Old Sep 16, 2001, 05:20 PM
San Diego, CA. USA
Joined Nov 2000
PicoJet Combat on 1400AE vs 800AR
I'm thinking of getting a PJC. I don't like the short flights of 500 or 600 cells and have a bunch of 1400AE and 1700AU Zagi packs. I see other people using Permax 480 with 800AR which I know is the same weight/shape as the 1400 and 1700 but delivers more amps, more RPM and more thrust according to PCalc. Question being: if I used the 1400's would I end up with an underperforming, overweight PJC or not? Anybody put in CP1300's?
Balin is offline Find More Posts by Balin
Old Sep 16, 2001, 05:41 PM
JoeM's Avatar
Colonial Heights Va. USA
Joined Dec 2000
I use the 8x1400AE from my Zagi in both the PJC and now my TJ they work fine. Better in the pjc but very acceptable in the TJ.
About 5 to 6 min in the TJ and 8 to 10 in the PJC.
If you like the PJC try a TJ you will love it.
Joe
JoeM is offline Find More Posts by JoeM
Old Sep 16, 2001, 06:41 PM
small electrics r BIG FUN
Iowa
Joined Aug 2000
8x1400AE will be quite happy with your Permax 480 and 6x4 or 6.5x4 props. And many PJC's are happy with 8x1400AE, including mine with Kontronik 4oo/22 brushless and 6x5 prop.
If you fly full throttle most of the time, 800AR will deliver the most thrill for a while. If you fly mixed throttle, you will love 8x1400AE for a long while.
I have a brand new pack of 1300's but haven't flown them yet. The weight is similar to the 1400ae and 800ar and 1700au . Performance is said to be the same as AR cells.
Regarding the weight/performance issue: With a good toss, once in the air it is easy to forget you are carrying aprox 4 oz more than 500ar/600ae packs. It is helpful to carry a bit more speed into the corners, and landing will be a bit faster. The longer flights make up for it.
Al
Al P is offline Find More Posts by Al P
Old Sep 16, 2001, 10:44 PM
San Diego, CA. USA
Joined Nov 2000
Al,
I'm surprised at the size of the prop(s) you suggest. I figured a MA5.5x4.5 like on the Zagi. Glad to hear the 8x1400 is a good choice as I have 3 (one from you).
"8x1400AE will be quite happy with your Permax 480 and 6x4 or 6.5x4 props."
Balin
Old Sep 16, 2001, 11:30 PM
Iowa
Joined Aug 2000
The Permax 480 spins significantly slower than your 6v 400 so you need a bigger prop to make it "work" efficiently.
In all honesty, I tried this motor with 8 cells and a 6x4 prop and went back to a 6v 400 and 5x4 Gunther (Zagi) prop. I must try the 5.5 x 4.5 prop sometime.
Test both to see which you like better..
Al
Old Sep 17, 2001, 12:11 PM
CMFC Secretary (UK)
BioHazard's Avatar
Swindon, UK
Joined Oct 2000
I've tried all those prop combinations - any many others- but keep going back to the MA 5.5 x 4.5 - definately the best prop.
Other goodies :-
The Perkins Carbon Fibre version of the Graupner 5x5
The Graupner 4 blade 7x4 pusher prop. (just don't go full throttle with 8 cells - as it pulls 27 amps ) Absolutely ballistic at 50% throttle, 8x800AR and Graupner Speed 480 BB Race.
BioHazard is offline Find More Posts by BioHazard
Multiplex PicoJet Combat fs - ARTF on EBAY glovesave39 Aircraft - Electric - Airplanes (FS/W) 0 Feb 14, 2002 09:06 AM
Jamara 480 in PicoJet Combat dezflyer Foamies (Kits) 2 May 18, 2001 12:57 AM
Best Battery for a PicoJet Combat?? windsurfer Foamies (Kits) 10 May 14, 2001 04:59 PM
Why do other EPP planes need tape covering and PicoJet Combat doesn't? WAR Foamies (Kits) 3 May 12, 2001 01:13 AM
PicoJet Combat vs Original peterv Foamies (Kits) 7 Apr 25, 2001 08:16 PM
