Old Nov 12, 2012, 03:31 AM
stoke on trent UK
Joined Feb 2010
Os max 90 problem
hi, hope someone can point me in the right dircetion please. os max hz .90 fiyyed to elyq 90. starts perfect with an align ignition switch and runs for about 5 minutes then cuts out. starts again fine but cuts out when ignitor turns off. same again the following day if i leave it. runs foi 5 minutes then cuts out. i have changed the glow plug and the same problem? any ideas where i start? thanks.
roger200 is offline Find More Posts by roger200
Old Nov 16, 2012, 09:20 AM
United Kingdom, England, Leics
Joined Feb 2010
Cutting out
Mmm sounds like mixtures
Is the back of the crank case hot
By hot I mean hot burn cannot keep your finger on for more than 1 second?
Richen top end
or finger on for 5 secs then hot?
Can u pinch the fuel line and does it cut immediately (bottom end to lean)
It should run on for around 5-10 secs :
Dave p
dave peers is offline Find More Posts by dave peers
Sold BCM Bisson Side Mount muffler for OS MAX .60 or .90 Price reduced to $20 unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 23, 2012 08:44 AM
Sold OS Max .60-.90 Muffler NIB with gasket and mounting bolts unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 6 Mar 22, 2012 06:36 AM
Sold BCM Bisson Side Mount muffler for OS MAX .60 or .90 unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 20, 2012 06:47 PM
Discussion OS Max 90 2 stroke problem 70's Flyer Engines 1 Apr 05, 2009 07:58 PM
Help! OS Max 90 with Valbro carb problem vgk Engines 0 May 11, 2006 12:24 AM
