Old Feb 14, 2015, 10:59 PM
steveciambrone1 is online now
Find More Posts by steveciambrone1
United States, CA, Castaic
Joined Jun 2014
Build Log
1/200 Battle Ship Missouri R/C Conversion
The Trumpeter USS Missouri was a build I could not resist, I have already built a 1/200 Yamato from a plastic kit and it runs very well, but to confess I only built it because there was not an comparable Iowa class battleship available at the time.
My plan is to power the model the same as the Yamato with 4, 7.2volt speed 400 motors. This provided good power and with a bit extra speed to get the ship out of trouble should it arise.
I also confess I am not a fan of Japanese warships mostly because they were not American and there navy was inferior to ours, any arguments to the contrary, needs only a simple reply of "they lost the war".
I will be first covering the conversion to R/C, and maiden run in the water, less the superstructure completed. A friend from work who is a well accomplished static modeler and builds to a much higher standard than I, will take on the remainder of fitting out and detailing the model. He will actually be building two, one for him as a static model and mine as a radio control working model. He likes to build models.
Steve
steveciambrone1 is online now Find More Posts by steveciambrone1
Old Feb 14, 2015, 11:10 PM
babblefish is offline
Find More Posts by babblefish
Yes, that is Jamie
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
This is going to be fun...
Wish I could still get MEK, but they pulled it off the shelves around these parts.
babblefish is offline Find More Posts by babblefish
Old Feb 14, 2015, 11:32 PM
Joined Jun 2014
Stuffing tubes
I chose to use 3/32 inch stainless steel for the propeller shafts, this worked well with the G Factor propellers since they are cast in brass with an approximately 3/32 hole in them. I glued the propellers to the shaft with JB weld epoxy.
The inner tube for the stuffing tube is brass 1/8 K&S along with all the rest of the brass and stainless materials, my usual way to make tubes it to have short lengths of the smaller diameter tubes to act as bearing surfaces and the majority of the stuffing tube one size bigger to support the ends, but with this model it was not possible. I made the propeller end long so to maintain the scale appearance of the two outer propeller shafts and the two inner shafts which run through the long fin structures.
To install the shafts the two inner fins had to be drilled to 1/8 inch, to make them fit better I also used a 1/8 ream. I carefully drilled and reamed the outer shafts support structure to the same size. The outer stuffing tube bearings were cut to length and deburred, the length was cut to make the tube long enough for about a1/2 inch remained inside the hull so the inner tube could be bonded on later. The tubes were glued in with CA, the sealed inside the hull with contact cement based sealer, the name brand was Welder bought from Walmart, there are other brands like it. Silicone sealer could be used but I just do not like using it.
I made the inner stuffing tubes with 5/32 brass tube and had a 1 inch section of the inner tube to act as a bearing, I added oiling tubes by using an aircraft wheel collar and drilling out the threaded hole to accept a brass tube of short length and another longer tube over it to act as a reservoir for the oil. It was all soldered to gether and the cleaned. The inner portion was glued with JB Weld to the fitted outer tubes, to complete the stuffing tubes. The motor were glued in and short lengths of stainless rods were used as intermediate shafts with silicone tube u joints at each end. This allowed a shallow and near straight line for the shafts.
Old Feb 15, 2015, 12:40 AM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Awesome Steve!
Kmot is offline Find More Posts by Kmot
Old Feb 15, 2015, 12:43 AM
Joined Jun 2014
Thanks, I have been on too much travel the last two years, it feels good to be in the shop working on a new model.
Steve
Old Feb 15, 2015, 12:44 AM
Kmot is offline
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
It looks like the propellers are counter-rotating on the inner set. Same with the outer set?
Old Feb 15, 2015, 01:11 AM
Joined Jun 2014
Yes, they are actually brass castings made from the kit plastic ones provided. The two port propellers are counter rotating from the starboard side. Should track straight, the inner two are 5 bladed and the outer two are 4 bladed.
Steve
Old Feb 15, 2015, 03:25 AM
Harquebus is offline
Find More Posts by Harquebus
I see all your typos
Harquebus's Avatar
South Korea, Gyeonggi-do, Ansan-si
Joined Jan 2006
Oh, indeed. A definite moment.
I admire your use of drilled-out wheel collars for your shaft oilers. That's an easier method than to just join two pieces of tubing together and solder. It seems to be a little more robust and you have perfect angles.
Interesting use of 'intermediate' shafts there. Don't recall ever seeing that but they're essentially dual universal joints and I see why you have them. Have you considered going all out and actually utilizing some miniature universals?
Finally, good to see the usage of G-Factor props. Originally intended for static display, this should prove interesting to see how well they work. They're not soft in any way, are they?
