the field without a PC/tablet or other device.
RC Madman68 is offline Find More Posts by RC Madman68
Old Feb 20, 2015, 02:36 PM
exnihilo is offline
Joined Dec 2014
Thanks for the answer. Let me rephrase, how does one update the firmware without a USB connection?
Old Feb 20, 2015, 03:00 PM
Shawndae's Avatar
Joined May 2011
Thank you so much guys - I knew I could count on you all. I will make the KK2 adjustments as you describe and move my battery to the best counter balance.
I will go through both links and do some reading before I take this quad out for a good test flight.
Yes this is my second KK2 controller. Both were brand new and I did not upgrade any firmware. I purchased some kind of USB interface for my Turnigy 9XR receiver to upgrade the firmware which I never used. I am unsure of this can be used to upgrade the firmware on the KK2.1.
Old Feb 20, 2015, 09:08 PM
reelflyt is offline
reelflyt
Joined Mar 2010
Hi.
You need a USBASP to program the KK boards .
Gordon
Old Feb 21, 2015, 04:46 AM
robca is online now
Joined Sep 2013
Something like this http://www.ebay.com/itm/6PIN-Wire-Su...-/321455871442
You need the "6 pin version". If you buy the "10 pin version" you also need a 10-to-6 adapter
http://blacktieaerial.com/2014/07/24...date-tutorial/
Old Feb 24, 2015, 03:54 PM
gigrl9999 is offline
Find More Posts by gigrl9999
Joined Dec 2014
q450 quad with KK215 oscillation problem
Hi guys,
i just finished building my 450 quad. I can't seem the get rid of these slow speed oscillations, and the quad also gains some altitude by its own.
i tried different combinations in the PI Editor. These are my current settings:
Roll (Aileron) and Pitch (Elevator):
P Gain: 35
P Limit: 100
I Gain: 30
I Limit: 20
Yaw (rudder):
P Gain: 80
P Limit: 20
I Gain: 70
I Limit: : 10
Self level settings:
P Gain: 60
P Limit: 60
Hight dampening: 0
Firmware is Steveis 1.9S1 (pretty old, am planning to flash it with latest 1.19S1)
I am flying it with self level ON because without it I crashed once and I'm afraid of crashing again .
Props are balanced.
Here's a video
q450 (0 min 36 sec)
Thanks!
gigrl9999 is offline Find More Posts by gigrl9999
Old Feb 24, 2015, 04:11 PM
cayuse is offline
Find More Posts by cayuse
Crash Test Dummy
cayuse's Avatar
Abbotsford, BC, Canada
Joined Nov 2001
gigrl9999, you are flying in a lot of "ground effect" in that room. Try to find a larger room with an unobstructed floor and walls that are far away to reduce the turbulence you are stirring up.
cayuse is offline Find More Posts by cayuse
Old Feb 24, 2015, 05:14 PM
reelflyt is offline
reelflyt
Joined Mar 2010
Hi gigrl9999 .
When you get it flying in a larger area please do a video of it , and post it so we can see .
Gordon
Mini-HowTo KK2 camera stabilization set up, updating firmware to 1.5 rctestbench Multirotor Electronics 44 Apr 17, 2015 09:01 AM
For Sale KK2 , KK2.1 , KK2.1.5 new and used yosemitez Aircraft - Electric - Multirotor (FS/W) 6 Nov 20, 2014 11:47 PM
Sold Two KK2 controllers. - KK2.1 1.5 & KK2 1.2 FC 747Pilot Aircraft - Electric - Multirotor (FS/W) 5 Jun 04, 2014 07:40 PM
Discussion Kk 2.0 (1.2, 1.5, 1.6); kk2.1; kk2.1.5 griesel Multirotor Talk 1 May 02, 2014 02:38 PM
Question KK2.1 Camera Stabilization Abolfazl Multirotor Electronics 1 Feb 11, 2014 02:09 AM
