Old Jun 07, 2007, 01:34 PM
mazur50 is offline
Find More Posts by mazur50
Joined Apr 2007
Looking for a Deg of rotation circuit.
I am looking for a circuit that when i turn a pot it will display how many deg of rotaion i have turned the pot.
thanks
mazur50 is offline Find More Posts by mazur50
Old Jun 07, 2007, 01:55 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
Need more details on what you are trying to do. With a linear pot it is pretty trivial, just connect it as a voltage divider and read the voltage.
jeffs555 is offline Find More Posts by jeffs555
Old Jun 07, 2007, 02:40 PM
mazur50 is offline
Joined Apr 2007
I want to use it to tell me how many deg of timming one of my armatures has in it.
Old Jun 07, 2007, 08:00 PM
jeffs555 is offline
Raleigh,NC
Joined Nov 2000
I don't understand the reason for a pot. If you are talking about static timing, you just measure with a protractor, or measure the diameter and calculate the degrees from displacement along the diameter. That will be more accurate than a pot, especially a non-precision pot.
If you want to use a pot, make sure it has a linear taper, preferably a precision pot. Then either measure the resistance or connect it as a voltage divider and measure the voltage. Either will be directly proportional to the rotation of the pot.
Old Jun 08, 2007, 08:58 AM
Gordito Volador is offline
Find More Posts by Gordito Volador
Flying Fatboy
Gordito Volador's Avatar
Tampa, FL
Joined Apr 2003
To do this correctly, you really need a shaft angle encoder to have any degree of reproducability.
http://www.encoder.com/quickreference.html
Gordito Volador is offline Find More Posts by Gordito Volador
Old Jun 08, 2007, 09:57 AM
mazur50 is offline
Joined Apr 2007
do they have any really small encoders. the arm shaft is only 2mm.
Discussion looking for a circuit diagram for a ir Transmitter and reciver for my futarba 6exa jhdgkss Scratchbuilt Indoor and Micro Models 5 Apr 14, 2006 05:27 AM
Discussion looking for a speed controler circuit for electric heli tail motor jhdgkss DIY Electronics 3 Feb 26, 2006 01:22 PM
looking for circuit of old 27mhz AM futaba tx brucej Radios 2 Oct 11, 2004 12:07 AM
Looking for Aerobird Extreme Circuit Board zzjoki Parkflyers 9 Aug 28, 2004 07:17 PM
looking for receiver circuit for r/c car brucej Electric Power Cars 0 Dec 11, 2003 09:14 PM