Harquebus is offline Find More Posts by Harquebus
Old Feb 15, 2015, 03:40 AM
herrmill is offline
Find More Posts by herrmill
Shanghai'd Expat
herrmill's Avatar
Xiaoshan, China
Joined Jun 2006
Looks like a nice project. You'll want to consider their new HMS Nelson/Rodney to round out the fleet. My LHS in Hangzhou has the Missouri, Iowa, Arizona & Bismarck in stock along with the smaller Sovremmenny & PLA 051 DDG & I always have to pause to look at the box art whenever I'm there.
I started building RC warships in that scale with the Nichimo Yamato, Akizkuki & Hatsuzuki, Tianjie Takao & Trumpeter Sovremmeny. As with many other hobbyists, the majority are still sitting in my stash for that but my eyesight has grown too bad over the past few years to work on such small detail.
herrmill is offline Find More Posts by herrmill
Old Feb 15, 2015, 07:57 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Wear an Optivisor... amazing how much better you'll see!
patmat2350 is offline Find More Posts by patmat2350
Old Feb 15, 2015, 11:56 AM
Joined Jun 2014
the G
Factor props seem to be robust enough, not soft, I had to open up the casting for the propeller shaft a bit and they did not flex or bend any.
I thought about commercial u joints but wanted to keep cost down and finding them is always an issue.
All the motors are from my used parts bin or what I had on hand. 3 of the motors are from a once proud JU 52, that met its demise one day.
The Rodney has such an odd look to it, I would prefer the Hood. I have been thinking about picking up a Bismarck though.
Steve
Old Feb 15, 2015, 05:51 PM
DDG 51 is offline
Find More Posts by DDG 51
DDG 51's Avatar
EUrope
Joined Apr 2008
Missouri is a beautifull kit. I get it on end of last year. Quaity is excellent
DDG 51 is offline Find More Posts by DDG 51
Old Feb 15, 2015, 07:37 PM
Joined Jun 2014
I fabricated brass rudders with a 1/8 inch shaft and .030 brass sheet a slot was cut into the shaft and then the rudder was solder to it. Sheets of plastic were stacked together and glued to the rudder area. The holes for the scale rudders were filled in with a plastic and glued, the holes were then sealed over with the Welder glue.
The rudder tube holes were drilled and the tubes glued in, then sealed with Welder glue.
The rudder servo was installed and linkages ran to the rudder arms.
Steve
Old Feb 16, 2015, 12:57 PM
Joined Jun 2014
I installed a antenna tube in the bow section. I intend to use my Nautical Commander radio for this model, twin throttle will work well with this type of model.
I cut the rear deck about 1/2" forward of the bases of the seaplane catapults, giving enought access to the rudder area and the rear gun tubs can be permanently sealed increasingly the effective freeboard of the model. I cut the deck from the bottom with a rotary Drexel razor saw about 80-90% through and then snapped it to break it clean. A little clean up with a sanding block was all that was needed. When mated the joint line is barely noticeable. I made retaining blocks from some 1/2" Plastistruc hollow tube, glueing them to the inside of the hull. I marked the location on the deck and after placing the deck on the hull drilled 1/16" holes through the deck and retaining blocks. This was done to ensure both holes would match, without and difficult measuring and inaccuracy. The deck holes were then opened up for clearance of the 2-56 hex head screws. The retaining blocks were then threaded to accept the screws.
The boat in now transferred to Johns shop for the below the waterline cleanup prep and paint prior to a shake down cruise. When I get it back just the below the waterline paint will be completed, this was done since during the cruise the shafts and rudder tubes will have to be oiled and this could be a problem getting them cleaned and degreased good enough for the paint to stick.
Steve
Old Feb 16, 2015, 05:42 PM
CaptDH is offline
Find More Posts by CaptDH
BUILD SOMETHING!
CaptDH's Avatar
United States, CA, Avalon
Joined Oct 2002
Look at those tiny speed 400's in there! That hull is a monster! As for the G factor props, several guys have used them for the Schnellboot and they are really working to get that hull planing.
DH
CaptDH is offline Find More Posts by CaptDH
Discussion 1/200 Trumpeter Missouri BenjaroX Scale Boats 135 Jul 11, 2015 07:57 PM
Discussion Barnstormers R/C Club Dexter Missouri Fun Fly hrwatson68 Combat 0 Sep 20, 2014 07:57 AM
Discussion motorising kit for 1/200 Missouri rondean1 Scale Boats 2 Nov 28, 2013 01:49 AM
Discussion trumpeter 1/200 Missouri kit rondean1 Scale Boats 12 Nov 23, 2013 03:54 AM
Build Log 1:200 IJN Kitakami (R/C model convert from Answer paper model ) IvanYuen Scale Boats 6 Dec 23, 2006 03:16 PM
