Old Jul 31, 2015, 05:25 PM
ernie b is offline
Find More Posts by ernie b
3RN13
ernie b's Avatar
United States, IL, West Chicago
Joined Feb 2008
Originally Posted by Gregertman View Post
Yep I'm sure I have 2 or 3 spares. I got your pm I will get it out to you.
Hello Greg
Got the package, just what the doctor ordered!... Thanks!
If you PM your paypal acct, I would be glad to reimburse.
You guys are awesome!
Ernie
ernie b is offline Find More Posts by ernie b
Old Jul 31, 2015, 10:41 PM
Gregertman is online now
Find More Posts by Gregertman
United States, IL, Glenwood
Joined Nov 2013
Don't worry about it. It's better that you can use it then sitting in my spare parts box. I still have another spare if I need it plus a whole spare motor with one on it. I like to have spare parts with me I have spare evreything just about. Weather should be good tomorrow so get it out there and fly it. Tomorrow will be my first time flying in over a month. I was moving my shop for the last month so I'm so sick of moving boxes and equipment. I guess we'll find how rusty my thumbs are tomorrow.
Gregertman is online now Find More Posts by Gregertman
Old Aug 01, 2015, 08:04 AM
Potoczak is online now
Find More Posts by Potoczak
Learning 3D
United States, PA, Kunkletown
Joined Mar 2015
Just picked a used mxs last night from a member rcgroups. The plane is in ok shape but needs some work. When I got home I noticed that the control horns in the ailerons were two different lengths. Is it possible to remove one of the horns without damaging the wing??? It looks like epoxy was used to secure them in place.
Potoczak is online now Find More Posts by Potoczak
Old Aug 01, 2015, 09:40 AM
Luv3d is online now
Find More Posts by Luv3d
Honeybadger don't care...
Luv3d's Avatar
United States, FL, Winter Park
Joined May 2010
Yes- you can dig them out of the aileron, but it is an ugly project. You might find that it's easier to cut a block of balsa out (around the existing horn) and replace the balsa with a slot for the new horn as well.
What I don't know is if you can get the proper horn all by itself.....but if you had (or know) anyone who lost a 48" airframe....I'm sure they are the same part across all the 48's....
Luv3d is online now Find More Posts by Luv3d
Old Aug 01, 2015, 06:17 PM
flygilmore is offline
Find More Posts by flygilmore
Pro Bro #1963
United States, VA, Dublin
Joined Mar 2004
It's not an ugly project at all IF you have a dremel and the right size bit. Go slow and you can grind the G10 horn out while pretty much maintaining the original size slot. I'd epoxy the new horn back in.
EF has horn sets for the 48"s btw.
flygilmore is offline Find More Posts by flygilmore
Old Aug 01, 2015, 11:15 PM
Learning 3D
Joined Mar 2015
Should I just cut the horn even with the wing then just grind away a slot again in the same spot with a dremel??
Old Aug 02, 2015, 10:51 AM
Luv3d is online now
Luv3d's Avatar
Joined May 2010
I've never tried that with a dremel in balsa, grinding out a hard material like G10.
Interesting idea. How do you hold it steady enough not to chew up the soft wood around it? If that works, I'd call that a winner- provided you have the tools.
Cutting the horn even with the surface of the aileron seems like a reasonable place to start, if you are going to attempt this method.
Old Aug 02, 2015, 01:07 PM
Sweguy is offline
Find More Posts by Sweguy
Sweguy's Avatar
Joined Mar 2013
A few from today.
Description:
Description:
Description:
Sweguy is offline Find More Posts by Sweguy
Old Aug 02, 2015, 10:46 PM
Pro Bro #1963
Joined Mar 2004
Yes, cut the horn flush or slightly below the surface. I use a very sharp cutting bit smaller diam. the better. Tape the control surface still and really brace your arms steady. Go slow! It can be done very well.....I've had to do it before.
Video Extreme flight rc mxs-exp EXTREME FLIGHT Electric Plane Talk 12 Jul 21, 2014 06:24 PM
Discussion EXTREME FLIGHT MXS EXP part 2-First prototype assembly and evaluation process EXTREME FLIGHT 3D Flying 2178 May 13, 2012 10:51 PM
Sold 48" Extreme Flight Edge 540T-EXP red white blue -$320 ARTF AirRaider_2009 Aircraft - Electric - Airplanes (FS/W) 5 Nov 07, 2010 10:50 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
