Old Nov 21, 2012, 09:36 PM
United States, CA, Oak View
Joined Jul 2012
tamiya cc01 gears grinding fix
ok my cc01 unimog was making grinding noise i knew it was the spur gear
but it wasn't hopping and i found the fix for anybody who has the same problem
because it was a real pain in the
chaosmaker159 is offline Find More Posts by chaosmaker159
Old Nov 21, 2012, 09:41 PM
Joined Jul 2012
how i fixed it the pinion gear on the cc01 doesn't completely cover the spur gear
and the screw that holds the pinion was just barely touching the spur gear and was
clicking so i took the motor mount of and slid the pinion down and tighten it down
and it fixed it
Old Dec 05, 2012, 09:37 AM
Centeral Florida
Joined Apr 2010
Thanks man!!
Just-in-skin is offline Find More Posts by Just-in-skin
Old Dec 31, 2012, 04:59 AM
Joined Dec 2012
my tamiya cc01 is making a grinding noise also with a loud wining noise i think its coming from the rear diff does anyone know how to fix this problem
luka.v is offline Find More Posts by luka.v
Old Dec 31, 2012, 11:27 PM
Joined Jul 2012
most of the time when mine started grinding it because the spur gear is hoping make sure the spur gear is in there good no loseness my gear had a warped in it and caused it to grind when i got a new gear set i put little bit of hot glue in the spot where the spur gear sits and put the spur gear in and let it dry so the shaft dosent shift and no it never grinds even in high stress and in
Old Dec 31, 2012, 11:32 PM
Joined Jul 2012
if its in the rear axle look and see if there is a bushing there there were the shaft ends and after were the gear sits
Old Dec 31, 2012, 11:34 PM
Joined Jul 2012
make sure it not to tight were its grinding post a video
Old Jan 01, 2013, 04:23 AM
Joined Dec 2012
now i remember what may be causing the trouble i took it to the beach a while a go but sand may have got into the gearbox causing the grinding sound
Old Jan 01, 2013, 10:23 PM
Joined Jul 2012
maybe i dont think thats the problem i mud bog mine stock and took it to the snow and it dosent grind for me
Found wtt tamiya cc01 for lipo charger and lipos nick84 Cars - Accessories (FS/W) 2 Sep 24, 2012 10:11 PM
Wanted Wanted: Tamiya CC01 or CR01 mxaexm Cars - Trucks and Parts (FS/W) 0 May 20, 2012 09:04 AM
Wanted WTB Tamiya CC01 or CR01 mxaexm Cars - Cars and Parts (FS/W) 0 May 17, 2012 08:51 PM
Discussion tamiya cc01 fj cruiser igotit Off-road Cars 18 Sep 11, 2010 02:05 AM
