Old Sep 20, 2012, 05:05 PM
Germany, NRW, Dusseldorf
Joined Sep 2012
Dutch sub K-XVIII
Hi all,
I'm new here. Ive scratchbuilt my first sub in the last three years and got it to sail this year.
The K-XVIII was built in 1934 in the Netherlands and made a long sea voyage to the Dutch East indies. It fought the Japanese in WWII and was destroyed by its own crew when the base was overrun in 1942. Lots of photo, film and books are available as the K-XVIII was famous for a long voyage aimed at doing gravity measurements for the Dutch Geology Society.
The model is 1:50, 1.44 meter long and 8 kg weight
The hull is wood, made using the bread-and-butter method
The boat has a divetank emptied and filled with a two way gear pump
The boat opens along the full length, and is seled with a seal along the full hull.
Attached video shows the boat in a swimming pool in Lichtenstein, together with an Austrian U-boat (yes they had them too)
Freek
Model Duikboot K-XVIII in Vaduz September 2012.wmv (14 min 21 sec)
FreekS is offline Find More Posts by FreekS
Old Sep 20, 2012, 05:27 PM
Wichita, Kansas
Joined Jan 2004
I like this boat! Very different and extremely well done!
ThorDesign is offline Find More Posts by ThorDesign
Old Sep 20, 2012, 08:12 PM
BabyBootLegger
sunworksco's Avatar
United States, CA, Alameda
Joined Nov 2010
Very beautiful build!
It looks very much like the later versions of the USS Holland, which I have blueprint drawings.
Regards,
Giovanni
sunworksco is offline Find More Posts by sunworksco
Old Sep 20, 2012, 08:13 PM
tchalfant's Avatar
United States, NV, Las Vegas
Joined Aug 2011
Very well done! Great work!
tchalfant is offline Find More Posts by tchalfant
Old Sep 21, 2012, 01:47 PM
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Looking great, well done
Jan,
Horseman is offline Find More Posts by Horseman
Old Nov 25, 2012, 02:35 AM
Joined Sep 2012
Hi all,
The K-XVIII had a pair of "decktubes", torpedo tubes that could be trained starboard or port and are located under the deck forward of the gun.
I decided to try to make these functional, and started experimenting with rubber motor driven torpedos. Not a new subject I think but I spent some time optimizing 1:50 scale torpedos. Result is OK so far and i have now started on the torpedo release mechanism, a trainable mount that can ejectthe torp into the water and start the motor.
freek
Rubber band torpedoes (1 min 44 sec)
Old Nov 25, 2012, 07:49 AM
RC sub dude
CaptainNemo12's Avatar
Montreal, Quebec, CANADA
Joined Nov 2004
Very promising results with the flight rubber! I've tampered with rubber-band powered torpedoes in the past but have never gotten them to work beyond a range of a few centimeters or so... Do you have good source for obtaining flight rubber?
CaptainNemo12 is offline Find More Posts by CaptainNemo12
Old Nov 25, 2012, 10:29 AM
Joined Sep 2012
I ordered the flight rubber, lucricant and a winder from below adress.
The rubber made a lot of difference as did optimising the propellor pitch as the rpm's are surprisingly high (>10000). Im still waiting for some special props from propshop to see if I can improve further.
The real trick will be to minimize counterrotation, as that might increase range further.
http://www.freeflightsupplies.co.uk/rubber.htm
Old Nov 30, 2012, 04:19 PM
Slovakia, Žilina Region, Zilina
Joined Feb 2012
Torpedo-controlled at a distance
http://www.youtube.com/watch?feature...&v=uzM1xBb6wmk
randaubot is offline Find More Posts by randaubot
Old Nov 30, 2012, 04:28 PM
BabyBootLegger
sunworksco's Avatar
Joined Nov 2010
Do you have drawings ?
Would make a great torpedo !
Regards,
Giovanni
Old Dec 03, 2012, 04:46 AM
Joined Feb 2012
Drawings I have not earned. Torpedo is in 1:40 scale and it ppoužívam in Type XXI submarine with U2540
Old Dec 03, 2012, 05:16 PM
bassplayer1's Avatar
Corfu Greece
Joined Mar 2010
Absolutelly beautifull!!! Very well done!!!
bassplayer1 is offline Find More Posts by bassplayer1
Discussion New Dutch Courage Making Blog Hans UK Dock Talk 0 Sep 08, 2012 02:19 PM
Idea Dutch artist turns dead cat into remote-controlled helicopter herrmill Multirotor Talk 16 Jun 10, 2012 01:05 PM
Ho XVIII (Horten 18 Amerika Bomber) - Design/Build Thread Cyberman Electric Ducted Fan Jet Talk 59 Aug 01, 2011 08:42 PM
Sold SOLD! FS: 1/60 Dutch Walrus Zeeleeuw Sub by Anderson/Reichmuth/Oudmayer Halifax1 Boats (FS/W) 2 Jun 09, 2009 09:46 AM
Discussion Spitfire XVIII peterpont Scale Fuel Planes 2 Sep 12, 2006 04:31 PM
