Old Dec 18, 2014, 10:38 AM
Joined Dec 2014
Charge/Discharge lipos for storage
I have a Hitec X1 Touch charger.
Can anyone tell me how to Charge/Discharge a Lipo battery to the proper level for winter storage?
Thanks!
Ron
Rsmith0399 is offline Find More Posts by Rsmith0399
Old Dec 18, 2014, 10:45 AM
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
does it have a storage charge or a discharger function? set that to 3.8V/cell.
cmdl is offline Find More Posts by cmdl
Old Dec 18, 2014, 11:00 AM
Lake's Frozen Let's Fly
Rhea's Avatar
United States, MN, Eden Prairie
Joined Oct 2008
Use the Storage mode as shown in your manual.
Storage voltage should be between 3.7V to 3.9V per cell.
Rhea is offline Find More Posts by Rhea
Old Dec 18, 2014, 11:55 AM
Joined Dec 2014
Will the battery stay at that charge if stored in a cool place?
Old Dec 18, 2014, 12:06 PM
Germany, BY, BA
Joined Sep 2014
Yes - You can check the voltage, from time to time. Normally its not needed.
RNFLY is offline Find More Posts by RNFLY
Old Dec 18, 2014, 11:19 PM
Y=C+I+G
cmdl's Avatar
Joined Jan 2012
recommended temp is 45F.
any temp down to -20F is fine.
Old Dec 18, 2014, 11:48 PM
Joined Dec 2014
Is the same true for nimh batteries?
Old Yesterday, 12:08 AM
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
No. NiMH / NiCD type batterys should be charged fully for storage. Check periodically and top up if necessary.
LiPo need to be at 3.7 - 3.9v per cell storage but NiXX format should be fully charged.
Nigel
solentlife is offline Find More Posts by solentlife
Old Yesterday, 12:32 AM
Joined Dec 2014
Thanks everybody!
Old Yesterday, 12:41 AM
So. Cal.
What Nigel said, with one small adjustment - NiCd (and NiMH to a lesser degree) should be stored in a discharged state for best preservation.
Read here for more info on why: http://www.camlight.com/techinfo/techtips.html
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Yesterday, 01:33 AM
solentlife's Avatar
Joined Jan 2010
The subject of storage of NiMH packs is one that has two camps and they disagree ... Mark links to Camlight where they say store at 0.9v ... but the Energizer Manufacturing Co. say full charged :
Recommended Storage Conditions for Maximum Battery Performance
 Store at the lowest feasible temperatures (-20C to 30C being the generally recommended storage temperatures).
 Store batteries open-circuit to eliminate loaded storage effects (see next page).
 Store in a charged condition (except for large bulk volumes).
 Store in a clean, dry, protected environment to minimize physical damage to batteries.
Use good inventory practices (first in, first out) to reduce time batteries spend in storage.
It is generally accepted that NiXX chemistry cellls are far more tolerant of storage than a LiPo ... and NiXX are also regarded as easier to cycle after storage to recover ability. Both Camlight and Energizer mention cycling in fact.
I follow Energizer basically because a pal of mine was a Senior Tech with Mallory and it agrees with his chats with me ... but of course is no g'tee ...
Nigel
Discussion Can 1S Lipos In Parallel Be 3.85V Storage Charged? itsme2 Batteries and Chargers 2 Dec 16, 2014 12:30 AM
Discussion Lipo storage charge/discharge rates Bidwin Batteries and Chargers 1 Feb 27, 2013 12:38 PM
Discussion Lipo storage, charge, discharge ? mskeyspirate Batteries and Chargers 2 Nov 05, 2012 09:05 AM
Question proper way to charge lipos, discharge and storage pedaler Batteries and Chargers 7 Apr 20, 2009 07:58 AM
Discussion how are you guys discharging/charging your lipos to 50% for storage? soholingo Batteries and Chargers 19 Nov 07, 2007 01:26 AM
