Old Apr 17, 2008, 03:22 PM
Drew816 is offline
Find More Posts by Drew816
Smoke, Fire, ahh SMIRE!!
Drew816's Avatar
Columbus, Ohio
Joined Dec 2007
Anyone using an R146ip Futaba Reciever for your T-Rex or like helo???
So I bought one from RC Machine, took three forevers and a day to arrive, finally fired up T-Rex #2 (my future scale build bird) and the Gyro was acting totally weird. Long story, but I went thru all the normal setup and tuning steps with a GY401, copied my 'program' in my Tx from T-Rex #1, adjusted up and down the AVC settings (gain) for HH mode, Reverse switch, etc and still the helo was spinning in place.
So I thought I'd tried my other Futaba Rx, a 148dp (also a PCM1024 Rx on the same channel) and the Gyro was acting differently. I couldn't get the bird airborne as I apparently need to do some more overall tuning BUT the 401 wasn't letting the bird Piro' on the ground like the 146ip. Any ideas? I'm highly confused at this stage and I will post this on the Tx and Rx section of the RC Groups too BUT I thought I'd start with the Helo' experts first to get your input.
Thanks and Happy Flying!
Drew816 is offline Find More Posts by Drew816
Old Apr 17, 2008, 06:22 PM
heli_newbie is offline
Find More Posts by heli_newbie
crash. rebuild. repeat
Fairfield CA, USA
Joined Mar 2005
I've been using the 146ip without issue for over a year, it's a great little TX. Just a guess.. but, are you sure the gain lead on the gyro is plugged in correctly?
heli_newbie is offline Find More Posts by heli_newbie
Old Apr 17, 2008, 08:38 PM
Drew816 is offline
Drew816's Avatar
Columbus, Ohio
Joined Dec 2007
I think I figured it out, I'm running an Align 35X ESC which is running a 6 volts and I think the 146ip is NOT happy with this much power. I swapped over my 148dp Rx from T-Rex #1 and the Gyro seemed to be fine on Rex #2; the bird is setup badly but it wasn't acting the same. So I'm going to try an Align 5.1 v drop down regulator on the 146ip and see if that solves the problem. Man if it's not ONE thing it's another, I thought I was finally going to be flying that bugger today, arrghhh! Welcome to the wonderful world of RC stuffs eh?
Happy Flying!
Old Apr 23, 2008, 11:25 AM
Drew816 is offline
Drew816's Avatar
Columbus, Ohio
Joined Dec 2007
Update: Got the Align 5.1 Volt Drop Down Regulator, plugged it into the 35X ESC's 'input' into the Rx (so the whole bird is now at the lower voltage), got the 146ip all secured and setup and she flew with no problems whatsoever. I now need to get T-Rex #2 up in the air to confirm that I'm not having Gryo problems so I'll be using the 148dp Rx at 6 volts throughout the helo and we'll see here shortly.
But the major question I had was answered, the Futaba 146ip should be run ONLY at the lower voltages, at 6 volts you're going to run into all kinds of problems so keep that in mind and just get a 35G ESC (or equivalent) and same yourselves the headaches!
Happy Flying!
Old Apr 23, 2008, 10:11 PM
darkangellas is offline
Find More Posts by darkangellas
Joined Nov 2005
Happy Flying!
Great info. I am using 146ip in my TRex for a while w/o a problem. But I am using CC 35 ESC that outputs 5V and now I know I was lucky.
Thanks for reminding me Align 35X outputs 6V that I forgot too.
darkangellas is offline Find More Posts by darkangellas
Old Apr 25, 2008, 02:15 PM
Drew816 is offline
Drew816's Avatar
Columbus, Ohio
Joined Dec 2007
Ok, things are still screwy and I can't figure out WHAT the heck is causing my problems. I think I'll start another thread becuase I'm not suspecting the Scorpion -8 v1.5 as the prime suspect here, but basically no matter what combination of parts I move over to T-Rex #2 that has the Scorpion both of my GY401 Gyros can not keep the tail from wandering; badly I might add (like 90 degrees in the direction of main blade rotation within 4-6 seconds).
I've stated by moving my 148dp Rx over from T-Rex #1 to this helo #2, same results, tail wandering.
I then flew the 146ip in T-Rex #1 w/ the Align 5.1 volt drop down coming off the ESC to the Rx and it flew perfectly. I flew this 4 times back to back with my Dad in town visiting and 2 times back to back earlier in the day with no problems, the 146ip w/ the drop down seems to be fine in T-Rex #1.
I switched my 401's back and forth and on #1 they work perfectly, on #2, wander.
My latest 'theory' was maybe the tail slider assembly was binding so I took the extreme action and moved the entire very functional tailboom assembly from #1 and moved it to #2, it flew once 'ok' with a little bit of wandering, I then went to a second battery and it was wandering instantly! What the heck is going on here?!? So I installed the entire tail boom assembly from #2 onto #1 and just flew it and it flies fine, so it's NOT the tail boom-rotor assembly.
Here's the layout of the setup on #2, the 146ip (w/ 5.1 drop down) is located underneath the battery tray so the Scorpion is sitting pretty close, maybe it's messing with the Rx?? The ESC us towards the back of the lower tray getting some cooling from the gearing, the gyro is under the tailblock boom via one of Rick's "thingie" mounts.
I've spent more time chasing this gremlin then I spent building BOTH T-Rex's up from nearly scratch (as you can see from my list of testing steps above). If I had an extra motor I'd just pull the -8 and try another but my other motor met it's maker a week or so ago.
