Old Jul 24, 2014, 12:29 PM
Joined Jul 2014
help with s107g repair please
hello, im new to to rc helicopters, so i thought i would purchase a syma s107g to learn how to fly propperly before i purchase a bigger one. unfortunately i crashed it almost immediately and one of the gears snapped. i purchased some replacement parts and managed to replace it.
however when i was putting the thing back together the top rotor no longer stays on when i try to screw it back in place and just pops off. also the bottom rotor looks higher then the other pictures i see of the same helicopter online. but im pretty sure it came like this as i didnt move the bottom one about when i went about replacing the broken gear. i have no idea why the thing won't stay on. any suggestions or help would be much appreciated, as my only other alternative is to purchase another and keep this for parts.
forgot to mention this was purchased on ebay froma chinese seller, which may explain why the bottom rotor looks higher up then it should be or could be i just messed up somewhere when reassembling it. i've attached a picture to illustrate the problem.
firefly82 is offline Find More Posts by firefly82
Old Jul 24, 2014, 03:01 PM
Master Of My Universe
scotsoft's Avatar
Newcastle, UK
Joined Jul 2010
If you have a look through the S107 thread you will find pictures showing you what you need to know
http://www.rcgroups.com/forums/showthread.php?t=1176146
scotsoft is offline Find More Posts by scotsoft
Old Jul 24, 2014, 05:09 PM
Joined Jan 2014
The top blades are held on with the set screws. Loosen them or even remove them the holder will then slide onto the shaft, then tighten the set screws. Its possible your shaft isn't going past the screws and it is just setting on top. Also make sure the gear is on the shaft at the bottom far enough. The crosshatch on the shaft holds the gear on it can be moved by holding the gear and turning the shaft (like a screw).
bilderberg is offline Find More Posts by bilderberg
Help! walkera v120d02s help pleas cowboys518 Micro Helis 7 Mar 18, 2014 09:53 PM
Help! Mcpx brushless conversion PLEAS HELP ME Newbie77 Beginner Training Area (Heli-Electric) 3 Nov 19, 2013 05:35 AM
Discussion Plea for help with HS-85MG gears... wylchyl Hitec/Multiplex USA 11 Sep 04, 2008 10:01 AM
Discussion Pleas Help me with walkera 36 WK-0701 Tx kaushiksad Simulators 1 Dec 03, 2007 06:26 PM
Help With Charging Li-Po's With Triton Charger Pleas? Synthetic Batteries and Chargers 13 Dec 17, 2004 08:08 PM
