Old Jun 16, 2015, 06:55 PM
lrb75 is offline
Find More Posts by lrb75
United States, VA, Springfield
Bvm air cylinder
Working on an older bvm f16. The nose gear air cylinder leaks past the front seal pretty badly. It's intermittent and if you push on the rod it will usually seal up. Any idea what sized oring would be to repair? Guess I could get a new cylinder but figure I would try to fix it.
lrb75 is offline Find More Posts by lrb75
Old Jun 16, 2015, 07:10 PM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
I would try injecting some o ring lube first.
Barring that, this is the large one? .75 diameter I think? Pm me if interested, if you pay pal me $10 for shipping i'll send you one.
Chris True is offline Find More Posts by Chris True
Old Jun 16, 2015, 07:33 PM
lrb75 is offline
I tried the thin bvm oring lube and the thick parker oring grease. The grease may have helped some. The oring may have gotten melted when the extended brass tubing was soldered on by the original owner. $10 shipping is outrageous I would rather fly with you at pgrc and pick up, but not sure you are going to come back now that your other field has the petromat. anyway appreciate your offer. I will take the old one out and see if I can clean it grease it and see what happens. If that doesn't work I'll pull the oring. If that doesn't work I will get with u via pm. I will also measure to make sure we are talking the same sized cylinder.
Old Jun 16, 2015, 07:49 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
You must not order much online!... That' s dirt cheap..
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jun 16, 2015, 09:00 PM
Joined Dec 1996
We can meet up at Pgrc, no problem
Old Jun 16, 2015, 10:01 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
shipping just went up june 1st. so yeah $10.00 is what I would charge right now...unless it is small enough to put in a envelope.but still your paying for the guys time and gas to get to thee PO.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Jun 17, 2015, 08:41 AM
Joined Dec 1996
It's all good guys, it was a joke. Note the smiley face
Old Jun 19, 2015, 09:14 AM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
No Jokes allowed, this is the internet, everything serious!
invertmast is offline Find More Posts by invertmast
Sold Bvm door air cylinders set(4) hmjets Aircraft - Fuel - Jets (FS/W) 0 Apr 09, 2015 11:58 AM
Sold BVM door cylinders,set(4pcs) hmjets Aircraft - Fuel - Jets (FS/W) 3 Mar 25, 2015 05:49 AM
Sold NIB BVM door cylinders set(4) hmjets Aircraft - Fuel - Jets (FS/W) 0 Mar 07, 2015 12:48 PM
For Sale BVM Assist Cylinder bvmflier Aircraft - Fuel - Jets (FS/W) 0 Jan 28, 2012 03:30 PM
For Sale BVM Main Cylinders bvmflier Aircraft - Fuel - Jets (FS/W) 0 Jan 28, 2012 03:21 PM
