Old May 21, 2014, 05:07 AM
_AL_ is offline
Find More Posts by _AL_
Australia, NSW, Hornsby
Joined Jul 2005
Substitute for Parkzone UM motors
I have a Parkzone UM P51, a scratch build Gmite & 2 Stevens Aero micros, all using the Parkzone UM motor & gearbox & AR6400 brick.
I seem to be getting only 15-30 flights before the motors start surging & triggering the motor cut off on the AR6400 brick. At $20 a pop to replace the motor it's getting a mite too expensive to keep throwing good money after bad not to mention it's a royal pain in the backside to get the motors out without damaging the models.
I'm more than happy with the power so not looking for an upgrade, but has anyone found a substitute that'll fit in without too much mucking about & a better life span?
Thanks.
Al
_AL_ is offline Find More Posts by _AL_
Old May 21, 2014, 08:33 AM
JSS4 is offline
Find More Posts by JSS4
I'm BIG on micros
Canada, ON, Brampton
Joined Mar 2011
Several people found that the Solo Pro motor works well in the 1s UM planes. I haven't tried it, but there is a thread over in the Micro RTF forum that may be of help.
http://www.rcgroups.com/forums/showthread.php?t=1326158
Also there is a BL upgrade HH is offering for the NCPX, you might have some success with that.
http://www.horizonhobby.com/products...o-cp-x-BLH3325
Hope that helps
JSS4 is offline Find More Posts by JSS4
Old May 21, 2014, 09:17 AM
thewildweasel is offline
Find More Posts by thewildweasel
Beware the Axis of Weasel.
thewildweasel's Avatar
Plymouth, Devon
Joined May 2007
Yep, solo pro motors are good; bit more power and seem to last longer.
thewildweasel is offline Find More Posts by thewildweasel
Old May 22, 2014, 06:20 AM
_AL_ is offline
Joined Jul 2005
Thanks guys.
I just had a look in the solo pro thread & found the micro motor warehouse which is only 45 minutes from my place.
I think I'll give his motors a try.
Regards.
AL
Old May 29, 2014, 02:35 PM
borkencorter is offline
Find More Posts by borkencorter
Weltherrschaft will be mine
Germany, SN, Leipzig
Joined Nov 2012
I found the v911 motor to be at least as good as the solo pro motor. the v959 motor compares to the bravo sx motor.... have to change gears tho.... but at 3bucks a piece at banggood
ordered several NE yak 54 gearbaoxes lately bbut wasnt too impressed with power and lifespan compared to v9xx motors
borkencorter is offline Find More Posts by borkencorter
Old Jun 02, 2014, 10:01 AM
Bare is online now
Find More Posts by Bare
Canada
Joined Nov 2000
I'd give serious thoughts to retrofitting a wee BL motor.
Yes a bit fiddly but then it only needs doing ...Once
Bare is online now Find More Posts by Bare
Old Jun 02, 2014, 11:30 AM
epilot is online now
Find More Posts by epilot
Remote island inhabitant
epilot's Avatar
Faroe Islands, Sandoy, Sandur
Joined Nov 2000
I contemplated a gearbox for an AP-03 motor but it never made it past the CAD doodle stage. Shortage of spare time at the moment with the 3-4hour daily commute.
epilot is online now Find More Posts by epilot
Old Jun 02, 2014, 03:44 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
They actually have AP03's with a 6mm bearing tube now. They even come with a 7mm adapter ring so they should be direct fit in the stock gearboxes. The only thing you would have to do is press out the shaft and re-install it the opposite direction. The shaft length looks long enough but I'm not positive.
http://www.megasmicros.com/product_p/hp03tv2-13k.htm
I R Irv is offline Find More Posts by I R Irv
Old Jun 02, 2014, 04:54 PM
epilot's Avatar
Joined Nov 2000
Way to high a kV for my liking, even for gearbox use.
Old Jun 02, 2014, 08:05 PM
I R Irv is offline
I R Irv's Avatar
Joined Nov 2008
Your absolutely right, it's perfect for gearbox use.
Old Jun 03, 2014, 03:43 AM
methuso is offline
Find More Posts by methuso
A.K.A sir Crashalot
methuso's Avatar
Ístersund, SWEDEN
Joined Sep 2005
well they have a 7kkv variant on that site too...
/Ulf
methuso is offline Find More Posts by methuso
Old Jun 03, 2014, 05:39 AM
_AL_ is offline
Joined Jul 2005
I bought a couple of these with the 9t pinion.
http://micro-motor-warehouse.com/products/cl-0820-15
I've fitted one to a gearbox but haven't tried it yet in a plane.
I'll let you know how it goes once I've had a chance to test it.
Al
Old Jun 03, 2014, 11:07 AM
Joined Nov 2012
go with the wl toys v959 motor 2 for arond 7 dollars at banggood . there is a lot of data buzzing around here that they re the best (strongest). and i m really happy with them. they last really long , usually my motors get decomissioned when the wire breaks, cuz they survived one or two transplantations to other airframes. after 50+ flights u usually notice a slight decrease in power but its still ok for another 100 at least. as with all coreless motors u sometimes get duds that screech of within the first 5 flights... and, i oil them before first use
what u bought is still f++++ expensive
Old Jun 03, 2014, 11:30 AM
glewis is online now
Find More Posts by glewis
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Which of the v959 motors do you use, clockwise or anti?
glewis is online now Find More Posts by glewis
Old Jun 03, 2014, 12:42 PM
epilot's Avatar
Joined Nov 2000
You need clockwise for a gearbox.
Sold Used motor/gearbox/prop for Parkzone UM T-28, $8 shipped PACubFlyer103 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Apr 11, 2014 05:22 PM
Sold parkzone um t-28 with as3x gyro and 2500kv bl motor, 2 x 2s 200mah IceRain29 Aircraft - Electric - Airplanes (FS/W) 2 Nov 10, 2013 01:12 AM
Sold parkzone um spitfire with as3x and solo pro motor upgrade IceRain29 Aircraft - Electric - Airplanes (FS/W) 2 Nov 06, 2013 07:23 PM
Sold parkzone um spitfire with as3x and solo pro motor upgrade IceRain29 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Nov 06, 2013 07:22 PM
Found Parkzone UM Sukhoi 26m Motor Trade for UM P-51 Motor microflitedude Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Nov 08, 2010 01:56 AM
