Old Dec 27, 2003, 04:18 PM
fprintf is offline
Find More Posts by fprintf
[intentionally blank]
fprintf's Avatar
Cheshire, CT, USA
Joined Jan 2001
Slowstick with EPS400 f gear works nice with cut down 12x6 prop. How come?
I resurrected one of my 12x6 props from the garbage bin after getting desperate for some flying. The ends of the prop were all chewed up and chipped off and the only way to create a balanced prop was to cut the prop down.
So I did and ended up creating what seems to be a 9.5 x 6 prop. The weird thing is, the plane flies and flies very well. I seem to get a lot more RPM out of the motor. I have no idea whether I'll get less flight time or not but I was tickled pink to see the plane fly!
Any ideas why? Or is it just that the GWS slowstick can fly with a couple of wooden spoons as props?
My stock setup is an EPS400 with F (3.3:1) gearing, 8 cell KAN 950 battery pack.
fprintf is offline Find More Posts by fprintf
Old Dec 28, 2003, 04:40 PM
kjkish is offline
Find More Posts by kjkish
San Carlos, California, United States
Joined Apr 2000
Yes, you are getting more RPM out of the motor to the prop and a higher pictch speed.
You can use the P-Calc tool on the www.flydma.com site to see the details.
kjkish is offline Find More Posts by kjkish
Vasa 65 with Wemo 480 cut down Doc Dyer Electric Ducted Fan Jet Talk 2 Oct 05, 2006 04:23 PM
Shogun with T-rex Gear and Cut down blades HoverDown3K Mini Helis 0 Feb 11, 2005 09:59 PM
help with cut down zagi PLEASE JimF Flying Wings 3 Nov 15, 2004 04:01 AM
cut down zagi 400x with a speed 480 or a400 and 10 cells? asjeep Foamies (Kits) 1 Mar 26, 2004 02:25 PM
f/s s400 6v with 1.85 gear dr.E Aircraft - Electric - Airplanes (FS/W) 0 Sep 20, 2002 10:57 AM
