Old Aug 06, 2014, 09:45 AM
Joined Mar 2007
Sailboat size in relation to water area and wind
Anyone check out what is the relation between sailboat to pool or pond. It would seem that smaller area smaller boat. What about light winds ? Does this mean smaller boat? Pond with light wind? Small boat? Large boat? How do you look at this? Thanks Ron
darticus is offline Find More Posts by darticus
Old Aug 06, 2014, 11:53 AM
Don't lie to my dog.
Gregg28's Avatar
United States, DE, Wilmington
Joined Jun 2005
Boat speed is a factor mostly of waterline length. A larger boat on a smaller pond may be a little tight. As far as the wind goes, a larger boat can handle light winds fine assuming it has sufficient sail area. Conversely, a smaller sailboat will always struggle in higher wind. A small boat in light wind on a smaller pond would be the ticket. Something like the Dragon Force 65 (25 1/2") would be about the limit in a pool in light air.
Gregg28 is online now Find More Posts by Gregg28
Old Aug 06, 2014, 01:07 PM
Joined Mar 2007
Thanks for your input very good. Ron
Old Aug 06, 2014, 04:00 PM
md6364's Avatar
United States, MN, Park Rapids
Joined Feb 2014
I don't feel size has much to do with it, other than how fast the boat would get from one side to the other. I think it would be more about the boats ability to maneuver.
md6364 is offline Find More Posts by md6364
Old Aug 06, 2014, 06:10 PM
Joined Jan 2006
Small ponds tend to be shallow so you need shorter keels which tend to be on smaller boats. Big water can mean big waves which larger boats handle better. Wind speed and the ability to cope with it is really more about matching sail area to the wind speed. RG-65 can easily be sailed in 30+ if you put small rigs on them.
slotracer577 is offline Find More Posts by slotracer577
Old Aug 06, 2014, 06:37 PM
Joined Mar 2007
Thanks all. Ever have to swim for your boat on a pond? Ron
Old Aug 07, 2014, 05:43 AM
Blackpool, Lancs
Joined Feb 2006
Sail boats can be considered to be scale models of something. As such, the wind and weather effects on the model conform to the square/cube laws of scaling. So a small boat on a large water for what is a pleasant day for a big boat can be something Biblical for a very small one, and a matter of survival rather than sailing. '65s are the ones that cut straight through that. Despite their small size, they just seem to perform better the more wind they get, but the long fin does mean that they need deep water.
mfr02 is offline Find More Posts by mfr02
Old Aug 07, 2014, 07:15 AM
Gregg28's Avatar
Joined Jun 2005
Absolutely!
RG65s (and Marbleheads, US1M and to some extent IOMs) do this because of their "ridiculously" long fin and low CG, resulting in high stability. A fifty foot "RG65" would draw 24 feet with a CG about 8 feet below the surface. That is a huge amount of stability.
Old Aug 07, 2014, 07:27 AM
Joined Mar 2007
I think the Dumas Star 45 and Equation fit that because their keels are deep. Thanks Ron
Old Aug 07, 2014, 07:33 AM
Gregg28's Avatar
Joined Jun 2005
They both can handle some breeze, but may be a little cramped in a pool.
Old Aug 07, 2014, 07:43 AM
Joined Mar 2007
I think too big for a pool but it has a long fin. The Equation has the longer of the two. Ron
Old Aug 07, 2014, 04:52 PM
United States, MO, St. Louis
Joined Jan 2014
Absolutely!
From RCSailing, "cludio" explains scaling, hence the reason for long fins and keels on RC boats. Basically direct scaling doesn't work:
http://www.rcsailing.net/forum1/show...y-MODELS/page5
"Scaling up or down :
- Linear dimensions are following directly the scale factor.
- Surface dimensions are following the square of the scale factor
- Volume dimensions go with the cube of the scale factor"
The Enigma is offline Find More Posts by The Enigma
Old Aug 07, 2014, 05:04 PM
Gregg28's Avatar
Joined Jun 2005
Or from Skene's Elements of Yacht Design. Stability goes with the 4th power.
Old Aug 21, 2014, 02:33 PM
heyharv
Joined Oct 2013
HI all, I am new to this site.
In regards to size and handling ability in different sailing area, yes the smaller boat will be more comfortable in smaller ponds however in regards to wind conditions on average the smaller boat performs quite well against larger boats. When the winds are very strong the heavier boat performs better. Claudio has right it is very hard to produce a scale sailboat that will sail ok. Our sailing club in Montreal often races 55Ē boat at 20 lbs with 1meter boats at 11 and 8 lbs and with a handicap start makes it interesting sailing.
I have developed a 1 Meter Dragon re drawn from the original Anker lines however modified for RC by trying to keep the look of the boat as scaled as possible. Considerations to keel depth, sail area and hull weight become crucial however it can be done and the results are quite impressive.
This dragon weight in at 8.2 lbs complete RTF and sails great even in heavy airs. It responds faster then the heavy boat and I am not a 100% sure but I think it points higher. The waters we sail are weedy and boats like IOM AC100 or any fin boat really does not sail very well in these waters. I think that boats under 1 meter are more fun in light air then heavy airs.
I will post a few pics and a video to show the performance of a smaller boat unfortunately I donít have them with me I am at work lololo.
heyharv is offline Find More Posts by heyharv
Discussion How To Fly In Wind / Forget Gyros, Forget Sims, Fly in Wind Dwayn 3D Flying 4 Mar 06, 2014 06:51 PM
Discussion slope site in SF Bay area for East wind? richtans Slope 2 Dec 31, 2013 01:53 AM
Discussion large expansion in water related jobs, Jim Thomerson Life, The Universe, and Politics 18 Feb 17, 2013 04:32 PM
Help! Frame Size in relation to Prop size? EyeFellOver Multirotor Talk 4 Mar 07, 2011 09:51 AM
Discussion Looking for someone with model related skills in the north Dallas area Thomas B Electric Plane Talk 0 Jul 26, 2010 01:50 PM
