Old Jun 08, 2014, 11:55 AM
Joined Apr 2014
Build Log
Pushy Galore
I am starting a close to scale version of Pushy Galore. The wings and tail are foam board and the body is Styrofoam. The inspiration was that I have a 4100KV motor with 3.75" 3 blade prop that is currently on my FT22 but it gets way to much dirty air so I know my efficiency is very low. The whole plane has way to much drag so I was looking for a very clean, light pusher and I have liked Pushy Cat/Pushy Galore since I was a teenager so thought I would give it a try. According to the online calculators I used it should be able to crank out some serious speed!
Wing Span 22"
Length 16"
Weight 270 grams (Estimated)
It is being covered with 3/4 oz fiberglass and Polycrylic. The test piece I did had 2 layers of glass, 5 layers of Polycrylic, 3 layers of paint, a clear coat and weighed almost identical to foam board with the paper left on! I was very happy with the strength as well.
Fitting everything inside has been very challenging as there is very little room but I think I have it all good now. I will post more pics as I go.
jjstanley is offline Find More Posts by jjstanley
Old Jun 08, 2014, 05:00 PM
Fremont, CA
United States, CA, Fremont
Joined Jan 2009
It sure looks nice!
djacob7 is offline Find More Posts by djacob7
Old Jun 08, 2014, 08:56 PM
SG Talon... Super Genius.
Lenox, Michigan
Joined Nov 2005
I once bought a 48" Span Fiberglass over Balsa Pushy Cat at the Toledo Show Swap. And I never put it in the air. It was too beautiful! I ended up selling it unflown and regretted it.
I love the Pushy Cat style planes though. So cool.
SGTalon is offline Find More Posts by SGTalon
Old Jun 15, 2014, 01:01 AM
Joined Apr 2014
Finally got a bit more done. I have 1 layer of fiberglass on the wings and the body is getting close to being ready to add fiberglass. I couldn't keep it quite scale as I could not fit everything in the body so had to make it a bit more boxy. Pushrod for the elevator is installed and both servos are ready to install.
Old Jun 15, 2014, 01:30 AM
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
Nice work! Quite the transformation from rough carved to sanded. For some reason the original "Buck Rogers" series popped into my head with it sitting in this state.
Granted is online now Find More Posts by Granted
Old Jun 28, 2014, 12:44 AM
Joined Apr 2014
I haven't had much time for this but I did get the motor mount installed and some more fiberglassing done tonight.
Old Jun 28, 2014, 03:52 PM
Joined Apr 2013
Pretty airplane and nice craftsmanship in the build.
At only 22 inch span, you might find it very challenging to fly. The combination of low Reynolds number and potentially high-ish wing loading may also give it a high stall speed.
If you're willing to deviate from scale, you might consider adding strakes at the root and having a somewhat larger-than-scale canard.
nuteman is online now Find More Posts by nuteman
Old Jun 30, 2014, 12:10 AM
Joined Apr 2014
The bottom fuselage with motor and ESC installed. Air vents cut for the motor.
Old Jun 30, 2014, 12:11 AM
Joined Apr 2014
Wings glued to the bottom fuselage. Aileron servo installed in the wing.
Old Jun 30, 2014, 12:13 AM
Joined Apr 2014
The elevator servo installed in the upper fuselage. A pushrod goes up through the tail.
Old Jun 30, 2014, 12:18 AM
Joined Apr 2014
Upper fuselage attached to wing and lower fuselage. Now I will continue with filling and fiberglassing. The canopy will be cut out last.
Old Aug 04, 2014, 04:28 PM
Joined Apr 2014
Finally getting a bit more done!
The body all has at least 2 layers of fiberglass and some parts have 3 layers. After that it has painted many times with a mixture of Polycrylic and drywall mud. I sanded with emory cloth between each coat. Number of coats varies between 3 and 7 depending on how much it needed. It could have used even more but got tired of doing it to be honest. I really want to fly it!!
Ready for paint.
With 2 coats of paint.
Old Aug 04, 2014, 04:35 PM
Joined Apr 2014
I was a little worried about if I would have enough throw on the ailerons with my unique linkage but they move LOTS. I will need to use lots of expo!
Old Aug 10, 2014, 04:21 PM
Joined Apr 2014
I believe it is ready to fly now! I have not had a chance yet but hopefully soon.
Old Aug 11, 2014, 10:20 AM
Joined Apr 2013
Looks great!
Good luck on the maiden flight.
Looking forward to video
Latest blog entry: My youtube channel
Meet My Pushy Galore nolasco Scratchbuilt Indoor and Micro Models 18 Jul 01, 2002 04:56 AM
Pushy Galore ideas nolasco Scratchbuilt Indoor and Micro Models 16 Jun 16, 2002 11:15 PM
Pushy Galore Ideas nolasco Power Systems 1 Jun 14, 2002 09:53 AM
Pushy Galore 3-Views? nolasco Electric Plane Talk 4 Jun 07, 2002 08:05 AM
HELP!Building Pushy Galore plan by Franz Schmid GRE66 High Performance 1 Oct 10, 2001 05:13 PM
