Old May 01, 2015, 02:54 PM
Rclover23549 is offline
Find More Posts by Rclover23549
It's never done that before...
Rclover23549's Avatar
United States, NY, Dewittville
Joined Aug 2012
New Product
Eflite Micro Radian FPV
E-flite® UMX™ FPV Radian® (EFLU6780)
A More Immersive RC Experience
UMX FPV Radian BNF w/o Headset
Key Features
AS3X® technology provides outstanding stability and smoother flight
Spektrum™ VA1100 ultra micro FPV system (included)
Fat Shark 5.8GHz FPV headset compatible
3-channel control for easy-flying and friendly soaring characteristics
One-piece, removable wing with carbon fiber support
Ultra-lightweight foam construction
Transparent, folding propeller blades (installed)
Efficient coreless brushed motor system (installed)
Spektrum 5-channel DSMX® receiver/ESC/servo unit (installed)
150mAh 1S Li-Po battery powers the flight system and camera
USB 1S Li-Po charger (included)
Ideal for outdoor and larger indoor flying sites
Overview
The First-Person View (FPV) experience is all about getting the sensation of flying a full-scale aircraft with your feet safely on the ground. The complex electronics needed to make a working system often requires a high level of expertise and a critical arrangement of components. But now there’s a simpler way.
The FPV UMX™ Radian™ aircraft is an evolutionary first-person view platform that combines a great flying airplane with easy-to-use ultra micro electronics so you can put yourself in the pilot’s seat. AS3X® technology features stabilization capabilities that reduce the effects of wind and turbulence so flight performance is as smooth as possible. Proportional 3-channel control makes maneuverability simple and an efficient power system delivers impressive climb performance. All combined, you get an RC experience that’s so immersive you’ll feel like you’re flying in a full-scale aircraft. So if you’ve ever wanted to have the view from a flying model airplane, now is your chance.
FPV Camera System
The Spektrum™ VA1100 ultra micro airborne FPV system is ready to be installed on the airframe and is compatible with any Fat Shark 5.8GHz FPV headset or video monitor. It’s a 2-in-1 camera/transmitter unit featuring a circular polarized antenna for superior range and is powered by the included 150mAh 1S 3.7V 25C Li-Po flight battery.
Stable Platform
Engineered around the renowned stability of the original ParkZone Radian® motor glider, the UMX™ FPV Radian aircraft is an ideal fixed wing first-person view platform that’s versatile enough to fly outdoors and in large indoor spaces.
Transparent Propeller
Transparent blades allow the camera view to be as clear as possible. For maximum glide efficiency when the motor is off, the propeller blades fold backwards.
Removable Wing
Two screws secure the wing which can be removed for easy transport and storage.
Li-Po Battery
The included E-flite® 150mAh 3.7V 1S 25C Li-Po flight battery can be charged with the included charger that works from any USB power source.
BNF Convenience
All you need to start flying the UMX™ FPV Radian® is 4+ channel transmitter with Spektrum™ DSM2®/DSMX® technology and a Fat Shark FPV headset that’s 5.8GHz compatible, or a compatible video monitor.
Product Specifications
Wingspan: 28.7 in (730mm)
Overall Length: 16.5 in (418mm)
Flying Weight: 1.75 oz (49g)
Motor Size: 8.5mm coreless brushed motor
Radio: 4+ channel minimum
CG (center of gravity): 29mm back from leading edge of the wing
Charger: 1S USB Li-Po Charger, 300mA
Experience Level: Intermediate
Recommended Environment: Indoor/Outdoor
Assembly Time: Less than 1 Hour
Is Assembly Required: Yes
Needed to Complete
Recommended
Requires a full-range 4+ channel transmitter with Spektrum™ DSM2®/DSMX technology and a Fat Shark 5.8GHz compatible FPV headset or video monitor
Due Late June 2015
Link to page- http://www.e-fliterc.com/Products/De...=EFLU6780#home
Rclover23549 is offline Find More Posts by Rclover23549
Old Jun 28, 2015, 12:38 PM
wrongler is offline
Find More Posts by wrongler
United States, NY, Brewerton
Joined Jan 2011
lipo
Anyone found a good lipo for the added weight of the camera? Any tips on making it glide better?
wrongler is offline Find More Posts by wrongler
Old Jul 08, 2015, 02:16 AM
ralfrcgroups is offline
Find More Posts by ralfrcgroups
ralfrcgroups's Avatar
Germany, NRW, Langenfeld
Joined Oct 2011
Still testing batteries...
See this thread: http://www.rcgroups.com/forums/showthread.php?t=2403579
ralfrcgroups is offline Find More Posts by ralfrcgroups
Sold UMX Eflite RADIAN Glider BNF BIGAIR Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jan 05, 2015 10:38 AM
Sold eFlite Radian UMX DenverJayhawk Aircraft - Electric - Airplanes (FS/W) 2 Jan 02, 2015 10:17 AM
New Product FPV Vapor BNF without Headset by Eflite: Horizon's first FPV pre- installed micro! Julezwatts Micro Ready-to-Fly 0 Aug 28, 2014 08:42 PM
Discussion PZ Artizan & Eflite UMX Radian & EFlite Allusive HaventFlownSince2014 Atlanta Area RC 7 Jan 29, 2014 08:08 PM