Thoughts?
Old Apr 25, 2008, 03:39 PM
Santini is offline
Find More Posts by Santini
The Great Santini
Santini's Avatar
Madison, NJ 07940
Joined Dec 2004
Drew,
I don't think its your receiver. I have this (146ip) in two V2s (RCE-BL35X (35A) @ 6V, 401 + 9650, 3X hs65mgs, no issues, in fact its perfect -- I have yet to get my first glitch. I am using a 7chp. Before I bought that receiver, I checked it out extensively and its probably the best receiver for a trex set up. It's been flawless.
Bird 1
frame
bird 2
frame bird 2
Bird 1 has the esc up front under the batt tray, while bird 2 it is strapped to the right side of the frame up front (I like that better). It doesn't sound like its an interferance probelm, but just the same I have the wire to the receiver outside the frame, right side, away from anything else + ferrite ring. Receivers are both sitting at the end of the lower flatform, one flat one on its side, pushed back and velcroed so they are just barely handinging out the back. I'm using antenna tubes, no overlaps, coils, not touching anything, or based loaded, with the end of the antenna terminating via a loop w fuel tubing off the horiz stabilizer.
If I were you I would verify other things, such as making sure your signal wire is indeed fully seated in the receiver, also go thru all your settings, make sure your gyro is going to HH. I was futzing with one of them when I was doing an LED lighting project and managed to knock the signal wire somewhat loose and it wandered and would not go HH until that was fixed. I was using a diff plug, not the 401 plug and that caused the issue.
Maybe step through the entire finless set up vid and see what happens..but I think you have a gyro set up or hook up issue at this stage, not a receiver prob. Also, I dont think its a great idea to copy settings between birds, I would just set it up frome scratch, in case there is anything different between them. Lastly, make sure the grub screw that holds the tail hub to the tail shaft is indeed loctited and tight so there is no slipping. Ask me how I know..
Santini is offline Find More Posts by Santini
Old Apr 25, 2008, 03:41 PM
nybbler is offline
Find More Posts by nybbler
United States, NJ, West Orange
Joined Aug 2007
Maybe bad tail-drive gear?
nybbler is offline Find More Posts by nybbler
Old Apr 25, 2008, 05:00 PM
takiss is offline
Find More Posts by takiss
Patras, Greece
Joined May 2007
Hi Santini.
I ahve exatly the same birds with you (!).
I use Park Bec at 6V and 5V for the 9650.
Is it safe with this receiver?
Me too had never any problem, but I am wondering about Rx and 6 V. I never read anything about that.
Is there any refference or just rumors/
Best
Takis Katsoris
takiss is offline Find More Posts by takiss
Old Apr 26, 2008, 07:50 PM
Santini is offline
The Great Santini
Santini's Avatar
Madison, NJ 07940
Joined Dec 2004
If you have the same set up, then you are good to go. I dont use a bec. I've never had a glitch...
Old Apr 28, 2008, 11:22 AM
Drew816 is offline
Drew816's Avatar
Columbus, Ohio
Joined Dec 2007
Just flew T-Rex #2 with the Align 430L motor and it flew fine, no tail wandering, no twitch, no issues. Now that was just one short test flight; the weather is crappy here at the moment and likely to get worse; BUT before the tail wandering would start instantly. So #2 has the 146ip w/ the 5.1 v drop down under the battery tray, 35X ESC in the body under the gear (for some cooling), Gyro under the boom mount.
I also flew T-Rex #1 now equipped with the Scorpion -8 motor and it flew fine, no issues besides the fact the 35X ESC is really under spec'd for this motor (so I'm playing nice) but NO wandering.
I started a thread over here as well specifically oriented towards the Scorpion motor being my 'prime suspect' and I'll post the above results there as well.
http://www.rcgroups.com/forums/showthread.php?t=855138
Very curious, I don't know what to make of all this BUT I'm going to not mess with success and leave the Rex's setup the way they are and keep flying them to see if any 'issues' return. If not, all the better, but I'm at a loss as to what the problem was to begin with. I think the Scorpion was interfering with the Rx but that's totally a guess, but mechanics seemed to have been eliminated as the possibility; that is ASSUMING that these problems don't return on my next flight of course!
UPDATE, a few hours later in the day:
Ok, two more flights on T-Rex #2 and no issues, one more flight on #1; I'm at a loss as to what the issue really was but so far so good. So the motor switch obviously did something 'positive' here and must have been at least a contributor; BUT keep in mind the Scorpion was right next to the Rx and is pumping out some serious power and it's working fine in a more average setup so just something to keep in mind when building...
Wanted Trade my nitro vehicles for your T-rex se 2hotrotts Aircraft - Electric - Helis (FS/W) 1 Aug 30, 2007 01:47 PM
Wanted *CLOSED* WTT my Microheli T-Rex setup for your T-Rex SE V2 H0ndaJunkie Aircraft - Electric - Helis (FS/W) 5 May 31, 2006 12:49 PM
For Sale Heli-up items for your T-rex rcman Aircraft - Electric - Helis (FS/W) 8 May 25, 2006 04:53 PM
anyone using a royal evo tx with a t-rex? mauiguy99 Mini Helis 1 Oct 02, 2005 04:10 AM
Does anyone make a lower gyro mount for the T-rex? number1cop Mini Helis 8 Sep 15, 2005 03:19 PM
