Old Jan 07, 2014, 02:52 PM
mklinker is offline
Find More Posts by mklinker
mklinker's Avatar
Joined Jun 2011
New Product
FFBLG: Gimbal for Mobius Action Camera
Here is a brushless gimbal designed for the Mobius Action Camera.
The kit for this gimbal is available for $35 at http://klinkeraerospace.com/
It is 3D printed out of ABS plastic, and designed to be used with a wide variety of motors and controllers.
-Designed to be mounted on front of QAV, TBS Disco, Phantom, or any multirotor.
-Integrated vibration isolation.
-Lighter than aluminum.
-Basic, simple design that is easy to build and install.
Please post here to discuss what you think of the gimbal, 3D printing in our hobby, and what you would like to see in the future.
There is another thread here on RCGroups, but I wanted to talk about the gimbal specific for the Mobius Camera.
mklinker is offline Find More Posts by mklinker
Old Jan 08, 2014, 10:20 PM
hoggdoc is offline
Find More Posts by hoggdoc
United States, CA, Huntington Beach
Joined Jan 2013
The kit for this gimbal is available for $35 at http://klinkeraerospace.com/brushles...ech-specs.html
-Designed to be mounted on front of QAV, TBS Disco, or any existing multirotor (DJI Phantom included!).
I actually have the very first of these Mobius Gimbals. Mike did a super job of designing this unit, the balance of both pitch and roll are near perfect.
I diffidently recommend this gimbal, don't let it's simplicity and cost fool you.
HD
hoggdoc is offline Find More Posts by hoggdoc
Old Jan 21, 2014, 07:09 AM
François_D is offline
Find More Posts by François_D
France, near Rennes, Bretagne
Joined Sep 2010
I also got one and I'm very happy with it ! Thanks again Mike !
I just built this hand held box to experiment with settings (and before using the gimbal in a fpv glider).
The controller board can use the alexmos 2.2b2 software.
As you can see, this one came with a very small accelerometer/gyroscope sensor.
It works from a 9V battery and I added a on/ff switch, led, and a joystick, to control the pitch, and, more useful, to use it for switching between profiles, for example with or without "follow mode".
François_D is offline Find More Posts by François_D
Old Jan 21, 2014, 04:32 PM
mklinker is offline
mklinker's Avatar
Joined Jun 2011
I really like what you did with the Mobius gimbal! Where did you get the joystick from?
Old Jan 21, 2014, 04:35 PM
hoggdoc is offline
Joined Jan 2013
How about a short video showing this in operation along with a sample video clip.
HD
Old Jan 21, 2014, 05:09 PM
Joined Sep 2010
It's an ebay purchase, easy find, I don't remember which seller but here is one for $1.99 for example. They are similar to the models used in Playstation pads, and usually associated with Arduino developpement kits.
I might do this tomorrow...
Old Jan 23, 2014, 09:25 AM
mklinker is offline
mklinker's Avatar
Joined Jun 2011
I'm looking forward to the video!
what type of signal does that playstation pad put out for each axis?
Old Jan 23, 2014, 11:13 AM
Joined Sep 2010
This joystick is pure analog, ie it's just two potentiometers and a switch. You give it gnd, vcc, and you get two analog tensions from the pots. For now, with the two motors / two axis board, I only wired one axis of the joystick (vertical) to the pitch, as controlling the roll has no interest. It would be useful for the yaw on a 3 axis configuration.
There is a (menu) button on my controller board but no button connector, so I just soldered a wire on the button..
I'll shoot some video soon, I need some time.. and I'm still fighting with the PID values to get a smooth optimized operation
Also, for real life use, as I discovered by experience, the principle of a "handle" behind a 2 axis gimbal is not the best. The handle would be best placed under it, on the non stabilized yaw axis. Once you stabilized two axis, the defaults from the non stabilized one are even more visible...
Old Jan 24, 2014, 12:08 PM
Neilyboy is offline
Find More Posts by Neilyboy
Joined Mar 2013
I am very interested in this project! I will be building one of these in the near future!!
Neil
Neilyboy is offline Find More Posts by Neilyboy
Old Jan 28, 2014, 07:55 PM
mklinker is offline
mklinker's Avatar
Joined Jun 2011
Same gimbal, different camera!
Forward Facing Brushless Gimbal on S800 (1 min 19 sec)
Old Mar 09, 2014, 08:57 AM
mykalt45 is offline
Find More Posts by mykalt45
Joined Oct 2013
Would you sell the plans for this so I could make it for myself? My friend has a 3D printer, and I'd like to try make it for myself. I am not intending to sell it or anything, I just want to see if he could make it and we could shave and alter the design a bit for personal use? Also, would this work for an AR Drone 2.0?
mykalt45 is offline Find More Posts by mykalt45
Old Mar 09, 2014, 09:52 AM
hoggdoc is offline
Joined Jan 2013
I can't believe you are even asking this. Mike has spent hours developing and refining his designs.
I truly hope his answer is NO!
HD
Old Mar 20, 2014, 12:42 PM
scrub is offline
Find More Posts by scrub
Joined Feb 2014
Brushless gimbal for Mobius
Hi Mike,
I am interested in your 3D printed gimbal for my mobius.
I have a GLB 2 axis gimbal (its heavy and overkill for my mobius http://www.goodluckbuy.com/dji-phant...otography.html , can I use the two brushless motors and the alexmos 2.2b it came with on your gimbal mount?
Scrub
scrub is offline Find More Posts by scrub
Old Mar 20, 2014, 12:50 PM
mklinker is offline
mklinker's Avatar
Joined Jun 2011
Originally Posted by scrub View Post
Hi Mike,
Scrub
Yes, all of those parts should be compatible with my gimbal kit.
Old Mar 20, 2014, 01:22 PM
scrub is offline
Joined Feb 2014
Ok, thanks!
New Product FFBLG: Low Cost, Simple Brushless Gimbal for Multirotors mklinker Multirotor Talk 1344 Aug 02, 2015 01:17 AM
Help! HOBBYKING 5.8GHZ 200mW to MOBIUS ACTION CAM CONNECTION dhonwyn Aerial Photography 3 Feb 02, 2014 09:10 PM
For Sale Mobius 1080P HD Action Camera- BRAND NEW - $65 shipped LHTPlane FPV Equipment (FS/W) 5 Jan 05, 2014 02:53 PM
Sold Mobius action camera bonito13 FPV Equipment (FS/W) 0 Oct 07, 2013 11:48 AM
Sold Mobius 1080P HD Action Camera Chad2323 FPV Equipment (FS/W) 4 Oct 04, 2013 02:54 PM
