Old Aug 08, 2014, 08:36 AM
Tucson, Az
Joined Feb 2007
I have a bl motor for a V100D03bl. Looks like C05m but has thicker shaft. If I can find a 8T/9T pinion to fit give it a try in Mini c/p. I had esc/ motor hooked up to Genius c/p for testing and motor seemed pretty strong. i also have V100D01 inrunner also. that motor was very happy when tested. Kinda tall and heavy but why not try it ?
dankar04 is offline Find More Posts by dankar04
Old Aug 10, 2014, 10:07 AM
Tucson, Az
Joined Feb 2007
My bl Mini is a year old now and has Wow bl kit installed. It has flown alot and held up great. One servo wire came out and replaced servo. Need to put new conector to rx on old servo as sure its still good. My other Mini is newer version and flys quite well. I have a third from trade and it flys fine but motor isn't that strong and its a V1. It flys well and for time being good nuff. To many irons in fire anyway to upgrade it to bl. These are great helis for small places.
Old Aug 21, 2014, 12:06 PM
Joined Aug 2014
Mini CP issues
After not getting round to fitting the servo saver mod i broke my servo.
Fitted a new one today, powered it up and the servo i fitted is dead. No movement. Do i need to do something to register it or am i just unlucky and it's faulty?
Checked connector in the same with same colour code pattern as other on control board. No twitching or movement from this servo on power up.
help!
TIA
captain_ken is offline Find More Posts by captain_ken
Old Aug 21, 2014, 01:15 PM
i812's Avatar
Joined Aug 2009
Servo replacement is simply plug n play.
To troubleshoot, I'd plug one of the other known good Servos in that RX's questionable Servo Connector, and/or plug that questionable Servo in one of the other known good RX Servo Connectors.
i812 is offline Find More Posts by i812
Old Aug 21, 2014, 01:38 PM
Tucson, Az
Joined Feb 2007
Agreed just try another servo. Unplug another and put in Rx to see if connector is bad in RX. You need a lite touch removing plug from RX. I just replaced pitch servo that was hunting badly. Took two old servos and made one good one.
mini is nice indoor bird. I never had bad servo fresh out of package.
Old Aug 21, 2014, 01:56 PM
Joined Aug 2014
good idea, ill try one of the other working servos in a moment, I ordered 2 servos here so they both can't be faulty, will report back my findings.
Thanks to both of you for your prompt responses and advice, most appreciated!
Old Aug 22, 2014, 09:57 AM
Tucson, Az
Joined Feb 2007
The connector are easy to have wire seperate. This happened to my Mini. Worked perfect next thing no alieron. I was able to fly it down with out problem.
Hope you get it working as good practice heli. I have one with C05m/ and hope to put HP05 in another and see what I have.
Old Aug 22, 2014, 10:20 AM
soonglim's Avatar
Joined Sep 2012
HP05 with double-FET xp-3a esc with BLHeli and 7mm tail for me so far is the best bl combination for the mini cp. Short or add a parallel resistor to the LVC resistor to avoid the control board shutting the heli down prematurely.
soonglim is online now Find More Posts by soonglim
Latest blog entry: V120D02S with 130X Main Gear
Old Aug 23, 2014, 11:32 AM
Tucson, Az
Joined Feb 2007
I have a new motor from V100D03bl. Shaft is thicker 1.5mm. CJ listd them, but some of his stuff is not correct. Ordered frame for my Scopion Y-6 and got frame for Lasybird. They are different. His add is wrong. Ordered esc for V100D01 main , he sent tail esc. He did replace it but that esc lasted two minutes. finally he had them on add and bought another. Since then over 100 flights onn it and no issues.
The 03 bl motor ran with my ESC. Now either make stock pinion work or find 1.5 mm pinion that will work. The 03 bl is taller than C05m. Have no idea what are the specks. I also have C05m. My Minoi bl has C05m and flys well.
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9799 Jul 11, 2014 12:28 PM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 14 Apr 15, 2014 12:24 PM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 11:38 AM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 07:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
