Old Jan 10, 2015, 02:24 PM
fATAL's Avatar
United States, GA, Augusta
Joined Dec 2014
Question
Charging
So its okay to charge a 5000 mAh battery @ 4amps correct safe is 5 amps so 4 is safe or will it be a negative impact to battery life.
fATAL is offline Find More Posts by fATAL
Old Jan 10, 2015, 02:40 PM
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
why would it have a negative impact to charge at a lower rate than 1C?
cmdl is offline Find More Posts by cmdl
Old Jan 10, 2015, 02:51 PM
fATAL's Avatar
Joined Dec 2014
It shouldn't but i was asking to be sure.
Old Jan 10, 2015, 03:13 PM
United States, OR, Canby
Joined Aug 2011
It's OK to charge slower.
600Bob is offline Find More Posts by 600Bob
Old Jan 10, 2015, 03:23 PM
Y=C+I+G
cmdl's Avatar
Joined Jan 2012
i see. someone had posted on another thread about higher charging rates affecting lipo life (which is also not true), so i was trying to ascertain the source of their information. you did not read this somewhere, right?
Old Jan 10, 2015, 03:27 PM
fATAL's Avatar
Joined Dec 2014
I think I read similiar posts about the risk of fires when charging over 5 A on 5000 mAhs.
That isnt true?
Is there a voltage limit to lipos what if i wanted to charge 24V @ 5A
Old Jan 10, 2015, 03:35 PM
Y=C+I+G
cmdl's Avatar
Joined Jan 2012
no risk with charging at higher than 5A. read: http://www.rcgroups.com/forums/showthread.php?t=1754232
in particular, read what everydayflyer posted in that thread.
Old Jan 10, 2015, 03:44 PM
So. Cal.
I know folks who charge their 5000mAh lipolys at 40A. They'd go higher but that's the limit of their chargers. Some 5000mAh lipolys are rated to be charged as high as 60A: http://www.thunderpowerrc.com/Produc.../TP5000-6SPF70
mrforsyth is offline Find More Posts by mrforsyth
Old Jan 10, 2015, 03:51 PM
Joined Aug 2011
That isnt true?
Yes there is a voltage limit. Lipo cells are never charged at more than 4.2v per cell. So a 6s would have a max charge voltage of 25.2 volts. Use that voltage on a 3s battery and you have a fire.
Old Jan 10, 2015, 03:54 PM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
That isnt true?
If a reliable charger is used virtually any battery can be charged at 2C, even 3C.
The voltage you charge at is dependent on the number of cells in the battery pack.
1S = 4.2V
2S = 8.4V
3S = 12.6V
4S = 16.8V
5S = 21V
6S = 25.2V
7S = 29.4V
8S = 33.6V
The charge current is dependent on the rating of the individual pack. Usually indicated by the mah of the pack. So a 5000mah pack can be charged at 5A. A 1S 5000mah can be charged at 5A. A 8S 5000mah can be charged at 5A.
Of course the limitation is determined by the power and specifications of the charger.
BTW a little punctuation would make your questions a bit more readable.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Discussion Over-Charged but not puffy. new battery (first charge) bopchong Batteries and Chargers 5 Jan 01, 2015 10:33 AM
Discussion The Accucel 6, Fast Charge and Storage Charge - Does the Balance Work? hoppy Batteries and Chargers 2 Nov 29, 2014 09:24 AM
Discussion 5' charging, 10,00 charge cycle for Li-Ion cells martin richards Life, The Universe, and Politics 2 Oct 22, 2014 04:48 PM
Discussion Duracell 1.2v 2400mah NiMh x8 charging via HK-T6A V2 via charge port Question LemonC Batteries and Chargers 5 Oct 03, 2014 05:34 PM
Help! What charging rate charges quicker? 300 mAh or 1.5 amps? PLEASE HELP! BoeingDreamliner Batteries and Chargers 16 Sep 25, 2013 04:56 PM
